Most mods on stock ecu?
Old Oct 1, 2002 | 10:20 PM
I know you have heard it before but the car I just bought has 15k miles on it and I don't want to do much. I was thinking downpipe, exhaust and a k&n air filter w/stock air box mod. Will this be safe on stock ecu???
Rob.
Old Oct 1, 2002 | 10:24 PM
rajeevx7's Avatar
2 FD's since '98
yes and no. yes stock computer will handle fuel needs @10 psi. but you will definatly be boost spiking, promise you. there is a simple manual boost controler you can make in under 1/2 hour and costs >$20 to tune down your boost to a safe 10 psi. try useing the search button for it.
ps. put some money into reliability mods way before you think about performance mods.
Old Oct 1, 2002 | 10:26 PM
Already ordered the reliability mods! AST etc.
What electronic boost controller most easy to use?
HKS EVC-EZ?
Old Oct 1, 2002 | 10:29 PM
rajeevx7's Avatar
2 FD's since '98
im not sure, ive got the manual valves.
but, if i was going to throw $400 at it, i would hands down go for the apex-i one with the fully digital blue screen. costs a little more, but well worth it to get the graphs and graphics.
Old Oct 2, 2002 | 01:23 PM
BUMP^
Old Oct 2, 2002 | 01:25 PM
rynberg's Avatar
Old Oct 2, 2002 | 01:30 PM
Mahjik's Avatar
Mr. Links
Re: Most mods on stock ecu?
Rob.
You should be fine as long as you are running the stock cat. However, make sure you have a boost gauge installed and make sure you don't start getting any large boost spikes.
Old Oct 2, 2002 | 01:48 PM
Do I need a fuel cut defencer?
Would I be safer w/HKS EVC-EZ?
Rob
Old Oct 2, 2002 | 02:32 PM
BUMP^
Old Oct 2, 2002 | 03:12 PM
Mahjik's Avatar
Mr. Links
You don't want a fuel cut defenser on the FD. Fuel cut is there to help protect you from running lean and/or detonation.
If you want to run higher levels of boost, you should upgrade the ECU.
Old Oct 2, 2002 | 03:25 PM
Thank you, that makes sense.
Old Oct 2, 2002 | 03:38 PM
Mahjik's Avatar
Mr. Links
It's never a bad idea to add a boost controller, however, most people prefer the Greddy Profec B.
Also, don't think that just because you have a boost controller on the car you can add what you want. For instance, a boost controller won't help you if you overloading the wastegate (from something like running a downpipe, midpipe and aftermarket catback).
If you are overruning the wastegate, there is nothing the boost controller can do about that. Basically, you are fine as long as you don't slap on a midpipe.
Old Oct 2, 2002 | 03:43 PM
Well I was just worried about boost spikes. I am not imto racing but I like quick acceleration. So ALL I want is a downpipe,exhaust and stock air box modw/K&N filter.
Will this be safe on my cars stock ecu?
Rob
Old Oct 2, 2002 | 03:50 PM
Mahjik's Avatar
Mr. Links
Rob
Yes, as long as you can keep the boost around stock levels (10PSI). I didn't have a problem with boost spikes or anything after doing a dp and catback, but some people do. Every car is different.
Old Oct 2, 2002 | 03:56 PM
Pumped's Avatar
the most mods i had with the stock ecu is DP,MP,cat-back,SMIC, intake, and profec b boost controller set at 10psi.
i had this set up from 35000miles to 55000miles
currently i have the pettit unlimted ecu and still on stock motor and turbos at 65000miles
Old Oct 2, 2002 | 04:03 PM
Then what is the purpose for the upgrades? If you keep boost at 10psi,isn't that stock? The car will have the same pickup, right?
Rob
Old Oct 2, 2002 | 04:08 PM
Mahjik's Avatar
Mr. Links
Arrow
Rob
Nope, check this thread for a very good explaination:
https://www.rx7club.com/forum/showth...hreadid=118839
Old Oct 2, 2002 | 04:12 PM
Nice quote man...
[to simplify it even more...blow hotter air (less dence) through a straw at 12psi or a 3in tube (cold air) at 10psi. more air can be "pushed through" a 3in tube than a straw.
think of an engine as a big air pump.
nathan explained it well and i dont know how else to dumb it down. (no offence)]
Old Oct 2, 2002 | 04:28 PM
redbase's Avatar
I just bought my first 3rd gen (completely stock) a little over a month ago and have been doing research on upgrades. There is much debate on the "rule of 3' for 3rd gens. After three mods, such as intake, dp, and catback, some say the stock ECU can not compensate for the increased air flow and thus the car will lean out under WOT. Before going any further, you will have to have an ECU reprogrammed or go for PFC or other computer upgrade.
Old Oct 2, 2002 | 04:40 PM
The whole point is I don't want to go any further. I actually like the car the way it is, but I feel doing these 3 mods will make the engine last longer and run better. Does everyone agree??
Queppa
Nov 18, 2024 03:47 AM
incubuseva
14
Sep 3, 2015 12:37 PM
