What does this thing do ?!?
Old Jun 15, 2003 | 03:30 PM
apeiron
Alright,
Take a look at the picture I have provided. On the UIM, on the back left part of it there is a black thing connected to it... What is this and what is the purpose of it and can it be eliminated in the NON-SEQ, my question is because I have two UIM's one of them was sold w/ the car, and it already has this thing eliminated so Im trying to figure out what it is...
Old Jun 15, 2003 | 05:36 PM
Mikey's Avatar
i would say that is your throttle position sensor...i left mine on, but i could be wrong
Old Jun 15, 2003 | 05:39 PM
meddle's Avatar
Thats AWS isn't it? Installed all my BOP but I cannot remember what everything looks like.
Old Jun 15, 2003 | 07:32 PM
JONSKI's Avatar
5yr member, joined 2001
Mikey,
The TPS is on connected to the throttle body, not the UIM.
meddle,
His AWS is already blocked off.
It's the Idle Speed Control (ISC). It increases airflow at idle when your engine is under load (i.e. air conditioner, headlights, fans, etc.). It's detailed in a few pages of the FSM, starting on page F-81. The decision to eliminate is a matter of personal preference. Be sure to read the section in FSM before you make your final call. I left mine in.
Old Jun 15, 2003 | 08:43 PM
apeiron
what can the side effects be of removing this???
Thanks,
Greg
Ill check out my user manual when I get back, im on the highway right now, looking for an easy way out =)
Old Jun 15, 2003 | 08:45 PM
Resource's Avatar
Thanks,
Greg
I removed it from my car with no problems.
Old Jun 15, 2003 | 08:57 PM
RX-Racer's Avatar
Aoohh!!!
What advantage does it do for you?
Jp
Old Jun 15, 2003 | 08:58 PM
Mahjik's Avatar
Mr. Links
Thanks,
Greg
Depends on what ECU you are running. The stock ECU uses that to control the idle as Jonski said. If you have a programmable ECU, it should be a problem removing it. However, if you don't, you'll probably have some fun idling problems.
Old Jun 15, 2003 | 09:01 PM
Resource's Avatar
Jp
I'm running the power fc and don't need it anymore. I remove anything I don't need to clean things up.
ZacMan
Sep 19, 2015 09:20 PM
Tem120
Sep 7, 2015 09:53 AM
