Limp Mode Returns after ECU reset.
Old Jul 14, 2002 | 08:36 PM
grinn253's Avatar
Question Limp Mode Returns after ECU reset.
Hey all,
Stock FD (sans MazdaComp Rad)
It seems that my FD tends to go into "Limp/Safe Mode," pretty often nowadays. I do reset the computer (unplug neg battery cable, and depress brake pedal). After resetting, the car runs/boosts fine. Drive and shutdown a couple of times more and FD is back into safe mode!
At first this happened sporadically, then a little more frequent, now it is happening almost after every shut off.
Yes i do wait for proper warm up, and i don't think the MazdaComp Rad is overcooling; it used to happen with stock rad as well.
I searched and the closest thread to my topic remained unanswered:https://www.rx7club.com/forum/showth...threadid=66808
I believe that thread assumed a bad "map sensor." Is this the culprit?
Thanks!
Edgardo
Old Jul 14, 2002 | 08:43 PM
duboisr's Avatar
does the check light come on , read codes and make the repair if you get a code ,if no code ????,
Old Jul 14, 2002 | 08:52 PM
grinn253's Avatar
no check lights.
Old Jul 14, 2002 | 11:51 PM
rx4ur7's Avatar
I would try checking for "stored codes" in the ecu even though your not getting a check eng light. if your not sure how just call or ask in a thread and i'll explain. you must check after it goes to limp
Old Jul 15, 2002 | 01:20 PM
grinn253's Avatar
okay, i'll check since it is in limp mode again, heh.
I'll search to find out how to check...I remember its something like grounding 2 places with a paper clip.
Thanks!
Edgardo
Old Jul 15, 2002 | 10:38 PM
slipperyslater1's Avatar
Mine did that, too. But wouldn't act up when I took it to RotorSport Racing. Thought it might have been oil metering pump going out. Started pre-mixing gas, and hasn't done it since.
Old Jul 16, 2002 | 12:30 AM
rx4ur7's Avatar
in the diagnostic box connect TEN to GND, do this w/a paperclip, turn the key on(not the car) and count. short blinks of the check eng. light are 1 - 9 and long blinks are 10,20, 30, etc. up to 70
Old Jul 16, 2002 | 01:08 AM
grinn253's Avatar
Thanks a lot rx4ur7!!!!! Since you posted the instructions, i felt obliged to check right now.
The error code is:
5 long 1 short. (first showed 5 blinking semi-long, paused, then 1 quick short one)
51 right?
I'll be looking forward for your help, I'll also try to check if i can see what code that is myself.
Thanks!
Edgardo
Old Jul 17, 2002 | 01:17 AM
grinn253's Avatar
Okay i've looked up what error code 51 is:
"Fuel Pump Relay-open or short circuit"
Finally a clue to the problem! Any info available to assist in checking to see if the Fuel Pump Relay is busted or shorted?
Laters!
Edgardo
Old Jul 17, 2002 | 01:38 AM
rx4ur7's Avatar
thats correct. tomorrow when im at the shop ill go over the codes and get w/ you tomorrow i dont have my manuals here at home. if you have your own manual go to the page for troubleshooting code 51 and go from there, your welcome to call if you wish, #'s in info box,my name is chad
Old Nov 21, 2002 | 09:01 AM
r71's Avatar
r71
Identical Problem with a twist.
I have the same exact problem with a twist. The problem described and the ABS light coming on seems to alternate. After resetting the ECU, the ABS light comes on. The car runs fine for about a day or two. Then the above mentioned problem arises, but the ABS light goes off. I check the codes this morning, 51, fuel pump relay. I replaced it and reset the ecu. ABS light came back on. I'll post the results in a day or two. Anyone with this problem? Please post something. Thanks
Old Nov 21, 2002 | 08:23 PM
r71's Avatar
r71
Nope! It's telling me the fuel regulator is bad again. That damn code 51. I guess I have to check the relay. Anyone with this prob? My ABS light don't come on any more. This sux bad.
Old Apr 20, 2023 | 09:36 PM
simronrx7's Avatar
Any updates on fixing code 51?
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
Clacor
Sep 11, 2015 08:36 PM
t-von
Sep 10, 2015 01:56 PM
