Fixed the idle garbage!!!
Old Jun 14, 2003 | 04:34 PM
Fingers's Avatar
WOOOO FACKING HOOO!
Well today i got fed up. After starting the car up in the parking lot when hot, and almost shitting my pants, i figured enough is enough. Today i will fix the goddamn idle.
So i go home, armed with a 10mm, 12mm, philips, garden hose, WD40 and a large sledge for when things don't go my way.
Checked tps AGAIN -- perfect.
Start pulling all hoses off and inspecting them... perfect (except for the hose on the acv sticking straight up, its dried out and loose, not a good seal)
started checking TB plates and springs... seem good... secondary plates a lil sticky... wd40'd the actuator arm... much better.
So nothing so far has gone right. Until i start inspecting the tb and doing some logical thinking. Noticed a screw towards the back of the TB (with a spring on it)... points straight up, sitting on a cam (not sure which one, perhaps fast idle?). I decided to unscrew it a tad... what do you know... tps light goes out. So i adjust the tps a bit... back the other screw a bit more... adjust the tps again. Put everything back together....
OOOH LA-LA!!! MUCH better!!!! Better throttle response!!! Doesnt stumble like a drunken mule for the first 30 seconds... MUCH MUCH better. Took it for a rip.. MUCH better throttle response. Got the car really nice and hot... shut it off, started it again, idle goes up to 1200, and then back down to 750 PERFECTLY.
Moral of the story? I don't know what the **** that screw is, and i don't really care... but that peice of **** caused me hours and hours of diagnosing, and vacuum leak testing, when it was as simple as a misadjustment.
Now it's not completely perfect... it still SLIGHTLY and barely noticeably misfires upon decelleration... leading me to believe its still running a bit rich... but that's for next time, boys and girls!!! In the meantime, i'm goin to enjoy my sweetly purring kitten.
Thanks to everyone for their help, and if you're experiencing the same issue, go out and start facking around with your TB
Old Jun 14, 2003 | 04:47 PM
Fingers's Avatar
Here's the bitch.
Old Jun 14, 2003 | 06:30 PM
88IntegraLS's Avatar
Displacement > Boost
Oh yeah, a throttle body out of adjustment. Yes enjoy it and don't mess with the boost unless you want a one-rotor paint can shaker.
Old Jun 14, 2003 | 07:02 PM
jgrts20's Avatar
Who are you?
where exactly is that screw again, that might be my problem but mine runs better warmed up!! only accured when cold for first 30 sec or so!!
Old Jun 14, 2003 | 07:30 PM
Fingers's Avatar
Its right beside the dashpot on my 89 TII. You have an 86 GXL, so i wouldnt be surprised if that screw doesnt exist at all.
Either way, issue #3 is resolved. i just need to adjust it some more.
Does anyone have a good way of adjusting that screw? any factory specs that I have to follow? Car runs much better and revs much smoother now... but theres alot of room for improvement.
Old Jun 14, 2003 | 08:18 PM
Black13B's Avatar
In Full Autist Cosplay
good to hear you finally got it solved!
Old Jun 15, 2003 | 08:33 AM
Fingers's Avatar
Anybody?
Old Jun 15, 2003 | 10:45 AM
Josepi's Avatar
Despise Enmity
I'm going to go look at my car in a lil while, I have some of the FSM out there too...
Old Jun 15, 2003 | 11:26 AM
HAILERS's Avatar
HAILERS
Yes, the online fsm is available at http://www.iluvmyrx7.com download the FUEL section. Explicit instructions are there to adjust the fast idle screw, fast idle cam screw etc.
Sample: https://www.rx7club.com/forum/attach...postid=1416963
Old Jun 15, 2003 | 11:43 AM
live4boost's Avatar
AKA ShepFC3
Its called a fast idle cam screw, or maybe just fast idle screw. I ditched all the cold start crap, and its much better.
lol, I guess someone beat me to it.
Old Jun 15, 2003 | 11:45 AM
Fingers's Avatar
I thought the fast idle cam was located on the front of the tb? the screw i'm referring to is on the back of the tb, right beside the dashpot
Old Jun 15, 2003 | 04:05 PM
Fingers's Avatar
Anybody know what the screw is? Throttle body adjustment of some sort?
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Bauer778
Nov 4, 2015 04:42 PM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
