How to get cold air to the turbo (minor cutting may be ok if it's safe)
Old Apr 14, 2003 | 06:46 PM
Barwick's Avatar
SCCA Rookie
I've got a cone filter and want to put a cold air box, but really, that stock intake going to the box won't do much.. and I've already removed the stock fog lights (they suck).. so basically, I've got a BIG open area (with the FTP lens removed and the fog lights gone) to suck cold air from. Ideally I'd LOVE to put the cone filter right down in there, with maybe a shield in front of it to prevent driving rain from being sucked up.
Any ideas on how I can get into there? I'll probably make an aluminum sheeting box (cold air box) at least, or ideally maybe even make a whole cold air intake system, going straight into that big gigundo hole. Or maybe even worst case, I can make a non-cylindrical "pipe" that goes through somewhere into that area, to gather up some air.
So.. I'm looking for ideas.. I know one guy moved his radiator back and did some custom work.. it looked cool, but that's not an option for me.. I'm gonig 3 rotor eventually.
Old Apr 14, 2003 | 07:02 PM
dr0x's Avatar
pei > caek
Just buy some prebent pipe and cut it to the lengths you need to get the filter down there. And you are probably talking about Scott, www.1300cc.com You can do something similar to that pretty easily.
Old Apr 14, 2003 | 07:55 PM
Barwick's Avatar
SCCA Rookie
There's not much "area" there to work with though..
Old Apr 14, 2003 | 08:40 PM
dr0x's Avatar
pei > caek
Pull the top of the radiator back 3 inchs. Its really really easy and doesnt take up much more room.
Old Apr 14, 2003 | 10:58 PM
Barwick's Avatar
SCCA Rookie
do you have any more info on this? It sounds like something that isn't exactly easy to do, nor recommended.. but if there's more info, I'll listen.
Old Apr 14, 2003 | 11:06 PM
Felix Wankel's Avatar
Super Newbie
If you can live without your windshield washers, pull the reservoir out and cut a hole in the fenderwell there. Then use a mandrel bend to go into the hole and stick the cone onthe end. It will wind up in the fog light hole.
Just a suggestion.
Old Apr 14, 2003 | 11:07 PM
AreExSeven's Avatar
Huh?
Build a bracket that puts 3 inches between the radiator and the original bracket. Then attach the radiator to that. You can run a pipe through the gap in front of the radiator.
Old Apr 14, 2003 | 11:21 PM
Scott 89t2's Avatar
SOLD THE RX-7!
you can remove the washer bottle and run a pipe down there infront of the wheel
Old Apr 14, 2003 | 11:27 PM
vosko's Avatar
Just Call Me Terminator!
scott what is going on with your S5 ? it has a S4 water neck too!!!!! man... canada cars are WEIRD!
Old Apr 14, 2003 | 11:42 PM
AreExSeven's Avatar
Huh?
Thats K2RD radiator.
Aftermarket.
Old Apr 14, 2003 | 11:46 PM
vosko's Avatar
did you even read what i posted?
i am talking about the waterneck where the rad cap goes. its metal S5 are plastic... i have worked on enough S5's to have memorized how its supposed to look
Old Apr 14, 2003 | 11:50 PM
AreExSeven's Avatar
Huh?
lol, i read, but didnt think.
I thought u meant radiator fill neck thingy. nm me then
Old Apr 14, 2003 | 11:58 PM
BlackRx7's Avatar
Daily Domestic Killer
bump I don't think thats scotts engine bay his cold air intake is in front of his FMIC....if youcan find my engine bay pics thats basically how mine is.. and when Idrive on the free way and come to a stop and feel my TID it's nice and cold!!!
here it is..
Old Apr 15, 2003 | 12:07 AM
vosko's Avatar
that is def scott's engine bay look at the intercooler pipe
Old Apr 15, 2003 | 12:13 AM
Scott 89t2's Avatar
SOLD THE RX-7!
LOL that is BDC's car
Old Apr 15, 2003 | 09:03 AM
Super Newbie
Yet you don't see the TO4B comp housing
Old Apr 15, 2003 | 09:09 AM
Barwick's Avatar
SCCA Rookie
that's a great idea.. I'll relocate the washer fluid bottle to "elsewhere".. I dunno where, but I will..
It just requires removal of the bumper.. how hard is that? Anyone have a writeup? My stupid manual sucks hardcore.. instructions "Remove bumper by removing screws.. installation is reverse of removal"
Old Apr 15, 2003 | 09:39 AM
2a+RoN's Avatar
its not too hard, but quite tedious. You have to get in b/w the fender and the wheel and reach through to get I think 4 bolts from each side. So you have to take off the fender liners to do this part. There are some other easier bolts to get to right on top along the bumper. Its pretty straight foreward.
Old Apr 15, 2003 | 12:16 PM
vosko's Avatar
oooops. i'll shut up now. it was late
Old Apr 15, 2003 | 12:46 PM
Super Newbie
It sucks if the studs are rusted on the nose piece, they'll break off easy.
I think you can get the reservoir off just by pulling the fender liner out, but I can't remember.
Engine Management Forum
11
Nov 9, 2015 01:15 PM
20B Forum
Aug 19, 2015 01:47 PM
Wolf_
Aug 11, 2015 04:23 PM
