I wonder where is the best location to place a after market fuel pressure regulator in a stock twin turbo engine bay? I saw some installation on the end of fuel rail on firewall side, wonder if there is other secure location to install?
theres no best location really. it can be put anywhere it fits. its up the user to decide where the "best" location is. what might be a good location for some might not be possible for others. put it wherever there is room.
^ I would add the caveat that it is installed AFTER the fuel rails. The FPR doesn't regulate any pressure on its return side, so if the OP were to install it on the line before fuel flows into his rails they would not be able to effect the pressure any.
I've seen some on the front of the intake manifold, so basically the inlet would go through both rails backwards from firewall to the front and to the regulator, than back to the tank.
where did you relocate your pressure chamber and the turbo precontrol/wg control solenoids to?
You can kind of see it in this picture, the tank is mounted on the air pump bracket, it rests on top of the primary turbo intake elbow perfectly. I'm running a GReddy EBC so no precontrol/wg solenoids.
they make conical seals for AN fittings if you've had bad luck. They work well.
I have found those to be helpful on my -10 oil lines. I was able to fix my fuel lines ok, I still don't like the metal to metal seal for fuel personally. I had a small fire where my fpr return fitting leaked onto the twins exhaust manifold. It was easy to put out but it could have been a disaster. I'm contemplating switching to hose and barb fittings lol
