K&N vs Bonez
K&N vs Bonez
i took a look at my stock filter this weekend, and its all fucked up, creatures storing seeds and **** in it! i figure what the hell i might as well just uprade it now. im debating between either the bonez cone filter, or the k&n one. theyre both about the same price, 120. i dont need to buy any other extra parts, it just bolts on the the existing connection right? does anyone have any input? stock 86 na sport by the way, i dont remember if thats in my sig or not. thanks.
http://www.mkiv.com/techarticles/filters_test/2/
I wouldn't consider the blitz even for my vacumm cleaner
youll need an adapbter to fit the cone on to your AFM i think HKS makes them
if you had a s5 then you would not need that extra part but because the AFM on s4 cars is square youll need an adapter to fit the cone filter to the AFM
Wow thanks for that link Ice! I just ordered an Apexi intake now for the T2 conversion I will be starting this coming weekend after I drive down and pickup my front clip!
I've been using a K&N on my 86 N/A for a long while and liked it, but there's no fooling a simple test like that!
Re: K&N vs Bonez
The important quote from that article: "It is questionable how accurate the original source of data is".
FYI, the proper test for an air filter is SAE J726.
Originally posted by Icemark
I wouldn't consider the bonz even for my vacumm cleaner
http://www.rx7.com/cgi-local/2catalog.cgi?cat=7&part=1
$5 K&N Crankcase Vent Filter (For RX-7 Air Pump)
$5-10 Various Mounting Hardware
$20 HKS Adapter for 86-88 RX-7
http://66.216.67.51/product.asp?0=214&1=319&3=553
$60-85 Total
Re: Re: K&N vs Bonez
Originally posted by Evil Aviator
I don't understand that statement. The Bonez intakes come with either an Apexi or K&N filter, which were the number 1 and 2 rated filters in that "test" you posted.
Trending Topics
I have a K&N on my 86 NA I like the looks of it, it was an easy install, all the adapters and parts were included and it came with a recharging kit. Made a huge diffrence powerwise as well.
Have the Bonez kit, liked the brackets and excellent instructions, but of course I am not very mechanically inclined. The Bonez kit is a bit pricey, and those with fab experience can make their own adapter and brackets fairly easily for less $$$
$30-50 K&N Universal Filter
$60-85 Total
I use a Bonez and have been very please with it. Looks alot like a K&N except the end is cone shaped toward the inside instead of just a flat end piece. I don't think RX7.com would sell a piece of crap though. I would hope they have higher standards than that.
Originally posted by Rx7Nub
You can buy the bracket's for the AFM off of ebay I think, and someone on the forums also sells them. I forget his name now though.
Good Transition (Smoothly goes from round to square)
Bad Transition (Large lip = lots of drag)
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419755041
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419779381
http://www.bnnauto.com/PIC/ebay/AD.jpg
No Transition (totally round, which also creates drag when the air hits the square AFM hole)
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419732784
http://images.channeladvisor.com/Sel...adapter_f1.jpg
ummm....sweet! do you know where i can get the vent filter, and mounting hardware?
http://www.rx7.com/pics/fc-bonez-intake5.jpg
Most K&N dealers will have the vent filters, and you can also use brands other than K&N. Some of the generic auto parts stores carry K&N products, and you can also order them through the mail or internet. I forgot the inside diameter of the air pump hose, so you may want to measure yours to make sure you get a vent filter with the correct vent diameter.
http://www.knfilters.com/images/cvfsb.jpg
Here are your K&N filter choices. Make sure you get one that fits under your hood and between the frame and other components. A lot of people accidentally get filters that are too long or too wide.
http://www.knfilters.com/universal/universal.htm
If all this sounds like a pain, then you can just pay the extra money for a kit. Some people don't like them, but kits do have their uses.
Skeese
65
Mar 28, 2017 03:30 PM
. Don't know about the filtration on it though
