(BRAKES) BRAKE upgrade MUST READ!!!
The AUTO DOCTOR
on
This is kick ***!!!!! These guys offer a 2nd gen brake upgrade for 1st gens. I told them i was in the usa so i figure they know about the 4x110mm compared to the aust. 4x4.5. I was quoted about 800 us dollars plus shipping. If this is true I know what im doing!!!
http://www.selectmaz.com.au/main_frame.htm
click on the brackes section
Trending Topics
Admitted Sevenaholic
on
If you want the ultimate 1st gen coilovers, look no further than
http://www.gforceengineering.net
Direct link http://www.gforceengineering.net/advance_shocks.htm
Originally posted by Montrealer
Hmmm if those coilovers are for 1st gens, it might also be worth looking into.
on
Any updates on this?
Hey guys,
Has anyone heard an update on this yet? I'm really interested. I did send them an e-mail but, no response yet.
Thanks,
Bern
83GS turbo
Thanks,
Bern
83GS turbo
on
I too am still waiting guru sent me an email awhile back saying he would send more info soon. but that was to long ago
On the subject, anyone care to take a guess if a rear brake proportioning valve will work out ok for this mod? as i'm sure we will have a bit of change in braking abilities front to rear.
Learn to swim.
on
on
Thats nice, but when you wear down your brake rotors, you will need to have another cu$tom set made again. $$ouch$$
Speedturn has the better solution, using Wilwood parts. thus you only need to replace a common wilwood rotor.
a bit more expensive at startup, but worth it.
Originally posted by stinkfist
Or you can do it yourself.
http://www.mazspeed.com/4pistonbrakeconversion.htm
Mike
Mike
Are you Nucking Futs?
on
Aren't those suckers $400 a corner? Just for the struts? (not to say that any custom valved, rebuildable race shock wouldn't be pricey)
OUCH!
10.32 @ 133
on
I'm getting a 2nd Gen brake conversion done on my car by www.mrenforcer.com.au early next year. Drive in drive out with 12 inch discs is costing me $1250AUS
Right near Malloy
Location: Behind a workbench, repairing FC Electronics.
on
Don't forget the driver.
Originally posted by Powerslave
Brakes r fucked! they weigh alot and only slow u down!
I could loose 145 Lbs (65.77 Kg) of ballast from any car I drive by simply jumping out! Why didn't I ever think of that? :p
on
Tires? are you kidding me! those things weigh a TON!! I drive on the rims, much, much lighter, I just coat them with a thin coat of rubberized undercoating, works great, real sticky, and just reapply it when I get another gallon of gas
Originally posted by Pele
Fill your tires with Helium!
Warning, do not use Hydrogen!
Old [Sch|F]ool
The best way to upgrade the brakes, of course, is to make the car lighter.
The track scales were open on the final day of test-n-tune. My car weighs 2210lb, or 2400 with me in it. That's a good 250lb lighter than stock. Must be all the rust, erm, chemical lightening.
And it still has A/C!
Right near Malloy
on
