The real output of a Gen 1
Apprentice Guru
The forum frequently has threads showing dyno results when a member is boasting/proud of the power of their highly modified and unique RX-7. Its rare to get data on a typical stock set-up.
I was very interested to see the results of a recent dyno day run by the South Australian rotary club, a set of typical enthusiasts. The summary results were posted on their website.
A total of 14 gen 1s were put over the dyno.
There were 8 relatively stock and their rwhp was
56, 62, 62, 65, 66, 71, 72, and 75
Even in stock form with people who are RX7 enthusiasts the variation is remakable. Ex-factory it would have been 70-72rwhp a 28% drop in power from the flywheel reading. These are all the Australian version which had slightly more power than the USA version.
There were 6 modified gen1s and their rwhp was
80, 87, 90, 90, 105, and 135
The 105hp was for a Gen 1 with a 13bt engine which is way down on what I would have expected, a new gen 2 with the 1987 13bt engine gave 128-131 rwhp.
The results for gen 2s with the 13bt were just as varied everthing from 90 [must have been really badly tuned] to a 168hp for a moderately modified 13bt.
As these results were obtained on an accurately calibrated dyno, on the same day and with the same weather conditions, I believe they are a true representation of RX-7 performance. It would be great to get the results from another club dyno day.
It's fine to examine the relative differences among the cars, but your (actual and implied) inferences regarding absolute numbers and drivetrain power losses (comparison to Mazda quoted figures) are not relevant in my opinion.
The type of dyno used can have dramatic results on the scale of the power figures, as can the other variables inputted on the particular day by the dyno operator. I don't think it is appropriate to speculate on driveline losses given only that info above.
Personally, I think the interesting thing above is the variation among 'stock' cars, but that's about as far as you can take it.
Apprentice Guru
I agree its the substantial variation between cars that is the main interest.
Many dynos, especially those of tuners, are optimistic so the absolute figure is subject to a level of scale variation. However, the only figure I gave for driveline loss was for factory data relating to new cars.
A calibration error would have a 2 1/2 error impact on powertrain accuracy but for the average person all they get is rwhp while the factory normally only quotes flywheel hp. Its the same problem as the difference between implication and inference!.
Apprentice Guru
smnc, all the 12a powered RX-7s sold in North America were rated 100-101 SAE bhp at the flywheel, the rwhp rating was much less due to powertrain loss. The Australian version had bigger ports and gave some 110hp at the flywheel
Trending Topics
So mine is making a bit over 500hp (Dyno dynamics) to the back wheels now, so thats around a 400% increase in power over standard? Or is my maths wrong?
Either way...
I wonder what the person who designed the first generation 7s would say if they saw mine, or Directs or HITmans car....that would be funny
Either way...
Originally posted by thorin
56hp... ouch.
56hp... ouch.
-Error
Well, i believe AUS dynos are not comparable to US Dynos. So 56RWHP would be close to 70RWHP on a US dyno. Which seems about right..
That also means the ones making 72&75RWHP are pretty strong engines.
-Zach
-Zach
I doubt that the Aussie dynos are setup to read exactly like US dynos. What brand/model of dyno where you on?
I've also always heard that drivetrain loss should be 15-20%, depending on drivetrain configuration.
As the knights rally to defend the 12A's honor...
Seriously, those numbers DO seem a little lower than one would expect.
Maybe they just build lousy motors in So. Australia. (j/k!)
Don't the pre-'76 12As have larger stock ports than the RX7 12As? -WG
Here's where I came up with 101 rwhp...
I really should read things more carefully...
At least it all makes sense now...
https://www.rx7club.com/forum/showth...ock+horsepower
Apprentice Guru
The data given by Nota V6 was that a stock gsl-se gave 101rwhp, but that is a 13b not a 12a. Using his results against the factory flywheel data gives a powertrain loss of some 26%.
According to Revhed in another thread, there is a slight difference in dyno calibration with the USA ones giving a higher reading.
I originally started this thread because it was the first set of figures I have seen for over 20 rotaries made at the same time. My surpise was the wide variation between similar set up cars. Absolute hp was of seondary interest as was powetrain loss [22-28%???]
In my case I am trying to get the best spread of torque rather than peak horsepower, as this is what gives you performance on the road. Its the view of a person brought up on European rally cars rather than on American 1/4 mile drag cars.
Nikki-Modder Rex-Rodder
Ehhh- What's the difference? While everyone's busy measuring thier ****** in inches, I'll measure mine in centimeters.
Everyone wants a number to quantify the power of their rocket, but like Paul said, the # means nothing unless it's compared to something. And that # means nothing unless you've drivin it and can know the difference, right?
I also agree with Error- I really enjoy telling my passenger that my engine is only 70 cubic inches after taking him on a white knuckle ride!
I could say the thing has 200 HP, and what the hell would they know? It drives just like the car they were in that did have 200 HP, but wieghed 700 lbs more.
S'all relative, guys.
Yeah this is like saying my car will do 0-60
Sure it will get to 60 mph, but not specifying a time in which to do so , is simply clueless
I think car HP ratings fall into the same criterea as lies, damn lies and specs
well if you want to hear something really sad.... my white bone stock automatic 85 only made 47 rwhp!!!! thats bad! i think the tranny eats some of the power....a few tranny guys told me its the same tranny as the nissan
