how much unintercooled boost can a S4 TII engine handle.
Old 09-25-02, 10:46 AM
8/1 Building/Drive Ratio
82streetracer's Avatar
I have a whole S4 TII driveline (unported) in my garage waiting to go into my 82 s. I am ordering a atkins 7in this winter and hope to have the whole setup running by spring.
The camden site says that with 8.5 compression (this is what the TII has, right?) you can only run up to 6lbs of boost. (i think there talking about piston engines though)
THis sounds really low to me. I am looking to produce between 250 and 300 flywheel.
I have thought about creating a air/water intercooler to sit under the blower, with its own cooling system. How much could I possibly run after that.
also, I plan to run a distributor on this setup but Im not familiar with boost vs timing, I know its different for superchargers vs turbos but any info would help.
and should I just run stock FC plugs?
Old 09-25-02, 11:21 AM
bump, I need help on this!
Old 09-25-02, 11:37 AM
hypntyz7's Avatar
Well, the stock turbo engine runs 6psi with the stock IC, adn we all know a turbo makes more heat than an SC, so you can run at *least* 6psi. IT's prety widely agreed that 10psi is about the limit on the stock intercooler's capacity before it becomes a burden. However, using it as air to water, not being top mounted, and not having a turbo pump all kinds of heat though it, you could probably run more with your blower. Depends on exactly how much more efficient(less heat) it is than a turbo. Nobody can "tell" you how much this is, youll just have to figure it out yourself. Unles they have done the exact same thing.
Ryde _Or_Die's Avatar
So what exactly are you doing? Are you putting a supercharger on your current engine with a TII tranny and rearend or what? Or I'm getting the impression your trying to supercharge a TII engine which is already turbocharged. If thats the case I must ask-why?
Old 09-25-02, 01:31 PM
RETed's Avatar
Non-intercooled, the magic number is 7psi - anything over that is asking for trouble.&nbsp I've heard you can push it to 10psi, but that's at your own risk.
-Ted
Old 09-25-02, 04:38 PM
Rotorhead
Evil Aviator's Avatar
http://images.amazon.com/images/P/08...1.LZZZZZZZ.jpg
Old 09-25-02, 05:15 PM
no, its a bare tII block, racing beat roadrace headers, atkins intake and blower, no turbo,
I also dont have the stock intercooler and dont plan on using one.
Where can I get that book, that would be very helpfull.
Lets say the intercooler works great, the supercharger is limited to i think 15psi, maybe as high as 25. What can the motor take?
Old 09-25-02, 05:27 PM
I've never heard of superchargers getting that high of boost. What do you do, change the pulley to a smaller one or what?
Old 09-25-02, 05:33 PM
Rotorhead
http://www.amazon.com
Yes, it's very helpful, and a very good read even if you don't have a supercharger. Unfortunately, it is geared toward piston engines like every other book, but if you just double your rotary engine's displacement all the math will work out just fine.
Old 09-25-02, 06:50 PM
yeh I just ordered it.
Old 09-25-02, 06:55 PM
RETed's Avatar
Boy, you should go ask those NHRA Top Fuel dragsters and Funny Cars how much supercharged boost they are running...
-Ted
Old 09-25-02, 08:01 PM
well the site says there standard pulley makes 15lbs of boost.
I think i will start with a 6lb pully for a while till I get the whole Air/water intercooler figured out. Then go up from there.
Im also going to get one of those dual signal intake temperture sensors so that I can test intake temp before and after the intercooler. That should help me alot in deciding safe boost levels.
Old 09-25-02, 08:27 PM
think a blower cant make that much boost, check out this autometer guage. I saw one of these guages on a drag car once.
60 max psi
Old 09-25-02, 09:02 PM
Rotorhead
60 max psi
LOL, the SPA boost gauge comes with one of the following pressure sensors:
1.6 BAR (23.2 psi)
16 BAR (232 psi)
200 BAR (2900 psi)
http://www.spatechnique.com/instruments.html
Old 09-26-02, 10:33 AM
what about timing, noone answered that.
What should i run, I have heard advance is acceptible on a blower.
Right now im running 24 leading 16 trailing @ 4000 rpms but im pretty sure thats way too much.
immanuel__7
Megasquirt Forum
08-22-15 09:34 PM
Quick Reply: how much unintercooled boost can a S4 TII engine handle.
