Antenna
Old Aug 9, 2003 | 12:40 AM
rescueranger's Avatar
Antenna
can anyone help me out here .. my antenna seems to be stuck .. is there anyway to disable it .. like a fuse specifically for the antenna .. or any step by step instructions on how to disable my antenna would be most helpful .. im having problems getting to the antenna itself .. perhaps a good site that has step by step instructions .. thanks in advanced
Old Aug 9, 2003 | 05:45 AM
rynberg's Avatar
You can always just pull the power lead to the antenna.
Or just replace it......
https://www.rx7club.com/forum/showth...hlight=antenna
All you have to do is use the search function. You should also get a factory service manual. Normally, you can download one for free from www.iluvmyrx7.com but that site is down right now.
Old Aug 9, 2003 | 08:12 AM
the_glass_man's Avatar
Will u do me a kindness?
Just get rid of the damn thing!
I'm in the process of shaving mine and painting my car.
I've got through 3 freaking antenna's on my 7's. What a dumb design, it always ends up breaking no matter what.
Plus the car looks like a RC car with the thing up.
Old Aug 9, 2003 | 09:37 AM
rajeevx7's Avatar
2 FD's since '98
i fixed my broken cable inside of it.
the antenna was stuck down, because the toothed cable was not pushing it out.
if that is the problem, pm me.
raj
Old Aug 9, 2003 | 04:08 PM
NorthwindHost's Avatar
is there anything you can pull out that will stop it from trying to pull it out?
Old Aug 9, 2003 | 10:47 PM
SleepR1's Avatar
Antenna replacement is easy...do a search...
Old Aug 10, 2003 | 12:35 AM
vel525's Avatar
Woo Hoo, It Runs!!
i just unplugged mine.
Old Aug 10, 2003 | 12:47 AM
Vel, when you unplugged did, did you unplug the whole setup at the back or is there something simpler
Old Aug 10, 2003 | 12:59 AM
Snook's Avatar
Tony Stewart Killer.
mine is shaved
there is another antenna in the rear glass so I get the same reception without it....
Old Aug 10, 2003 | 01:32 AM
I don't get the same reception, so thats a problem for me during nightly drives =P.
Old Aug 10, 2003 | 03:59 AM
i successfully unplugged my antenna power cable .. only took 10 minutes cause i had trouble figuring out how to get the wheel jack out .. thanks everyone for the help info
Directfreak
Interior / Exterior / Audio
Feb 3, 2002 11:17 PM
cjf
Feb 2, 2002 05:38 PM
