transmission differences for fcs
Old Dec 29, 2002 | 02:11 PM
Black13B's Avatar
In Full Autist Cosplay
can anyone help me out?
wondering what differences (if any) are between the tII tranny, and the n/a tranny, of any year for the fc..
is there any transmissions from another vehicle (if applicable) that you can fit on a n/a 13b fc?
im not familiar with transmissions and mazdas..
i know GMs (FWD vehicles anyways) have a wide variety of trans you can swap (cookie cutter cars, right? N-bod J-bod A-bod etc trannies are usually all swapable), ones with different ratios for more accelleration or more top end or whatever..
just trying to figure out if the same things are possible with any stock mazda transmissions with an 86 n/a 13b fc.
Old Dec 29, 2002 | 02:12 PM
Black13B's Avatar
oh, btw.. keep in mind im talking about standard transmissions only.. i dont really care too much about the automatic tranny differences..
thanks again guys!
Old Dec 29, 2002 | 02:38 PM
Evil Aviator's Avatar
Rotorhead
The NA and TII transmissions have the same bolt pattern for the engine, so either will bolt onto either type of engine. However, the starter is different, and the clutch, flywheel, driveshaft, and rear end are of different diameters, so you need to change the entire drivetrain as a unit, or make custom components.
Other transmissions which will work are the HKS Dogmission race transmission ($7,000 USD) and the PBS MDR-1 race transmission ($6,000 USD). With appropriate custom adapters, you can use more common transmissions like the T-5, T-56, T-10, etc.
Old Dec 29, 2002 | 03:29 PM
Spraintz's Avatar
Edmond Dantes
so if I have an S5 N/A and have a complete TII driveline from flywheel to rear end, that tranny will bolt directly to my N/A engine? (until i get the TII engine of course)
i am concerned primarily with the 2 upper-passenger side bolts, they seem a different distance apart.
i only ask cause i would like to bolt it up once i get it so i can sell my N/A driveline and to have to store the TII stuff while waiting for the engine.
Old Dec 29, 2002 | 04:05 PM
Spraintz's Avatar
Edmond Dantes
also, after looking at the TII tranny gear ratios, it looks as if it help accelerate a little quicker. am i correct?
Old Dec 29, 2002 | 05:40 PM
Spraintz's Avatar
Edmond Dantes
please?
Old Dec 29, 2002 | 06:38 PM
Six Rotors's Avatar
To answer your 2nd question,the 5 speed from a B2200 truck will do nicely on your NA.
Old Dec 30, 2002 | 10:49 AM
Black13B's Avatar
from a b2200? what mods does it take to bolt one of those up (if any)?
Old Dec 30, 2002 | 07:43 PM
Rotorhead
Yes. Conversely, you could attach a TII engine to the NA drivetrain, although it wouldn't last long if your engine is producing much over 200hp. Also note that the TII halfshafts are a different size, so it is easiest just to swap the whole rear subassembly (with or without shocks) rather than to just replace the differential. Are you sure that you don't want to just sell your car and buy a TII?
I haven't tried it. Search this site for the infamous NA to TII threads and see if you can find any info.
Yes.
Enzo1944
Sep 6, 2015 08:57 AM
driftxsequence
NE RX-7 Forum
Sep 5, 2015 04:21 PM
