Pics from my rebuild
Old Jan 15, 2004 | 12:53 PM
93BlackFD's Avatar
built my own engine
As continued from this thread:
https://www.rx7club.com/forum/showth...hreadid=260332
and ultimately these threads:
https://www.rx7club.com/forum/showth...hreadid=260953
I've decied to build my own motor, and I just got some of my internals back from rick engman
i'll link all pictures as they're HUGE
budget
http://www.1131.net/pics/brian/DSCN1212.JPG
just picked up the engine from mazmart
http://www.1131.net/pics/brian/DSCN1238.JPG
all tools aquired
http://www.1131.net/pics/brian/DSCN1233.JPG
eccentric shaft was worn
http://www.1131.net/pics/brian/DSCN1210.JPG
after micropolishing
http://www.1131.net/pics/brian/DSCN1242.JPG
all bolts/front cover components polished
http://www.1131.net/pics/brian/DSCN1240.JPG
prepping the rotors and clearancing side seals
http://www.1131.net/pics/brian/DSCN1249.JPG
rotors assembled and side seals clearanced, new bearings installed, 2mm solid corner seals, rotary aviation 2mm apex seals (not shown)
http://www.1131.net/pics/brian/DSCN1250.JPG
right now gotham racing's steve kan is porting the plates, when i receive his permission and some final pictures, i will be posting those as well....
stay tuned for some pics of the powdercoated engine
Old Jan 15, 2004 | 03:19 PM
911GT2's Avatar
The Power of 1.3
Thats some serious internal blingage. Very nice!
I've never built an engine so excuse my ignorance, but why coat the rotor in petroleum jelly?
Old Jan 15, 2004 | 03:21 PM
93BlackFD's Avatar
built my own engine
well it serves two purposes, it keeps the seals in tact while you assemble the motor, it provides further lubrication on the initial start of the motor, and as you turn the motor over by hand
as soon as it hits oil/heat, it liquifies and burns off/joins the oiling system
i will use petroleum jelly and assembly lube (assembly lube is thick and stringy/sticky, and dissolves in oil as well)
Old Jan 15, 2004 | 03:25 PM
wow man much props have u rebuilt b 4? are u learning from manual???
Old Jan 15, 2004 | 03:39 PM
911GT2's Avatar
The Power of 1.3
Interesting. I wonder how many engines Dr. Wankel went through figuring out how to get everything to stay together as he assembled them. I'm just picturing this German guy working on an engine with all of his fingers on a different seal as he lowers the rotor onto the e-shaft. lol...
Old Jan 15, 2004 | 04:25 PM
93BlackFD's Avatar
built my own engine
http://www.mazda.com/history/rotary/
check out that site man, wankel never really got to play with the "high tech" rotaries we have...
and this is my first rebuild
Old Jan 15, 2004 | 07:03 PM
93BlackFD's Avatar
built my own engine
just got the pics in from gotham racing
Old Jan 15, 2004 | 07:12 PM
Gargamel's Avatar
What's he charge for just the bridge to be done?
Old Jan 15, 2004 | 07:13 PM
93BlackFD's Avatar
built my own engine
(817) 788-8726
call them up and ask
Old Jan 15, 2004 | 07:17 PM
Gargamel's Avatar
(817) 788-8726
That's too much work.
Old Jan 15, 2004 | 07:18 PM
93BlackFD's Avatar
built my own engine
i think it's about $750 for that type of port, exhaust and intake
Old Jan 15, 2004 | 07:39 PM
Gargamel's Avatar
Good lord......... you guys have too much scrilla. I'll just still with my baby jesus port.
Old Jan 15, 2004 | 07:41 PM
93BlackFD's Avatar
built my own engine
do the math on a catback and intake
how much horsepower do you get from that?
now do the math on my port job....
Old Jan 16, 2004 | 08:25 AM
3isacharm's Avatar
Car>woman
I'm going to go change my pants now. Damn I can't wait to get my car running!
Old Jan 16, 2004 | 08:29 AM
Gargamel's Avatar
I can't remember that far back.......
Old Jan 16, 2004 | 08:33 AM
3isacharm's Avatar
Car>woman
a lot
Old Jan 16, 2004 | 08:50 AM
vudoodoodoo's Avatar
Nice port job!
Old Jan 16, 2004 | 12:48 PM
jspecracer7's Avatar
1JZ powered
What type of corner seals are you using? More importantly, what brand? They look like the new Hurley design.
Old Jan 16, 2004 | 01:47 PM
93BlackFD's Avatar
built my own engine
i got them from atkins, solid 2mm corner seals
Old Jan 16, 2004 | 01:56 PM
Gargamel's Avatar
What new design? I didn't know you could change the design much on a corner seal. Either is a triangle or it's not.
Right?
Old Jan 16, 2004 | 02:02 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
This may be a dumb question so someone please slap me (or at least point me in the right direction)....
How does a bridgeport work differently form just a huge streetport?
Old Jan 16, 2004 | 02:07 PM
Gargamel's Avatar
See that thin port? It allows more air into the combustion chamber.
Old Jan 16, 2004 | 02:12 PM
1JZ powered
Right?
since when are corner seals TRIANGLES? Go to Hurley's site and you'll see what I mean about "design"
Old Jan 16, 2004 | 02:17 PM
1JZ powered
Yeah, I had to take a closer look. My stupid 15" monitor sucks bad. Does Steve Kan recommend solid 2mm corner seals?
Here's the hurley corner seal:
Old Jan 16, 2004 | 02:20 PM
93BlackFD's Avatar
built my own engine
i recommended solid corner seals to myself steve kan agreed
it's good practice to use them with bridges, the plugs found on OEM seals are likely to cause a problem
the downside is, they do not cushion hard blows to the apex seal and they put more wear on the side plates
