Stock ECU + MP with Perfect BOOST Control!
Old Jul 6, 2003 | 09:19 PM
shaun.sheldrake's Avatar
I have to start this with a huge vote of thanks to Damian Dela Huerta ... I got all the info I needed from this thread of his ... https://www.rx7club.com/forum/showth...astegate+pills
We've been working on this over the last couple of weeks in the Wellington Sunday FD-Kai workshop sessions ..
We decided to manufacture as buying something was looking too expensive down here in NZ for a short term (until Power FC) measure ..
Results are FANTASTIC .. boost is rock solid at .75 bar .. where it's currently set .. transition is much smoother than stock and much much faster .. boost pressure hardly drops at all .. and it sounds heaps better without the cat in there!!
Anyone want's to replicate this I can write you a shopping list of the bits you'll need!
Pics below of how it looks installed and one giving you an idea of how we put it together.
There's some mounting, polishing and general prettying up to be done but getting it working was the important part.
Relevant Mods: Racing Beat Inake, Fujitsabo CatBack, RES Midpipe with small resonator ... and Ball/Spring boost controller!
Old Jul 6, 2003 | 09:23 PM
.. next pic
Old Jul 6, 2003 | 09:28 PM
.. and another
Old Jul 6, 2003 | 09:30 PM
911GT2's Avatar
The Power of 1.3
Thats awesome, sounds really good for you seq. guys. But in my opinion, best way to avoid spikes is non-seq!
Old Jul 6, 2003 | 09:32 PM
.. last one, the components ..
Old Jul 7, 2003 | 09:28 PM
ludeowner's Avatar
Shaun or anybody else,
Does Shauns MBC work as well or better than the Hallman device?
Shauns results has caught my attention, and I want to try installing a Hallman device or replicate Shauns setup. I have a stock ECU, with HKS air filters and Apexi N1 currently installed. I want to install my M2 DP, but I am afraid of spikes.
Old Jul 7, 2003 | 10:06 PM
I can't say I've tried the Hallman to comment, but I'm getting identical results to what Damian described .. and total cost was only $38 NZ and a fun afternoon's working under the hood!
Old Sep 26, 2003 | 04:14 PM
jayk's Avatar
So whats involved in the installation? Can you post instructions/parts list?
Old Sep 26, 2003 | 04:26 PM
BoOsTin FD's Avatar
Powered by** Rotary
yeah, post instructions and shopping list, I'm interested
Old Sep 26, 2003 | 11:32 PM
bureau_c's Avatar
Unless I'm missing something...why aren't you suffering from boost creep? No boost controller will prevent it alone, and with the cat gone you should be creeping. Did you port your wastegate?
jds
Old Sep 26, 2003 | 11:39 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
If I understand correctly he still has the pre-cat. That could help.
Unless I am mistaken, but I don't see a downpipe on the list of mods
Old Sep 27, 2003 | 12:14 AM
Zoomspeed's Avatar
jds
Some cars dont get boost creep, even with full 3" from the turbo back. Why this is? I dont know, but I know its not a problem for some cars.
Old Sep 27, 2003 | 12:32 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
That's nuts. I know mine was SOLID with intake, efini y-pipe, SMIC, DP, Hi-flow and cat back... But I never got brave enough to go midpipe...
Have a friend that had just an intake and downpipe... Slapped on a exhaust and went to 15 on creep... NUTS.
Mines a 93, his a 94. Dunno the difference, but there HAS to be something!
But, you're right... Some cars don't creep. I would just take the precaution anyway... Cheaper than a rebuild!
Old Sep 27, 2003 | 12:37 AM
Zoomspeed's Avatar
Oh definatly get a boost controller for sure. I didn't mean to imply otherwsie lol.
Its just that not all cars will require the wastegate to be ported.
Old Sep 27, 2003 | 11:38 AM
the_saint's Avatar
I suspect it has to do with the turbos being able to flow more air than others (assuming the same intake/exhaust setup).
I had huge boost creep problems until I ported the wastegate ALOT. Since then it hasn't been a problem.
I can't imagine being able to control creep with the stock wastegate.
Oh well.
thesaint
Old Sep 29, 2003 | 12:07 AM
Zoomspeed's Avatar
are we getting a parts list?
Old Sep 29, 2003 | 09:46 AM
cruiser's Avatar
Could there be a small boost leak, preventing the car to get boost creep but still be able to boost to like 10psi. Everything above gets vented through the small boost leak source.
Could that be possible ?
Old Sep 29, 2003 | 10:43 AM
David Hu$tlerhoff's Avatar
i highly doubt that three persons that already run damians setup have the same kind of boost leak
Old Sep 29, 2003 | 10:55 AM
cruiser's Avatar
I'm just asking as I was only getting like 10-5-7 boost pattern. Then I installed intake, dp and ECU and now I get 12-8-12 - I think I have a leak somewhere and it must be pretty small to hold up the boost.
Old Sep 29, 2003 | 11:05 AM
memmi's Avatar
One reason why many dont get creep, I recon, is due to the altitude differences.
I've got no creep on an identical setup, except I've got a DP as well. I live in boulder at 5,500 ft. When I go on mtn cruses up to 9,800 ft the boost patern changes dramatically. I think altitude is the most ignored factor when people speak of modding on this forum. Turbo's really do behave differently up here!
Old Sep 29, 2003 | 12:15 PM
johnchabin's Avatar
Agreed. Most guys up here complain of turbo lag, too.
And a bigger drop at transition.
cristoDathird
28
May 30, 2019 08:47 PM
