disconnecting motor from transmission.
Old Dec 25, 2002 | 09:10 PM
93redFD's Avatar
Whats the tricky part of this? I was told that only porsche and fd's are like this. How do you get the through out bearing to release??
Old Dec 25, 2002 | 09:49 PM
Trexthe3rd's Avatar
Are you trying to remove the engine or the transmission?
The simplest way is to remove the inspection plate on the bottom of the transmission. Unbolt the six pressure plate bolts, get in the car, step on the clutch and the engine will detach with the fly wheel. Loosen and remove the transmission bell housing bolts and the engine and transmission will seperate.
Old Dec 26, 2002 | 12:59 AM
SPOautos's Avatar
Hey, where did my $$$ go?
Man did you just pop your engine or what? You going to be at the dyno Fri???
STEPHEN
Old Dec 26, 2002 | 01:48 AM
TomsRX7's Avatar
Hi 93redFD. As you probably know, the FD uses a pull type throw out bearing/pressure plate instead of a push type. It really is simple to do once you learn it. No offense to Trexthe3rd, but I think it's a heck of a lot easier than having to spin the engine to loosen the six small bolts holding the pres plate on. All you really have to do is stick a long pry bar or screwdriver up through "service hole B"and pull the collar out (toward the back of the car) and it will realease. Takes 5 seconds.
The step by step procedure can be found in the big green 1993 workshop manual on page J-12. In case you don't have the book, here is a link to it. Just scroll down to J-12. http://www.scuderiaciriani.com/rx7/s...ansmission.pdf
Have fun and Merry Xmas
Tom
Old Dec 26, 2002 | 07:40 AM
rxrotary2_7's Avatar
i think undoing the 6 PP bolts is easiest. never had any luck with the collar through the service hole.
Old Dec 26, 2002 | 01:16 PM
93redFD's Avatar
nope havent popd the motor yet, im just gettting ready in case something bad happens. Its a hayes motor so anything can happen..
93redFD's Avatar
that pretty much cleared everything up. thanks ..
Old Dec 26, 2002 | 01:26 PM
Brad's Avatar
dear baby jesus...
Originally posted by 93redFD
Its a hayes motor
lol...better start saving for another!
Old Jan 22, 2003 | 10:48 PM
93redFD's Avatar
sorry to bring up the old post, but the motor blew at 4k miles. A extenal coolent seal went out. Does anybody have any pics of what im supposed to pry??? THis is the only thing I have left. I really need pics. I have never pulled a engine nor a trany. I have all the bolt of the trany to the motor also. I though that i was supposed to disconnect the trany bolts 1st. If I unscrew the pp bolts, How do I stop the main drive pulley from rotating?? I would tried the pull and release but I dont know what a collar is. Sorry for the ignorance, I have never delt with this kinda thing.
Old Jan 22, 2003 | 11:02 PM
c00lduke's Avatar
I wedge a screw driver between the bell housing and the fly wheel and unbolted all the nuts on the PP
Old Jan 22, 2003 | 11:09 PM
jr426's Avatar
you can use a prybar or large straight blade screwdriver to hold the pressure plate (hold the flywheel teeth using the prybar against the trans housing so it can't rotate) or have a friend hold the front pully bolt with the proper socket and breakerbar
Old Jan 22, 2003 | 11:13 PM
jr426's Avatar
I guess I am to slow
Old Jan 22, 2003 | 11:55 PM
I wish I was driving!
Re: disconnecting motor from transmission.
I worked on a Toyota supra, 87 turbo, that was the same way. Any pull-type clutch will be like this.
Old Jan 23, 2003 | 12:02 AM
Wargasm's Avatar
Weird Cat Man
This is the best way:
Remove both inspection plates on the bellhousing.
Remove the clutch slave and let it dangle by the line.
Stick your hand in the top inspection hole and pull back on the release fork.
While holding it like that, look in the lower hole with a light and you should see that the collar is pressed into the pressure plate now.
Stick a long flathead screwdriver in there between the bearing and the collar... while releasing the pulling force on the release fork with your other hand. The collar will stay in the pressure plate, and the release bearing will come out of it.
If you do this right, it should be disconnected.
Old Aug 31, 2003 | 03:07 PM
apexkw's Avatar
in slow, out fast!
WARGASM... Thank you!!! man, after messing with this thing for a long time... i just did what you said above and it came right out!!! thanks a bunch!
harrison
doritoloco
Sep 5, 2015 12:41 PM
