Questions on S4 engine in FB..
Old Apr 16, 2003 | 06:24 PM
Rxmfn7's Avatar
Do a barrel roll!
Ok, so my friend may be buying a 84 GSL-SE, with a blown coolant seal. We're going to look at it tomorrow. Anyway, Im getting a 87 GXL as a parts car, with a good running engine. I just wanted to know if there is anything abnormal or special about swapping the engines that I will need to know?? Will the entire FC wiring harness be needed?? IM assuming the FC ECU will need to be used, but anything else I will need to look out for? I am using the entire FC engine, intake manifolds, everything. Thanks..
Old Apr 16, 2003 | 06:29 PM
Icemark's Avatar
Thought the motor mounts on the engines were radically different, between a S3 and S4
Old Apr 16, 2003 | 06:31 PM
Dan H's Avatar
Zoom Zoom Boom!
Try a search in the FB forums, I think I saw a write up about it.
Old Apr 16, 2003 | 07:06 PM
Rxmfn7's Avatar
Do a barrel roll!
See Im really not sure, alls that I know is that Ive seen a few people's sigs that have FBs with S4 engines in them. Ill try in the 1st gen section, maybe Ill have more luck there, thanks.
Old Apr 16, 2003 | 07:09 PM
spunks's Avatar
The motor mounts and the front cover are different and I think the oil pan too.
Old Apr 16, 2003 | 11:09 PM
pillage6's Avatar
Whatever you do, reinforce your ground wires and add some.
I have a 13bt in my 84 gs and I don't know if some grounds were missing or what, but when I added some, it made a huge difference.
Search for my latest posts, I posted some pics earlier this week on grounding stuff.
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
