Yet another n/a to turbo question..
Old Apr 21, 2002 | 08:42 PM
gold87na's Avatar
SRT-4 User
Talking Yet another n/a to turbo question..
(Yes i tried searching I found n/a & turbo war stories)
I'm going to be stripping a 87 T2 turbo, manifold, and injectors from a 87 at a junk yard. what else should i take? For a intercooler i'm going to look at the turbo saab's and turbo volvo's for a small front mount one. I am not going to rush into putting this on untill i have all the required parts. I did research and found that i can use a Safc to control the fuel curve using a T2 boost sensor. Lastly I'm only looking for a max of 8lbs boost (I would perfer 6lbs to be safe). Mainly looking to break my 200hp limit
Old Apr 21, 2002 | 09:09 PM
Bambam7's Avatar
I came, I saw, I boosted.
Ya.. You ONLY want to break 200hp.... that'll last about a day, then you'll want 250... trust me.
Anyways... as intercoolers go.... there isn't a small volvo one... it's HUGE, as in, lasrger than the stock radiator!!!
Now- I don't have first hand expereince with them, but I'd say on a mild turbo setup, with the stock turbo, you'd have way too much turbo lag.
Also- you have to do some crazy customizing to get it to fit- moving the radiator back, etc.
I am welding 2 TII corse together- it's easy and cheap.
What's even better is welding 2 1st gen talon/eclipse intercoolers. They have smaller cores, but are 4" thick!! They are usually pretty cheap too, but I could only find one...
Any machine shop will weld them together for you for very cheap.
Don't skimp out on intercooling- that's key to keeping safe boost on the N/A's high comp rotors.
There are 2 sizes of Saab intercoolers- 900 and 9000. The 900 is a side mount, it's a little smaller than the stock TII one. The 9000, again is massive- like the Volvo-probably hurt performance.
Get the fuel pump as well.
Don't forget the oil lines, and coolant lines- it makes it easier to fab the rest when you have most of the lines already.
If it's an 87 TII make sure the injector impedence matches your car- they changed 1/2way through 87.
If your car is low, and the turbo is high, then get the resistor block too- it's under/behind the passenger headlight area.
If your car is low, and they are high- then your car will have a resistor block- just bypass it to run high imp. injectors.
You won't be able to keep boost down that low if you have an exhaust/intake. You will probably need to port the wastegate to be safe with boost creep....
With a decent intercooler, and you arent leaning out with fuel , you can run 10psi without a worry!
You are aware you need to make a spacer plate too, for the turbo to clear the intake manifold- some fender thumping might be required too.
Don't forget about ding intercooler piping, and also, you need a new front exhaust... there's lots of little things.
Good luck! I'm knee deep in the same thing right now!
Hey- and where did you hear about the S-AFC hooked to the TII boost sensor??? I just thought of that today!!
Old Apr 21, 2002 | 10:22 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
GET THE WHOLE DRIVE TRAIN !!!!!
the NA drive train wont hold up to the inevitable upgrade to 250 or 300 HP. so do it right the first time and swap it all.
And really from having helped RX7_ragtop (brad one of the forum admins) swap out the NA tranny and rear end into his vert I have to agree unless its a conversion to a vert just get a T2. Unless you have lots of time and just wanna do it.
Old Apr 22, 2002 | 10:10 AM
gold87na's Avatar
SRT-4 User
Should I grab the BOV? If so where would i find it?
Old Apr 22, 2002 | 02:41 PM
Bambam7's Avatar
The BOV is internal to the turbo.
Mazda calls it a compressor bypass valve or something....
Old Apr 22, 2002 | 02:58 PM
Aaron Cake's Avatar
Engine, Not Motor
The NA drivetrain WILL hold up to the power of the turbo.
The BOV is not integral to the turbo, it is a seperate part...Either use the stock TII BOV (air bypass valve) or get an aftermarket unit.
You will certainly have to modify the inner fender...This will involve cutting a chunk out of the frame rail...I hope you can run a welder.
The stock TII intercooler can be front mounted with a few changes in the pipe...But a better intercooler should be easy to find (check eBay).
Any questions? I'm halfway through installing a TII turbo on my '86NA right now...
Old Apr 22, 2002 | 03:22 PM
Bambam7's Avatar
He's da man.
Old Apr 22, 2002 | 05:16 PM
gold87na's Avatar
SRT-4 User
o.k. so:
(from T2 in salvage yard)
Turbo unit (will get it rebuilt to factory spec)
Manifold
Intercooler
Fuel pump
Injectors
oil lines
pressure sensor
(new)
BOV
SAFC
Tubing for air ducts
My uncle (who will be doing most of the work) is a master welder (35+ years exp). He has combined meny crushed cars to make rather nice, drivable cars.
For cooling lines can i use the line that i took off of my thrmo wax? I don't know how much pressure that gives.
Old Apr 22, 2002 | 05:20 PM
gold87na's Avatar
SRT-4 User
next question. Should I get a wide-band O2 sensor and a a/f meter? If so how much and where can i find a wide o2 sensor? I think i can get a autometer a/f meter @ pep boyz for like $40.
Old Apr 22, 2002 | 05:23 PM
SonicRaT's Avatar
Super Raterhater
Grab the front cover while you're at it, then you won't have to drill holes in your NA cover for the oil lines.
Old Apr 22, 2002 | 06:53 PM
Brian P's Avatar
I just skipped most of the messages, but for anyone curious about the volvo ic its quite big, here's a picture of mine. It fits in nicely if you move the rad back a bit
Old Apr 22, 2002 | 06:58 PM
Felix Wankel's Avatar
Super Newbie
The return line is in the front cover. The supply comes off the front side housing.
Old Apr 22, 2002 | 07:04 PM
VtekEater's Avatar
Dont waste your money on that A/F gauge, they are garbage, get an exhaust temp gauge, they are more precise and will definitely give you more info on how lean your motor is running.
BTW The N/A drivetrain will hold up as long as you dont drop the clutch over 6,000 rpms all the time
Oh and heres a pic of a S4 turbo on a GXL http://www.geocities.com/alx954/turbopic1.jpg
I think your going to have to copy and paste this one.
Ogh and you do not nee to cut the frame at all, you just need to "massage" it a little with a big hammer, so that the stock wastegate will fit.
Old Apr 22, 2002 | 07:08 PM
Super Newbie
Originally posted by VtekEater
Dont waste your money on that A/F gauge, the are garbage, get an exhaust temp gauge, they are more precise and will definitely give you more info on how lean your motor is running.
Yeah I can't believe you want to spend all that cash on a wideband just to use a $40 AF gauge on it
That, and don't shift like a spastic monkey on crack, banging gears all the time. Shifting mAd QuIk Yo!= mad quick tranny replacement
Old Apr 22, 2002 | 07:11 PM
VtekEater's Avatar
LOL My friend shifts like a crack head in his GT-S all the time it funny
Old Apr 22, 2002 | 07:19 PM
Super Newbie
I see Hondas at the track doing that. Making their shitty intake sound along with *grind* *grind* *grind* of the synchros
Old Apr 22, 2002 | 07:56 PM
SonicRaT's Avatar
Super Raterhater
Wankel, that's what I meant, sorry for putting 'lines', but I meant the one that just bolts on near the lower passanger side.
Old Apr 22, 2002 | 09:29 PM
gold87na's Avatar
SRT-4 User
can I just get an oil feed from the oil cooler? or just the oil cooler lines?
exhaust gas temp? How much would that be? sounds more expensive already.
I was on ebay and was looking at intercoolers i seen 2 that looked good. The easier one to install looked like the 4-banger ford probe intercooler. I seen another one that was something like 30"x3"x2.5" with an inlet/outlet on each end, but it looked like a lot of tubing to get it working.
Isnt the idea to have the least ammount of tube (well just the shortest distance from filter all the way through to the manifold)?
Old Apr 23, 2002 | 12:01 PM
Aaron Cake's Avatar
Engine, Not Motor
Originally posted by gold87na
oil lines
You will need to modify the oil lines, but yes, you need them.
That will work just fine. In fact, the hose used there is exactly the same diameter that will connect up to the turbo's water lines....
VtekEater: I had to cut the frame of my car to make the wastegate fit as it interfered quite a bit. Also, there was no room to swing a big hammer.
Several hundred dollars. But if you are concerned about cost, you shouldn't be doing this project.
Yes.
Take my advice though. If you need to ask these questions, you don't have the necessary knowledge to do this project.
Old Apr 23, 2002 | 05:27 PM
gold87na's Avatar
SRT-4 User
I really do know most of this, I just want to make sure. I have (in the past) built high power V8's but now I'm tring to forget everything I learned for rotary knowledge
Old Apr 23, 2002 | 05:39 PM
Roy James's Avatar
My cars louder than yours
why dont you just get the motor and driveterrain off the TII in the J yard, or hell, buy the whole car, rebuild the motor (depending on the shape its in) and then swaping it in your car as a whole, that way you dont have to cut your frame or buy all these extra expensive parts, just be stock TII for right now, then later on really mod that peice. Just my two... ah **** it. keep us posted
Old Apr 23, 2002 | 06:17 PM
Aaron Cake's Avatar
Engine, Not Motor
Well, the reason I am doing this is because TIIs are super rare around here, I don't want to buy a TII, and I wanted something different (that "can't be done").
Old Apr 23, 2002 | 06:21 PM
Roy James's Avatar
I hear that man, if i were in your case i would do the same, hell, i was a few weeks away from starting my "N/A turbo" car when the motor blew, then i found a decent TII around AL i set my sights on getting. I was mainly asking "gold87na" because he found a TII in the yard, something i wish i could do. Have a nice day everyone.
Old Apr 23, 2002 | 06:23 PM
Im gonna do it as well. I already have a custom miata turbo install under my belt.
P.S. what do you guys think of the 00 VW TDI intercooler? I have a brand new one sitting in my room.
Old Apr 23, 2002 | 11:41 PM
gold87na's Avatar
SRT-4 User
Well it's a rather long storie.. Has to do with my parents. I live at home and my parents are sooo into the 'save your money' and if they know or find out that I am putting money into my car (in there eyes something "only" to get you where you need to go) I will be forced out and I can't pay for a apartment right now and i refuse to get another room-mate (and get ripped off again) so if my car looks the same and it doesn't take any nights away from home then they will never know.. (there not to mechanically inclined). Also I am only looking to get no more then 200rwhp and I don't drive like a maniac so I think the drivetrain would hold up. I never plan on going to a track or dyno (well I might have it dyno'd with a/f ratio after the turbo but mainly just to get it running with a stable a/f curve to be safe)
Question: I saw a Ford (F*cker Only Rolls Downhill) probe intercooler on e-bay has anyone ever tried fitting one in the nose? I think I can get it to fit with little moding but just wanted to see if anyone has tried one.
hotshot2014
Jul 18, 2017 02:30 PM
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
rxmiles
Aug 24, 2015 02:07 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
