UPDATE: 93 RX7 stalling at low RPM's (auto) HELP! :)
Old Oct 17, 2002 | 11:14 AM
DashKits.net's Avatar
MY 93 Auto RX7 stalls and cuts out at LOW RPMS:
it seems like it shifts into second at too low an RPM making it stall and
seem like its not getting enough fuel - or like its gonna die.
when i go slow through traffic, the car shifts into second/sometimes 3rd and put it at a LOW LOW
RPM like 1000...
making it stall out a little.
then i have to push the gas harder to get the RPMs up.
whats the deal?
TRANNY?
etc
i need to know please!
thanks !
Old Oct 17, 2002 | 12:05 PM
maxpesce's Avatar
Ex fd *****
First- get a Boost/ Vacuum guage - should be pulling at LEAST 10-12in Vac at Idle - If not check for Vac leacks,
Then Get a compression check, Low compression (>6 avg/Face on a Mazda comp. checker wil lead to the auto stalling)
Also may be related to the Throttle Position Sensor (TPS)
Does it happen more w/ the ac on?
Old Oct 17, 2002 | 02:08 PM
not sure on the AC thing- ill check
ALSO
compression was 6.1 all across 2 weeks ago
which is good.
aron
Old Oct 17, 2002 | 02:17 PM
Cihuuy's Avatar
maxpesce: do u know how to convert 10-12in Vac to mm/Hg? my boost gauge is in Bar... so how do u convert it?
Old Oct 17, 2002 | 04:24 PM
maxpesce's Avatar
Ex fd *****
Multiply the Inch # by 25.4 or Divide the mm #
inch = mm/25.4
Kyo
Apr 13, 2019 09:24 AM
Rotospectre
Mar 28, 2018 03:33 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
ncds_fc
Aug 15, 2015 10:06 AM
rkhanso
Aug 13, 2015 11:40 AM
