S4 & S5 AFM swap ??
Old Apr 16, 2003 | 01:14 PM
S4 & S5 AFM swap ??
Anyone know if a S4 & S5 AFM are interchangable? Just trying to get rid of the huge *** restrictive metal can on my intake without going to a stand alone.
Thanks,
Jason
Old Apr 16, 2003 | 01:18 PM
I dont know the difference between the s4 and s5 AFM but I would just like to know how to bypass the damn thing without buying a modified ECU? I hate it! Its put me through so much agony. -Evan
Old Apr 16, 2003 | 01:20 PM
bcty's Avatar
Boost This!
yes you can swap them out i forget how though
Old Apr 16, 2003 | 02:44 PM
600HP CLUB's Avatar
s5 afm is more restrictive, they made it because it was cheaper to build not because it has anything to do with performance.
Old Apr 16, 2003 | 02:45 PM
NZConvertible's Avatar
I'm a boost creep...
This is a waste of time as the S5 AFM is just as restrictive as the S4 one, plus it's highly likely that it will have unknown effects on you're mixtures. Don't bother.
Old Apr 16, 2003 | 07:38 PM
I appreciate the input. I guess the only way is get a stand alone then. I'll just keep the Titanic on the car in case I decide to go deep water fording. Just hope I don't run into any icebergs.
Hey GTIguy, did you get your ride up and running?
Old Apr 17, 2003 | 03:46 AM
This image shows how to disable the fuel pump cut-off switch? this is exactly what I need! To do this do I soldier the 2 very left terminals together? Please let me know thanks.
Just for the record... When the AFM is faulty it DOES cause improper air/fuel ratios, and will also shut down the car if its not grounded correctly.
Old Apr 17, 2003 | 05:51 AM
silverrotor's Avatar
Jason, this may help additionally https://www.rx7club.com/forum/showth...highlight=wire
Old Apr 17, 2003 | 11:41 AM
Thanks Silverrotor. Now that that nonsense is out of my mind. I can think of more important things like relocating the battery and getting one of those highly praised and talked about S6 Alt with the dual pulleys
Jason
Old Apr 17, 2003 | 12:54 PM
hmm i coulda sworn that was a upgrade. guess not!
R.O.D
34
Jan 6, 2016 12:09 AM
Wehavetocook
Sep 23, 2015 11:04 PM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
