low/no cost items to tacke while engine is out
Old Apr 9, 2003 | 05:40 PM
BigRed's Avatar
hey,
my engine is toast, and I'm getting a mazda reman on friday or monday. is there any low/no cost items I should tackle while the engine is out? so far all I've got is:
port the wastegate
thanks,
-Greg
Old Apr 9, 2003 | 05:55 PM
apeiron
hmmm.... ps dampener, fuel lines, vaccume lines, coolant lines, dunno... I had a similar post up afew weeks ago
-greg
Old Apr 9, 2003 | 06:05 PM
BigRed's Avatar
hey thanks greg,
can you link me to it greg?
thanks
-Greg
Old Apr 9, 2003 | 06:09 PM
neofreak's Avatar
accept no imitations™
What happened?
-not greg
Old Apr 9, 2003 | 06:10 PM
BigRed's Avatar
Neovosh broke my car.
j/k. he was taking my car to HIN, when the engine blew. said he wasn't doing anything crazy and I belive him.
Old Apr 9, 2003 | 06:31 PM
alwan16's Avatar
here is my list of stuff i bought. these include coolant hoses and some other random stuff. not all this stuff needs to be replaced though.... although it costs money get a light flywheel while you are at it.
Motor Mounts Left FD31-39-050B
Right FD01-39-040D
Spark Plugs Leading 0000-18-N3A2
Trailing 0000-18-N3A1
Radiator Hoses Upper N3A1-15-186B
Lower N3A1-15-185B
Bypass Hoses Turbo to Radiator N3A1-13-5360
Water Pump Housing to Turbo N3A1-13-54X0
Rear Housing to Throttle Body N3A1-13-681A
Pipe to Throttle Body N3A1-13-691A
Lower Radiator to Tank N3A1-15-184A
Heater Hose Connector Pipe to Heater Core (right) FD01-61-211A
Pipe to Heater Core (left) FD01-61-212A
Pipe to Radiator FD01-61-214B
Engine to Pipe FD01-61-213B
Hose End Disconnect B455-61-240A
UIM Gasket N3A1-13-112
LIM Gasket
Injector O-Rings and Grommets O-Rings Small NF01-13-ZG3
O-Rings Big NF01-13-ZG4
O-Rings N3A1-13-ZG3
O-Ring 8574-13-253
O-Rings 9954-10-1252
O-Ring N253-13-282
Injector Insulators NF01-13-257A
Injector Insulators N3A1-13-257
Fuel Pressure Regulator N3A1-13-280
Fuel Pulsation Dampener N3A2-20-180
Fuel Filter N3A1-13-480
Fuel Hose N3A1-13-496
Fuel Hose 9935-90-814
Fuel Hose Protector N326-13-428A
OMP O-Ring N350-14-604
Oil Filter Housing O-Rings (4) 9954-10-1601
Oil Filter
Old Apr 9, 2003 | 06:53 PM
Mahjik's Avatar
Mr. Links
Clean and repaint your engine bay.
Old Apr 9, 2003 | 07:20 PM
vudoodoodoo's Avatar
Clean and polish some stuff.
Old Apr 14, 2003 | 06:15 PM
spurvo's Avatar
don't race, don't need to
Hey Alwan: You didn't replace the air bleed sockets themselves, right? Just the insulators? Parts:
I'm just curious as I am replacing the air bleed sockets during my upcoming rebuild, and Ray from Malloy is saying that these insulators come with the sockets when you buy them. Just curious...
Old Apr 14, 2003 | 06:34 PM
GoRacer's Avatar
Speed Mach Go Go Go
Wiring to air pump and and other wiring that will get brittle and break. Cover it with heat shrink and/or run it through a silicone hose.
Old Apr 15, 2003 | 12:31 AM
911GT2's Avatar
The Power of 1.3
Stand in the engine bay, and close the hood, take pictures.
Bet people you can get under the hood of an FD, with it closed, and then show them the pictures.
Use the money to buy stuff to put in while the engine is out.
Old Apr 15, 2003 | 01:14 AM
alwan16's Avatar
i think i just replaced the insulators but did not replace the air bleed sockets because i definitely did not buy those. i just went through the parts diagram looking for parts to replace and checked their stock level and price with mazda motorsports. my list of replaced parts is actually a lot longer than what i listed. if ray from malloy says it is included i would trust him. he seems to know his stuff and is a real nice guy to deal with. he won't bs you.
Old Apr 15, 2003 | 01:25 AM
Scrub's Avatar
bow leggin'
Clean the grit off the firewall. Get all the parts that'd you'd want polished. Vacuum hose job if it needs it. If you have any dreams of going with braided lines or a custom fuel system, etc,....do those. Flywheel switch if it interests you. Pully kit install can be easier to have done before each of the accessories goes back in. Plugs and wires. Ground kit. Heat wrap things if you want. Replace anything that was cracked, broken, or brittle- solenoids, hoses, wire looms, etc. Change out all the gaskets that have been removed during disassembly. Having the engine bay repainted could be a good idea if there are exposed portions- rust prevention. Check you oil cooler(s), turbos, or whatever else you can't really get to without taking things off. Upgrade as much as you want to save you a hassle later.
fjwheeler
22
Jan 9, 2022 01:02 PM
MoTeC
Sep 10, 2015 07:58 PM
