My friend Mini Me 3 rotor FD 831 @ 27 psi.
Old Dec 3, 2010 | 08:31 PM
  #76
t-von's Avatar
Rotor Head Extreme
^ This! Can't wait for results!
Old Dec 6, 2010 | 09:11 AM
  #77
lantis's Avatar
Question to the guy who owns the car. I have a 20b in an fd and i am having problems with the car wondering in the road as a result of bump steer. the car also looses the alignment soon after being aligned. have u encountered any similar problems and if so how did you rectify.
Thanks alot
Old Dec 6, 2010 | 09:21 AM
  #78
RZMotorsports's Avatar
1000hp Quest
Steering
Thanks alot
I never had that problem. Several questions I will ask you to determine your problem would be.
1. what kind of cross-member you used for the 3 rotor conversion?
2. and how was the kit completed?
I had a friend that was having the same problem with his 3 rotor conversion but it was because the custom made his cross-member from a stock one without taking the proper measurements to accommodate the engine in the correct position and the kit they used didn't work at all. So the car went every way but forward.
Old Dec 6, 2010 | 10:08 AM
  #79
lantis's Avatar
It is a hinson http://www.hinsonsupercars.com/p-23-...equipment.aspx.
this is the kit i used and it came with bumpsteer prevention kit but the car wanders really badly. what sub frame did u use. I would send pics later on but the car wonders badly. The rear suspension has RP drag launch kit racing beat diff brace an cusco lsd.
Old Dec 6, 2010 | 10:24 AM
  #80
Gorilla RE's Avatar
GorillaRaceEngineering.co
Thanks alot
I'd say, that your toe is overly negative or your stearing rack is loose on the subframe.
-J
NOTE: instead of posting this question 3 times in 3 different threads in the same day, why don't you start your own thread or search for the answer
Old Dec 6, 2010 | 11:27 AM
  #81
lantis's Avatar
-J
Yea i did that first but i just kinda impatient so i just decided to ask everyone. the post is there.
Old Dec 6, 2010 | 01:21 PM
  #82
TRWeiss1's Avatar
LSx 7.0L
Amazing project man, LOVE IT! God, there have been so many nice 20B projects popping up lately...I've got the itch bad!!
Anyway, great numbers and I look forward to seeing some track times!
Old Dec 6, 2010 | 05:18 PM
  #83
1000hp Quest
Future plans in the horizon
I am waiting to have the t56 kit installed and tested. The I already made alot of upgrades like 1000hp axles, Kaaz diff, ect now I'm working on t56 kit and some fuel changes after all change then I am planning to take it back to the dyno to go for my original goal of 1000hp plus to the wheels. I stopped at 831 because car was spinning the tire on the dyno even with 2 people in the trunk plus it kinda dangerous to go for that much power and brakethe OEM transmission, axles or differential and injure somebody. I want power but safe. That is why I created the SFI certified bellhousing in case the clutch explodes it would be contained inside the bellhousing. Then after that I will be taking it to track and make some low boost passes and maybe raise the boost and let it all out (get kicked out of track) no roll cage
Old Dec 6, 2010 | 05:20 PM
  #84
1000hp Quest
Sound
Originally Posted by ndisgii
Man that is pure nasty right there. Sounds wicked!
Thank you . It's been a long 10yrs in the making. But it's all worth it.
Old Dec 8, 2010 | 10:37 PM
  #85
1000hp Quest
T56 magnum is in!!!!
The prototype T56 magnum is in. I received today the prototype SFI certified bellhousing and the T56 magnum and clutch. I will be test fitting tomorrow and check how everything fits will update then. Here are some of the pics.
Attached Thumbnails My friend Mini Me 3 rotor FD 831 @ 27 psi.-photo.jpg   My friend Mini Me 3 rotor FD 831 @ 27 psi.-photo-2-.jpg
Old Dec 9, 2010 | 05:55 AM
  #86
David Hayes's Avatar
Looking forward to seeing how the tranny pans out for you. I know it's one of the next items I need to address, although I just have a "mild" 650 HP 3 rotor version
When you have it together, I would be interested in your feedback on street drivability versus the stock setup. Does it shift smoothly, etc?
Old Dec 9, 2010 | 08:56 PM
  #87
fastrx7man's Avatar
Looking for 10's
I am looking forward to this being complete. I am dropping mine off at rotary performance tomorrow to have a voltage issue fixed and the rear end upgraded...
Old Dec 15, 2010 | 12:04 PM
  #88
1000hp Quest
Test fit
Last week we test fitted the bellhousing to the T56 magnum and then to the engine and we have some tweaking to so but everything is coming out great fits perfect under the tunnel cover. We will be working and creating a trans mount, short shifter, etc. So far I found that we might have to use the stock automatic starter that installs forward. Unless we can come up with a solution for installing a smaller starter, because they would like to offer the bellhousing also for 2 rotor conversions but it only would work now if the have a automatic back plate. So we are working on that. Will keep you posted but I am very exited how everything is coming along. More pics to come. Stay tuned.
Old Jan 3, 2011 | 01:48 PM
  #89
staticguitar313's Avatar
R.I.P. Icemark
how much are those T56 to REW SFI bellhousings going for?
Old Jan 3, 2011 | 02:53 PM
  #90
1000hp Quest
Transmission search
When I started my search for a replacement transmission I concisered several options like guru trans (not available), greddy 6 speed (not available)or HKS sequential 19,000 not a option lol. Then I looked at the t56 it was very vesitile and cheap to rebuild if anything went wrong and several companies had upgraded trans that could hold upto 1000+hp. So I decided at the time to go with the standard t56 the only one available at the time. The pros it was able to hold 450hp, availability was good in junk yards and price was reasonable at around 1,800 to 2,300 depending on milelage. But while reschearching Tremec came out with their new version of the t56 called the t56 magnum capable of holding 700 torque and much more advance in technology. The price is 2795 I believe. So doesn't make sence to pay 1800-2300 for a use t56 thy would handle less torque and you really don't know what kind of abuse it was put thru that you might install it and then a couple of months later might have to take it down and rebuilt it costing you more time and money. So I decided to go with the t56 magnum for obvious reasons. Also the new trans comes with 1 or 2 yr warranty and I can be upgraded to a 1000hp+ transmission brand new out of the box for around 2000 more I think. I should be posting some pics of updates probably today. Hope it helped.
Old Jan 3, 2011 | 09:40 PM
  #91
1000hp Quest
here are some pics
here are some of the pics
Attached Thumbnails My friend Mini Me 3 rotor FD 831 @ 27 psi.-photo-6-.jpg   My friend Mini Me 3 rotor FD 831 @ 27 psi.-photo-7-.jpg   My friend Mini Me 3 rotor FD 831 @ 27 psi.-photo-8-.jpg
Old Jan 4, 2011 | 12:39 AM
  #92
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
yep I'm officially drooling
  #93
Gurew's Avatar
indeed!
Old Feb 15, 2011 | 09:56 PM
  #94
4CN Air's Avatar
DETH TRP
updates?
Old Feb 18, 2011 | 10:49 AM
  #95
1000hp Quest
Updates
Originally Posted by 4CN Air
updates?
Currently working in so upgrades and getting so finishing touches to the t56 install. With the upgrades I really believe 1000hp should be accomplished soon. If anybody is interested I will be selling the parts I'm taking out of the car like the 3 disk ORC clutch only 50-100 miles on it amazing clutch cant use it with new trans. I also have a stock trans with short shifter. Driveshaft, torque bar ect. Stock differential, axels.
Old Feb 24, 2011 | 09:48 AM
  #96
ITSWILL's Avatar
Wiring Nightmare
subscribed
Old Feb 24, 2011 | 01:13 PM
  #97
Rxmfn7's Avatar
Do a barrel roll!
Is there anywhere where you can get custom gear rations for the T56? Id love to swap one for its strength, but for my application I will be making significantly less power, and really have zero interest in the double overdrives. Id like to have tighter more closely spaced gears, with 5th more towards 1:1 and and 6th somewhere around .8x. Just wondering if thats a possibility, because in searching I havent found anything.
Old Feb 24, 2011 | 07:13 PM
  #98
t-von's Avatar
Rotor Head Extreme
Since your going NA as I am, you can go with the T56 m12 tranny (GTO/CTS) with 4.44 or 4.77 Rx8 rear axle ratios and get close to what you want. Use this page to input the gear ratios and see for yourself. Personally I want that tranny with 4.30 gears. As the 5th gear is better suited for acceleration than the stock fd 5th gear. I also want the 6th gear for strictly highway fuel economy.
http://www.f-body.org/gears/
Edit actually an S1 or S2 Rx8 6 speed tranny may work for you. It is said they will handle 300lbs torgue at the tires. NA 20b wont come close to this. The main issue with the S1 tranny's was the faulty clutch pedal mechanism that caused some trannys to prematurely fail because of them NOT being fully disengadging when fully depressing the clutch pedal. What I mean is the weak poorly designed factory Rx8 clutch pedal was mostly responsible for the failed Rx8 6 speeds. You won't have that problem with the Fd's set-up.
Old Feb 24, 2011 | 10:46 PM
  #99
Rxmfn7's Avatar
Do a barrel roll!
^ The rx-8s trans is appealing to me, I just wish I was more confident in its strength. I plan on road racing a good bit, and the occational trip to the drag strip , and I just hate to have a potential weak link always in the back of my mind. The ratios do seem close to ideal for what I want though.
Old Feb 25, 2011 | 01:33 AM
  #100
KKMpunkrock2011's Avatar
dorito powered
proper cooling of the tranny on the road coarse should alleviate that concern.
as for the drag strip, I dunno what to tell ya.
