Sprint RE car wont start
Sup ya, so today i finished setting up ,u wiring and ecu, new spark plugs, map sensor connected, fuel pump wired, LS coils, ect. i updated my ecu firmware, loaded the S5 base map, ignition settings to direct spark for the LS coils, and car wont start
doesnt even sound like it wants to start. i pulled the spark plugs to see if it was flooded, and no. i used a simple light tester on the spark plug cables and there is power coming thru. i tried turning the CAS and nothing, so i tired starting fluid thinking maybe theres no fuel. AND nothing!! is there something im missing?
SPECS.
Jspec S5 swap, knight sports hybrid turbo, greeddy top mount, uknown if ported or not, stock injectors, omp blocked off, emissions blocked off, LS coil packs.
doesnt even sound like it wants to start. i pulled the spark plugs to see if it was flooded, and no. i used a simple light tester on the spark plug cables and there is power coming thru. i tried turning the CAS and nothing, so i tired starting fluid thinking maybe theres no fuel. AND nothing!! is there something im missing? SPECS.
yes it cranks, on my laptop it shows rpm go to 280 when cranking, tps is showing, vacuum pressure too. i didnt know we had a haltech section, i will go check that out. and what d you mean base timing?
also there are 2 ground wires, black and black with white, one goes to the chassis and the other to the battery, as of now they both are grounded to the chassis, any reason why one has to go to the battery?
oh thats right! im looking at my main pulley and theres to notches on it, how do i know ich is -5 or -20? getting a timing light is going to be hard, ill see of an auto parts store has one.
I not an expert, but i dont see anything that should prevent the car from starting
Yeah check timing and line it up. Make sure the engine isnt flooded as well. What the history on this engine? Fresh rebuild?
yeah stock pulley, i checked it out and i got it adjusted right. im thinking i connected the injection order wrong cause it kind of floods when i try to start it, motor is in unknown condition.. but when i deflood it compression sounds loud and constant
Ok so i found out i have no spark. I connect all the wires to spark plus amd sat all 4 one by one on the manifold, nothing. My ls coils are brand new. So.i tried thpse simple tester pens. And only 2 has power but very weak. I had to look.in the pen to see the light super dimmed. Those 2 are my leading cables right
The B/Y wires to the coils power the coils w/key to on, so check this aspect. The coils need to be bolted cleanly to the fender to be grounded, otherwise they don't work. The Green/Yellow wire at the lead coil is the trigger wire. W/key to on the voltage alternates between two values (0 volts and 5 volts) as the main pulley is rotated by hand (rotating the alternator pulley helps to rotate the main pulley).
wiring should to the coils should b perfect, i bought them from angel motorsports, who he made for a rew swapped fc, they got the car running but he ended up going a different route, on my part all i did was run the wires to the battery and ground. can it be a tuning problem?
yeah, i turned the cas by hand and the injectors click, its weird, i have rpm reading fine when i crank, but no power to the coils, im thinking i have a bad ground? this harness was used in a rew swapped fc just fine, the shop i got it from said the customer decided on a different route
Now that I'm thinking about it, check wiring to the coils. If you used the wire diagram on this forum, it's incorrect. Double check it.
Adaptronic Looking for a base map for single turbo S8
Charlieparker
Adaptronic Engine Mgmt - AUS
Mar 18, 2016 02:39 PM
