fuel and temp sensor, share what wire?
Old May 11, 2003 | 05:31 PM
sneakyasian's Avatar
Question fuel and temp sensor, share what wire?
I've got a short somewhere... both my fuel and temp gauge run at about twice what they are. on cold starts, both shoot up to about double their real readings then when it gets warm they drop. (as if the gauge was disconnected). sometimes it runs just a little above the true readings. but they always do the same movements... is it in my gauge cluster? cold solder points? could it be in the ECU? can anyone help... this is the last problem I need to fix! really... until next week. thanks for any help.
Old May 11, 2003 | 07:55 PM
HAILERS's Avatar
HAILERS
They both share a voltage regulator inside the combination meter. And....see the wiring schematic in the 88 manual that is online. Look for METERS
Old May 12, 2003 | 01:32 AM
ok I searched for a while and couldn't find anything. where is the combination meter? could someone tell me where it is?
Old May 12, 2003 | 01:36 AM
ok I know what the combination meter is... duh.. sorry. is it bad? how do I tell if I've got to get a new one? can I just resolder it? the gauges still work just they read twice as much or 1 1/2 as much as they should.
Old May 12, 2003 | 07:07 AM
HAILERS's Avatar
HAILERS
Ask NZCONVERTIBLE or ICEMARK. They're electrical. I say it's toast.
dkwasherexd
May 27, 2017 04:51 AM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
eddierotary
Aug 16, 2015 04:12 PM
