Maybe this is why i failed emissions?
Old Jun 2, 2003 | 07:08 PM
pip's Avatar
pip
the blackest incarnation
Yes thats duct tape on the wire and yes thats so much build up i cn pick it off in flakes. You guys think that maybe this ahd something to do with emissions problems?
Old Jun 2, 2003 | 07:21 PM
SDrotary's Avatar
The "Original SDRotary"
hey my name is pip, don't see that to often
Old Jun 2, 2003 | 07:45 PM
Psychoblue23's Avatar
minus the duct tape mine looked pretty similar. Had never been changed.
- James
Old Jun 2, 2003 | 07:49 PM
pip's Avatar
pip
Yeah thats my guess is that its 75k miles old, whats the average life of an o2 sensor? I think i remmeber reading somewhere 50k miles?
Old Jun 2, 2003 | 08:08 PM
rotary>piston's Avatar
I don't think the O2 sensor has anything to do with it. Mine had 150k miles on it when I passed with flying colors.
Is your new BOV plumbed back into the intake? If not you run extremely rich when you let off, and that might be it. You also have no air pump, which can be part of it.
Old Jun 2, 2003 | 08:13 PM
pip's Avatar
pip
Yeah I know its going to be tough to pass without an air pump but i also know that its possible, Im just hoping i wont have to invest in an safc quite yet to tune it back a little. As far as the bov being plumbed back into the intake what exactly do you mean by that?
Old Jun 2, 2003 | 08:17 PM
NZConvertible's Avatar
I'm a boost creep...
The O2 sensor is only used during light-load cruise to improve economy. Unless the emissions test involves a dyno run, it won't have any effect on the results.
It's worth replacing though, as I doubt your one is working at all. I'm running without one at the moment (waiting for a sensor boss to arrive to go on my new DP) and my fuel consumption has increased a bit.
Old Jun 2, 2003 | 08:23 PM
pip's Avatar
pip
Thats exactly what the emissions test is in this area. Its like a 10 min dyno run, they let it idle for a bit then take it up to 60mph and let it cruise for 60 seconds or something like that.
Old Jun 2, 2003 | 08:35 PM
Digi7ech's Avatar
I break Diff mounts
Arg. Emissions blows. That's what they do in AZ.
I gott a go for the first time in September. I'm hoping nothing is bad.
You guys think I'd pass with the CS Single?
Old Jun 2, 2003 | 08:36 PM
under full throttle the O2 sensor does nothing.
The stock BOV (or Air bypass valve ) blows back into the intake. The stock ECU is programmed to compensate for this, so it adds a bunch of fuel when you let off. If you vent to the atmosphere (like many aftermarket BOV's do) then the fuel still gets added, but the air isn't there for it to burn in.
I think if you can set it up temporarily so the BOV vents to the intake (after the AFM like the stock one does) then you may be able to pass.
Old Jun 2, 2003 | 08:45 PM
pip's Avatar
pip
Hmm very interesting idea, i think i should head over to home depot and see what i can find in the way of vacuum lines and whatever i can find to fit in the hole on the bov.
Old Jun 2, 2003 | 08:58 PM
In that case it would definitely pay to replace it. While cruising, the O2 sensor lets the ECU maintain stiochiometric mixtures, which results in fewer emissions as well as lower fuel consumption.
Old Jun 2, 2003 | 09:52 PM
j9fd3s's Avatar
Community Builder
also look at your air control valve, that is a key emissions part
mike
Old Jun 3, 2003 | 12:56 AM
pip's Avatar
pip
thx for the help guys i have my work cut out for me tomorrow
Old Jun 3, 2003 | 12:45 PM
HAILERS's Avatar
HAILERS
http://www.dot.wisconsin.gov/drivers....htm#Procedure
Old Jun 3, 2003 | 03:49 PM
turbocajun's Avatar
Talking
Run your gas tank low and dose her up with some ethanol from Home Depot. She will pass with flying colors, mine did in Illinois anyway.
Old Jun 3, 2003 | 04:20 PM
Steel's Avatar
I'm your huckleberry..
i always read how ethanol will make ya pass in a good way, but exactly how much do you use? I.e. do you mix it in with your gas, or do you wait until its damn near empty and run it straight?
Old Jun 4, 2003 | 10:32 PM
pip's Avatar
pip
yeah anyone got any specifics on using ethanol?
ls1swap
Jun 3, 2024 03:25 PM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
RedBaronII
Sep 20, 2015 11:29 AM
JP's 93 fd
Sep 16, 2015 01:12 PM
