what do you think of this compressor map
Old May 6, 2003 | 12:08 AM
87GTR's Avatar
just wanted to see what you guys think of this turbos map
Old May 6, 2003 | 12:11 AM
thats too small for my tastes i would overspin it easily... would spool quick but thats it. would make alot of heat
Old May 6, 2003 | 12:21 AM
87GTR's Avatar
this is what I have now, no that my car is hbp the boost on the to4 is dropping off. and so far my best dyno is 372
I want to be able to go over 500hp
Old May 6, 2003 | 12:33 AM
Marshall's Avatar
Actually that first one is bigger than a T04S and a little smaller than a T-66. Not a bad compressor at all. Which one is it?
Old May 6, 2003 | 11:14 AM
87GTR's Avatar
borg warner S300
Old May 6, 2003 | 12:45 PM
wtf? that's not too small at all. 500hp will be right in it's sweet spot.
Old May 6, 2003 | 01:49 PM
relvinnian's Avatar
I agree, it looks nice. Has a pretty broad efficiency range as well.
Old May 6, 2003 | 02:28 PM
AJatx's Avatar
Compressor efficiency drops off pretty steadily after 1 bar.
Assuming that 1 hp = 1 lbs/m, you'll be around 380hp in the 78% efficiency range (sweet spot).
However, you can MAX this turbo to mid-high 400hp on the flywheel at 2 bar of boost.
500hp to the wheels or flywheel? I seriously doubt you'll hit 500hp at the wheels with this turbo.
It shouldn't make tons of heat unless you push that turbo way out of it's efficiency range (< 75%).
Looks like a pretty good street n strip turbo.
I bet it would act great in an auto-x trac or small road track. An all around good turbo.
It's hard to tell spool characteristics without turbine information and the turbine housing spec.
J
Old May 6, 2003 | 02:53 PM
Marshall's Avatar
AJatx, do you mean 10hp = 1 lbs/min? This is a topic I brought up a little while ago and not many would touch it with a 10 foot pole. Considering our typical pressure levels (~2.0-2.5), it appeared than anything under a T-66 compressor was too small to be kept in its highest efficiency level for 400-450 rwhp.
Old May 6, 2003 | 03:06 PM
btwn, 50 to 58 lbs/min. he's still w/in 72-74% efficiency, this is still great efficiency. when choosing a compressor, the trick is to be to the right of peak efficiency. the drop off in efficiency isn't that great, but you'll get much better spool because the compressor is smaller. if you were to get a turbo that had peak efficiency at 60lbs/min., it would be huge and very laggy. at 500 crank hp this turbo will still be very happy and it'll offer much less lag than a bigger one. even 500whp isn't a problem as long as he keeps his backpressure and intake air temps under control.
Old May 6, 2003 | 03:20 PM
relvinnian's Avatar
Totally agree. I tend to look for anything over 67% efficiency when looking at peak airflow. As long as he has an efficient intercooler setup, charge temps will be fine.
Old May 6, 2003 | 10:25 PM
87GTR's Avatar
kewl I will let you guys know how this turbo does on my car. I should get it some time this week.
Old May 7, 2003 | 07:44 AM
87GTR: I`m going to use that turbo, its a Schwitzer(Borg&Warner)S300. Where did you get the compressor map?
Old May 7, 2003 | 10:26 AM
87GTR's Avatar
I went to a turbo shop in Dallas. I was planning on getting the GT4088 after they tracked down the part number they found the 4088 is not made any more.
but the Borg&Warner S300 was the direct replacement in there cross ref book.
so they had them fax us a compressor map. I already had a 4088 comp map and its almost the same. but the 4088 was a little larger.
here is the GT4088 comp map
http://www.limitengineering.com/catalog.pdf
its on page 21
Old May 7, 2003 | 08:51 PM
t-von's Avatar
Rotor Head Extreme
How in the hell do you guys read and comprehend that chart?
Old May 8, 2003 | 01:55 PM
JinXed's Avatar
For a basic explanation ...... Read it like it was a plateau map for geography class.. The smaller plateaus towards the middle are higher efficiency the very middle/top one being the most efficient. You want to size your turbo so that when you are at peak efficiency for the longest amount of time during your powerband. IE - your turbo is doing its best work when you want it to. Boot pressure in ATM is on the left (2 = 2atms) and compressor flow is on the right (Lbs/min) That number is basically how much air your turbo is moving/compressing in relation to your exhaust gases at a certain boost level. I *THINK* I got that right - somebody correct me if I'm wrong. -JinX
Oh yeah - so you figure out how much HP you want - then figure out how many lbs of boost you need to run to get there and find a turbo that is at peak efficiency for that boost level. Talk to Kenku for a more detailed explanation - he has a much better grasp than I do. (So do other people on this board, I just happen to know him personally)
Old May 8, 2003 | 03:39 PM
Marshall's Avatar
Close but 2 on the left axis = 14.7psi (rather than 29.4) of boost since its a ratio.
Old May 8, 2003 | 04:25 PM
JinXed's Avatar
Thanks! -JinX
Old May 11, 2003 | 03:37 PM
Cool
Here is a picture of my S300, it has a capacity of about 700hp(flywheel).
Old May 12, 2003 | 12:40 AM
87GTR's Avatar
here is a few pics of my S300
http://www.teamfc3s.org/forum/showth...threadid=13243
http://rx7.cyberosity.com/87GTR/pics/2003/05102003/
Old May 12, 2003 | 12:55 AM
87GTR's Avatar
wankelman
do you have your car up and running? IM going to be installing the S300 tomorrow. getting a downpipe made for it.
Old May 12, 2003 | 04:01 AM
Originally posted by 87GTR
wankelman
No, its not running yet. But I hope it will soon
What manifold are you going to use, and what A/R do you have on the compressor and turbine?
Old May 16, 2003 | 03:03 AM
BDC's Avatar
BDC
BDC Motorsports
We've got the BorgWarner S300 running on 87GTR's car. Fortunately, the compressor is kick butt. Unfortunately, the turbine housing is too large in both of our opinions. We opted for the 1.15 A/R but I'm unsure of the actual dimensions of the turbine. Even using two bridgeport cuts in the outer end plates on the motor, it's still taking too long to get moving. It's equivalent to a 5500rpm to 8500rpm power-band like on a high-powered race car only and leaves little to be desired on the street.
Hopefully, we can find a different turbine setup for this and go to one trim size smaller.
We managed to get the turbo to fit nicely in the engine bay with a couple of spacers here and there. We had the exhaust made today and used a 4" to 3" reducer and it worked pretty well. But, at the end of the day, it gets into boost too late in the RPM band. We're going to find out what options we have tomorrow.
Updates soon.
B
Old May 16, 2003 | 04:09 AM
I have A/R 0.98 and Q-trim on the turbine, I think it will spool quite fast! What do you guys think?
Old May 16, 2003 | 11:27 AM
87GTR's Avatar
the smallest a/r on the turbine I can find is a 1.15
