my new secret weapon(s) :-)
i am expecting around 750 to the wheels at under 30 psi of boost.
680...i make all of my parts including that PAIN IN THE *** intake!!! i had a NOS backfire and blew the other one i made apart at the seams, so i had to make a new one and i wanted to use three runners instead of four.
MWW
MWW
Trending Topics
the twins will create more hp with less boost and provide a wider power band. at 25 psi they are supposed to make enough flow to support 900 h.p. a single turbo would have to be 35+ psi to make that kind of hp and would take forever to spool. the twins are far superior as long as you can spool them and rotaries are great at that!! i just finished a street car with a similar setup and it runs GREAT!! they spool super fast , dont stop pulling and backpressure stays under the boost level.
MWW
MWW
MWW
MWW
If I remember right you can't get something from nothing. Can you explain?
I'm still tring to figure out how this is possible If I remember right you can't get something from nothing.
Can you explain?
when i say BP i mean in the header before the turbo. your engine has overlap, which is the point when the intake and exhaust are joining and open at the same time. so when you have more pressure on the exhaust side than the intake side where is the pressure going to go?.....towards the intake which is going to reduce power for a couple of reasons, one being the fact that 1600 degree air goes back into the combustion chamber! and if the ratio is too excessive it can actually surge the turbo. this is not getting something for nothing since the intake side is where the boost is coming from and the exhaust is waste material and heading out of the system.
MWW
Can you explain?
MWW
That is a twisted setup!
I think I'm afraid already.... I can't even imagine how the guy who pulls up next to you will feel? Even better how your gonna feel in the second before you romp the throttle!
Very nice!
Very nice!
Can you explain?
MWW
Can you explain?
MWW
Are you talking about scavenging? Because I don't see how it can work in a rotary since valve timing can not be adjusted and pressure (exhaust) is relieved before the intake port sees the chamber again? However, boost prevents this, No?
MWW
MWW
man that's awesome.. I'd love to make my own manifold(s) and do a complete custom setup.. kinda like they do with Formula SAE cars.. I'd have to do lots of research, but I'd imagine that's an intake plenum of correct size (roughly 2 times the engine displacement)? I don't understand why it's good to hvae it like that, like I said I need to do lots of research, but I was told that most race cars do things like that.
MWW
MWW
Can you explain?
MWW
Can you explain?
MWW
I understand the back pressure comment and how more will cause less hp and more detonation.
Hey Marcus.
Lovely set up. Hope to see you run some 7's
. From my experiences at turbo specialties, we used to do all the mustang stuff and we did no telling how many back pressure tests to many turbos. The least amount of back pressure to intake pressure possible is 1-1. If you don't have any backpressure, you won't have any drive for your turbochargers. yes 1-1 is ideal and picture perfect. But anything right at 3-1 is better b/c of airspeed. More airspeed you have in your exhaust the quicker the turbos will spool. You just don't want to have too much back pressure or else the turbos will fall on their face. Not enough back pressure and you won't spool the turbos
. But with an alcohol BP engine, you won't have a problem above 6 grand
. You WILL have some back pressure!!!!! Anyway, good luck and hope to see you succede at the track!
Bryan
www.bnrsupercars.com
. You WILL have some back pressure!!!!! Anyway, good luck and hope to see you succede at the track!Bryan
Wow
Originally posted by FEARED7
Hey Marcus.
Bryan
Hey Marcus.
. From my experiences at turbo specialties, we used to do all the mustang stuff and we did no telling how many back pressure tests to many turbos. The least amount of back pressure to intake pressure possible is 1-1. If you don't have any backpressure, you won't have any drive for your turbochargersBryan
Bryan go get SAE PAPER SP-768, TURN TO PAGE 25 REF TABLE 2
2 Rotor Peripheral Port Turbocharged
Intake pressure 200.6 Kpa (absolute)
Exhaust manifold pressure 152 Kpa (absolute)
Engine speed 8003 rpm.
This is well below 1:1 ratio, It is possible to achieve and is the way to make maximum %Ve from the engine.
My engine runs below a 1:1 ratio as well, spool is good in my books, could be better with different turbine specs, but as I see it you NEVER get something for nothing.
Originally posted by setzep
I'm sorry, I must have worded my question wrong. I meant to ask how is it possible to have more boost pressure than exhaust pressure? I can see how you could get close to having the same pressure (in the exhaust manifold and after the turbos outlet on the compressor) but just don't see how it's possible to have less pressure in the exhaust manifold than after the turbo
The turbine uses exhaust heat as well as velocity + pulse energy resulting from the "explosion" in the combustion chamber to drive the compressor section. it is pretty true for most systems that if you can stay of the WG as long as you can that you realy are getting free energy or power from the turbo charger as the pressure ratio will always be on the positive side of the compressor, some engines though are not as effected by excesive back pressure between exhaust and intake and so can start waste gating much sooner at the expense of in creasing exhaust back pressure.
Either way turbostreetfighters new set up looks pretty nice to me, I am sure it will go as good as it looks
