Anyone ever try re-using a dented rotor?
Old Mar 25, 2003 | 09:46 AM
Resource's Avatar
After having much fun at the track saturday I broke a seal here and there and put a nice dent in my rear rotor. The rotor isn't cut/scraped or anything it just has a nice dent in it from detonation. Anyways I know that it's going to lower the compression a bit but has anyone ever re-used one of these suckers or will I have a weeble wobble rotor?
:Team Wigger Rigged
Old Mar 25, 2003 | 09:56 AM
zyounker's Avatar
root
No don't use it.. The rotor will not be balanced right..
-Zach
Old Mar 25, 2003 | 02:20 PM
Tom93R1's Avatar
gross polluter
If you pull the whole thing apart to re-build it why not just replace it? I imagine a used rotor wouldnt be too expensive to find, especially after all the other gaskets and seals you still need to buy any ways.
Old Mar 25, 2003 | 04:29 PM
Scalliwag's Avatar
WingmaN
If you could put the same size dent in the same place on each side of the rotor it would be balanced again
I'm sorry it's been a long day though.
They are right, don't use it unless you make a clock out of it or something.
Old Mar 25, 2003 | 04:38 PM
peejay's Avatar
Old [Sch|F]ool
Balance shouldn't be THAT far off, what would worry me would be the compression inconsistencies from the dented face vs. the non dented faces, and when it dented the face what did it do to the rest of the rotor - did it pull the sides in, did it pull the apex slot opened more?
I'd scrap it, or make a pretty little doorstop out of it.
Old Mar 25, 2003 | 05:19 PM
lane_change's Avatar
It has begun
I'll give you $10 for it Eric....if you want to get rid of it.
Old Mar 25, 2003 | 05:52 PM
Resource's Avatar
I think I'll just have it gold plated and keep it on my dashboard
Anyone have a good 93+ rotor for sale?
Old Mar 25, 2003 | 06:15 PM
It has begun
That will add weight...you might as well sell it to me.
Old Mar 25, 2003 | 07:42 PM
Resource's Avatar
I've got other extra rotors laying arund that I'll sell you.
Old Mar 25, 2003 | 07:50 PM
88IntegraLS's Avatar
Displacement > Boost
I have a dented rotor that I am going to make into a clock. I bought a replacement (used) rotor in near perfect condition which will take its place in the engine. But my car is a (financially speaking) lowly S4 NA FC, he he he.
Old Mar 25, 2003 | 08:16 PM
Orange!FD's Avatar
I think you should put it back into the rebuild, just to answer this question once and for all.
Old Mar 25, 2003 | 08:17 PM
Resource's Avatar
Double dog dare me?
Old Mar 26, 2003 | 12:35 AM
Manolis_D's Avatar
Triple dog dare you
Old Mar 26, 2003 | 06:28 AM
rxrotary2_7's Avatar
i too would scrap it. but peejay, the placement of the dent would actualy cause the chance for compression inconsistencies no? if it was not in the dish... would it change? i dont think it would.
resource:
so i guess your *i'll have it back together and at the track on tuesday" statement was a little off.
Old Mar 26, 2003 | 10:00 AM
Resource's Avatar
resource:
Yeah, this whole dented rotor thing threw me off. I'm now on the lookout for a nice used rotor. Anyone know how much mazda charged for a rotor?
Old Mar 27, 2003 | 12:35 PM
peejay's Avatar
Old [Sch|F]ool
Doesn't matter where it is. Increased "clearance volume" (or the rotary equivalent) means decresed compression ratio, no matter where it is.
Old Mar 27, 2003 | 02:36 PM
es's Avatar
es
If you're buying new from Mazda you better buy a set as they have increased the side clearance for higher boost & RPM applications.
Old Mar 27, 2003 | 03:29 PM
Resource's Avatar
I have an extra rotor that I forgot about, no worries here
Old Apr 1, 2003 | 02:17 PM
InitialD FC's Avatar
Re: Anyone ever try re-using a dented rotor?
:Team Wigger Rigged
Well i guess you thought it was ok when you sent me 2 seriously dented rotors and a scraped up housing... You can go ahead and send my money back and ill give you the rotors and housing for your motor.
Old Apr 1, 2003 | 03:26 PM
TonyTurboII's Avatar
Glock Lover
Ouch sucka.
Old Apr 1, 2003 | 04:36 PM
DAMN!!
Old Apr 6, 2003 | 12:32 PM
I'll take that as a no?
Old Apr 7, 2003 | 07:41 AM
i highly doubt he will respond to that. we can keep pushing it to the top though.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
BLK 93
11
Sep 9, 2015 10:56 AM
