new gauge setup - prosport white/amber
Old Jan 26, 2009 | 12:55 PM
neit_jnf's Avatar
Thumbs up new gauge setup - prosport white/amber
this probably goes in the interior section but its a 3rd gen so I figure it will get most views here.
FlyRX7 center speaker 52mm quad pod
Gauges: AEM UEGO, Boost, EGT, Oil Temp
for the EGT I will install a O2 bung to 1/8 npt adapter to use the stock O2 sensor location. I know it's not the optimal location but I plan on installing it in the rear exhaust runner pre turbo some time later when I get around to pulling the twins.
for the oil temp I will use a Oil Pan drain plug to 1/8 npt adapter to get the temps. I'm used to this location since I was using a VDO that had the sender integrated in the oil pan drain plug.
Attached Thumbnails new gauge setup - prosport white/amber-photo_012609_001.jpg   new gauge setup - prosport white/amber-photo_012609_003.jpg   new gauge setup - prosport white/amber-photo_012609_004.jpg   new gauge setup - prosport white/amber-photo_012609_005.jpg   new gauge setup - prosport white/amber-photo_012609_006.jpg
Old Jan 26, 2009 | 01:00 PM
RA8225's Avatar
Banned
You suck at taking pics, gauges look good
Old Jan 26, 2009 | 01:16 PM
neit_jnf's Avatar
haha they're cellphone pics
Old Jun 23, 2016 | 09:11 PM
RA8225's Avatar
Banned
So over 7 years later are you still using these gauges? I ask because I'm thinking about getting their premium series in Boost and Oil temp and keep my AEM A/F just like how you have yours.
I would like Defi Racer series but defi costs are ridiculous
Edit. I notice no one really uses VDO gauges even though they make gauges for Porsche etc.. .Why is that? Old technology?
Old Jun 23, 2016 | 09:47 PM
Houstonderk's Avatar
My girl
I enjoy mine and keep it just the orange. With the peak and setting adjustments on the gauge it is easy to swap out or adjust as needed.
Old Jun 27, 2016 | 02:00 PM
neit_jnf's Avatar
I changed my setup and will be changing again.
Now I only have an Innovate AFR and Prosport Boost in a dual pod
New setup will likely go back to quad pod with oil temp and Aquamist water injection gauge.
Old Jun 28, 2016 | 06:53 AM
Sgtblue's Avatar
Urban Combat Vet
That's a lot of gauges. What will the gauge monitor on the WI system? Tank level?
Old Jun 28, 2016 | 08:54 AM
neit_jnf's Avatar
on/off, flow, level and some adjustments
Old Jun 28, 2016 | 10:22 AM
Supernaut's Avatar
[/IMG]
Just to be clear, I think neit meant on/off, flow level and some adjustments. If I remember correctly, I believe the adjustments on the gauge are just for the gauge themselves.
Also, for people having issues with too many gauges, I recommend looking at the PLX multi-gauges.
Old Jun 28, 2016 | 11:34 AM
neit_jnf's Avatar
well to be more clearer
Old Jun 28, 2016 | 08:47 PM
RA8225's Avatar
Banned
Are you still happy with the prosport? Are they accurate? I've read some reviews, albeit from years ago that customers were not happy.
Just asking before I pull the trigger
Old Jun 28, 2016 | 09:31 PM
Rikk's Avatar
Rotary Porn Addict
^^+1 I've heard the same thing about accuracy I'm curious as well
Old Jun 29, 2016 | 10:56 AM
neit_jnf's Avatar
no idea about accuracy, I never tested them against anything else other than the PFC and to me they were alright
Old Jun 29, 2016 | 03:47 PM
airjordan223's Avatar
brapbrapbrap
I have prosport boost, temp, and oil gauges. No problems so far and the orange is spot on with the factory gauge color.
Jeff20B
73
Sep 16, 2018 07:16 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
vmerino
Sep 5, 2015 11:26 AM
