Ford Diesel Turbos
Old Jan 7, 2002 | 08:08 PM
Jedon's Avatar
Slave2TheFD
Ford Diesel Turbos
There are a couple of sweet looking Garrett turbos on ebay for a good price but I can't find any more info than that it's a T04E. Anybody know anything more about these turbos like A/R etc?
http://cgi.ebay.com/ebaymotors/aw-cg...200008&r=0&t=0
Rebuilt Garrett Turbocharger for Ford Trucks 7.8L Engines - Garrett # T04E14 466290-1X {Original Ford # E8HZ-6K682-AX}.
Old Jan 7, 2002 | 08:40 PM
stinkfist's Avatar
Learn to swim.
Is there any reason that you wouldn't want this turbo on A RX-7? Is it the same TO4E that you would get from some aftermarket shop?
Mike
Old Jan 7, 2002 | 10:55 PM
HWO's Avatar
HWO
inteligent extratarestril
you'll just need to check the exhuast housing A/R size. everything else is all fine and dandy for the rx7
Old Jan 7, 2002 | 11:44 PM
mako's Avatar
a friend of mine bought one of these turbos. its pretty nice for the money. the a/r's were a .70 compressor and 1.00 on the exhaust turbine. with a p trim wheel. we took it to a local turbo shop and this one was the smaller t04e ford has a bigger one that has a bigger compressor wheel. but that one has like a 1.25 on the exhaust side.
James
Old Jan 7, 2002 | 11:55 PM
richjackson7's Avatar
cool i wonde how much ford directly charges
Old Jan 8, 2002 | 12:34 AM
Jedon's Avatar
Slave2TheFD
Well damn a .7 comp 1.0 A/R P-trim divided for $375 or so sounds great!
Old Jan 8, 2002 | 09:29 AM
Question
So are you saying that if you can get a turbo off of a power stroke ford truck it would work with no modifications, or few modifications? Just curious because I have just started looking for a single, not real sure what i want, but something in the to4e to apexi ballbearing range.
Old Jan 8, 2002 | 09:34 AM
Greg's Avatar
A turbo is a turbo. As long as the specs meet your requirements then go ahead and get it. Its sounds like a deal to me.
Old Jan 8, 2002 | 11:50 AM
InitialD FC's Avatar
If that is the bigger one (which is looks like it is) as Mako said the exhaust housing is huge, but its 1.32, not 1.25!!! But you really dont want to get it... Trust me...
Its a 57trim compressor wheel, it maxes out at just over 400hp... We ran one and would loose 5psi by redline. Dropped from 15 to 10!!! The compressor wheel cant flow the power for that size turbo for our motor.
Old Jan 8, 2002 | 01:07 PM
crispeed's Avatar
'Tuna'
The newer Ford Diesels run a much bigger turbo than the one above. They have internal wasgates too. Plus they spin backawards(anti clockwise) from coventional ones!
crispeed
87TII
9.20@150mph
Old Jan 9, 2002 | 01:06 PM
Gearhead's Avatar
I have a Powerstroke and have asked these same questions to no avail. The turbo is a TP-38. Mine has a 1.15A/R turbine and a 1.1A/R compressor. I believe the newer ones actually have a smaller turbine housing and a built in wastegate. Mine is non wastegated and puts about 20PSI to a 444 cu in. engine at around 2700 RPM so you can kinda know what the airflow is. Oh, and the powerstroke is a 7.3L not 7.8... so I'm kinda wary about what they know about their product.
Don.
Old Jan 9, 2002 | 01:12 PM
Jedon's Avatar
Slave2TheFD
I can't find reference to the Garret part number anywhere on the net, can we call Garret and ask them? Somebody must know for sure given a part number.
Old Jan 9, 2002 | 09:56 PM
peejay's Avatar
Old [Sch|F]ool
Loses pressure to 10psi at redline... hey perfect, no need for expensive wastegates and lots of midrange grunt
If you think $375 for a turbo is cheap, check out the intercoolers.... a P/S itercooler MIGHT fit under the hood of an FC if you took the engine out first and they only cost $200... now imagine buying one, cutting it in half, fabbing new end tanks, and selling one of the intercoolers for "only" $400 to a bud and keeping the other one for yourself!
Old Jan 9, 2002 | 11:28 PM
the intercooler from a 92 isuzu npr truck fits great BTw whats the flow rating on one of those.
Old Jan 10, 2002 | 12:17 AM
Gearhead's Avatar
Initial D, you must've gotten a different one. The specs on mine are different than that. Did you ever find any good info on those turbos? I could never find flow maps or anything. I have always liked to find wierd things like those to put on my RX7 cuz I used to be broke a$$. I am going to get a Freightliner intercooler and cut it and TIG the tanks for my next project. I know that some of these custom products offer some advantage... but I don't think all of them are worth that much more $$.
Don.
Old Jan 20, 2002 | 11:11 AM
HN's Avatar
HN
Gearhead, what year is your powerstroke? It seems your turbo's A/Rs are fine. is there a part number other than tp-38?
Old Jan 20, 2002 | 12:13 PM
Gearhead's Avatar
Ok. The turbo at the top of this page must be a Ford turbo from the Navistar (International) 466 or something. My '97 powerstroke has a A/R1.1 comp. and 1.15 turb. The part # is a 1825818C91. I don't know if that's Ford, Navistar, or Garrett (Allied Research). I'll try to find a pic to post 4 you guys. I just assumed that when someone is selling a Ford diesel turbo that it's a powerstroke. Because big rigs built by Ford are branded Sterling. Maybe it's an older Ford rig turbo. Mine also has a band clamp on the turbine. If I find one... I'm gonna buy it and try it.
Don.
Old Jan 20, 2002 | 03:14 PM
peejay's Avatar
Old [Sch|F]ool
Definitely not a Ford part number.. Ford part numbers are always a combination of letters and numbers that are like 4-4-4 and sometimes there's an -A or -B suffix. The first 4-digit "syllable" describes the year and model, so a part DESIGNED IN '97 would start with F7xx- etc. An E8HZ part number means it was first used in '88, and the Z means it's an "aftermarket" part - meaning it's a Ford Service part instead of one for a specific vehicle. At any rate it's HIGHLY unlikely that it's the same turbo as on your '97 Powerstroke. Like you said it's most likely from an industrial engine, I think Ford did make a 477cid industrial Diesel which would be 7.8 liters.
Old Jan 20, 2002 | 04:43 PM
Node's Avatar
hmmm Turbonetics T3 Garrett T4 TURBO ball bearing
http://cgi.ebay.com/ebaymotors/aw-cg...item=600592756
$285. Used but doesn't look in too bad of condition. E-Bay turbos, not bad.
"YOU ARE BIDDING ON A BRAND NEW GARRETT TURBOCHARGER. APPLICATION UNKNOWN. COMES WITH METAL GASKETS. IT WAS SEALED IN THE BAG, TOOK IT OUT FOR PICTURES ONLY. PART#465960-5003 MODEL#TO4B58 A/R .60 --A/R EXHAUST 1.00 SUPER CLEAN.
http://cgi.ebay.com/ebaymotors/aw-cg...item=600628337
Garrett T61 A/R 1.00
46 trim compressor wheel?!?!
http://cgi.ebay.com/ebaymotors/aw-cg...item=600399223
New Ford PowerStroke Intercooler
30"x18"x2" $225, $260 Buy It Now
http://cgi.ebay.com/ebaymotors/aw-cg...580125&r=0&t=0
There are a couple of these for sale
Used Isuzu NPR Intercooler
16"x13 1/2"x2 1/2" $150
http://cgi.ebay.com/ebaymotors/aw-cg...745137&r=0&t=0
Old Jan 20, 2002 | 06:45 PM
peejay's Avatar
Old [Sch|F]ool
HAHAHA $260 Buy it now!
You can go to your local Ford dealer and BUY IT NOW for less than $260!
Old Jan 21, 2002 | 09:12 AM
relvinnian's Avatar
Yeah lets just push the compressor to it's thermal limits, what a great idea!
Old Jan 21, 2002 | 09:44 AM
magnus's Avatar
Initial D is right they are not enough compressor for rx-7's we had one on our car for testing, all our other turbo's were getting rebuilt, best we could get was 11.4, on 1.4 60' not good enough, 300hp is about it.
Old Jan 22, 2002 | 10:30 AM
Gearhead's Avatar
I guess that whole counter clockwise thing would make it a little hard to get a different compressor wheel and housing. It's odd that it can only support 300HP on an RX7. I know of Powerstrokes making 400 HP with these turbos and about 800LB ft. I know it's different engines and fuels... The most common turbo upgrade on a powerstroke is a SMALLER exhaust housing to help it spool.
If the turbo that started this thread is different... actually a T04E then It could be a good deal. How would one go about finding more info on these?
Don.
Old Dec 24, 2002 | 01:50 PM
Gearhead's Avatar
Ok. I'm gonna try it. I found a Powerstroke turbo off of a '01 for $150 with the pedestal. I can sell the pedestal to someone... or if it won't work, I'll just put the turbo on my truck. Hell, it's quite a bit bigger than the turbo on my TII anyway. Surely it'll flow a little more. Any more info on this?
Don.
Old Dec 24, 2002 | 04:02 PM
Maxthe7man's Avatar
Freedoms worth a buck o'5
I have that turbo thats in the picture in the first post, I made 365 rwhp at 17 psi on a S4 motor..Max
