Need Help Quick, Vac Rack Removal.
Old Nov 22, 2002 | 02:14 AM
600HP CLUB's Avatar
i've search but i couldn't get a solid answer, i need to know where do i connect the two pulsation damper/FPR (or that thing at the end of the fuel rail)
and yeah where do i connect the vaccum lines from there to?
all i can find is
back of UIM
did they mean back of TB?
and
DOWNSTREAM of TB
the hell?
help me out i'm 16 and in need of help!
-mike
Old Nov 22, 2002 | 02:22 AM
600HP CLUB's Avatar
ps , there are 3 lines in front of the uim do i block em?
Old Nov 22, 2002 | 02:26 AM
600HP CLUB's Avatar
vaccum fuel lines - where to go?
i took out the spider lines, now i don't know where this two biatches should go for good vaccum for the fpr.
Old Nov 22, 2002 | 07:57 AM
SLOWT2's Avatar
From: new hampshire, middleton(a town so small we have no conveince stores)
if you dont need emmisions do a search under my name i only have 7 vac lines in my whole car, you can block the front 3 and use the back 4 one will go to your fpr, one will go to your oil injectors, one goes to the lower intake manifold and the 4th one on the bottom is a larger size that one gets blocked also
hope that helped a bit..
--joe
Old Nov 22, 2002 | 08:25 AM
No7Yet's Avatar
There's a nipple on the inside of the LIM, near where the cold start assist injector is. Connect the FPR to that.
Connect your injector breather lines to the nipples on either side of the MOP nipple. Connect the MOP vac line.
Connect the pressure sensor to the nipple that's just above the BAC on the side of the UIM.
Block off/cap all other nipples.
http://devils.eng.fsu.edu/~bmatt/RX-7/emissions.html <-- Here's my writeup. Note: complete writeup, unfinished website.
Brandon
Old Nov 22, 2002 | 01:35 PM
600HP CLUB's Avatar
but isn't the large nipple the oil injecters 4-1 line?
Old Nov 22, 2002 | 01:41 PM
600HP CLUB's Avatar
WOW PICTURES!
so fuel pressure goes here?
Old Nov 22, 2002 | 01:43 PM
600HP CLUB's Avatar
block these?
Old Nov 22, 2002 | 01:52 PM
600HP CLUB's Avatar
there are FOUR nipples on backside of the Upper Intake Manifold, are these correct?
-mike
Old Nov 22, 2002 | 02:03 PM
600HP CLUB's Avatar
im bored waiting for reply
here is me my baby few mins ago
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
joel(PA)
Oct 4, 2015 06:07 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
