Need an ID on this thing in the engine bay...
Old Sep 14, 2002 | 10:53 PM
Wattz's Avatar
What is this thing?
Old Sep 14, 2002 | 10:55 PM
Adsy01's Avatar
ACBron Motorsport
looks like the automatic choke return thinga-ma-bobbie to me
diabolical1's Avatar
if i'm not mistaken, that's the servo/solenoid assembly for the choke ...
Old Sep 14, 2002 | 10:56 PM
Wattz's Avatar
Alright well mine is broken.
The wire that goes from it to the carb is rusted, it doesn't move at all. The little connector that connects the wire to the little device thing there is broken, so even if the wire did move, it wouldn't work.
How bad is this? Can I get away with it being broken for a while?
Old Sep 14, 2002 | 11:04 PM
Adsy01's Avatar
ACBron Motorsport
it just mens your choke wont work unless you hold it out yourself,,
Old Sep 14, 2002 | 11:07 PM
i think the electric control is only there for sensing when it should be held in place, not the choke function itself, so as long as the cable itself is fine ... the choke should work.
here, let me educate you in Ghetto 101 ...
in the winter, when you REALLY need the choke (i don't know how cold it gets in Arkansas) just make sure you have a clothes peg (or two).
start the car with the choke, then slide it (them) under the choke lever ... take it (them) off when the car is warm enough to idle by itself.
now, i'm not saying don't fix it ... but i'm saying you can survive if you choose not to.
Old Sep 14, 2002 | 11:17 PM
Adsy01's Avatar
ACBron Motorsport
lol i gotta try that, and i was gonna just change my choke cable to a std one. (ive got no auto thingy in the engine bay)
Old Sep 15, 2002 | 01:46 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
LOL That is the hot start assist assy.
When the motor is warm it opens the throttle a little. Toss it , its a waste of space LOL You can do that yourself.
Old Sep 15, 2002 | 02:03 AM
peejay's Avatar
Old [Sch|F]ool
Yes it's the OPPOSITE of a choke.
When the engine is hot, that little motor pulls the throttle open a bit when you're cranking so that the engine doesn't flood.
It's not necessary if you remember to hold the throttle open when starting a hot engine. Remember, cars have to be designed so that Any Idiot can drive one.
Old Sep 15, 2002 | 03:09 AM
Adsy01's Avatar
ACBron Motorsport
no it isent! well not on the aussie cars it aint...
I removed mine as part of a rats nest tidy up and when i did so my choke no longer stays out (ignition on ect....)
the choke now springs back like it does when the ignition is off.
Old Sep 15, 2002 | 04:49 AM
Gatorgunner's Avatar
Yep i agree with mike p-28, i would toss it. I tossed mine, no noticable difference in how the engine runs. besides once its out, you have yet another thing to hang from your christmas tree, right next to the pretty multi colored connectors of your rats nest
hehehe
Old Sep 15, 2002 | 05:03 AM
Adsy01's Avatar
ACBron Motorsport
hehehe
lol,
must be a aussie thing then 'cause ive owned 31st gens and its been the same on all 3..
mine didnt run any bit different!! just could not use the choke unless you held it out the whole time, or used a clothes peg as we are now all informed
Old Sep 15, 2002 | 10:27 AM
MIKE-P-28's Avatar
I would think they would put the choke stuff on the carb?
Dunno , you got a pic of yours?
Old Sep 15, 2002 | 02:39 PM
Wattz's Avatar
I don't think I'm gonna remove the rat's nest until I buy an aftermarket carb... Too many people have complained of problems when you leave the stock carb on and take the nest out.
Old Sep 15, 2002 | 04:11 PM
BadAssRX-7's Avatar
The AUTO DOCTOR
hot start asst. motor thing... after tha car is warm watch it when u turn the key on it opens then closes.... putting a little fuel in the carb.
Old Sep 15, 2002 | 04:20 PM
REVHED's Avatar
Hunting Skylines
No, that's definately the hot start assist and it has nothing to do with the choke. The choke release is part of the actual choke **** assembly in the dash.
I bet the reason yours doesn't work is because you removed the wires from the temp sensor. The temp sensor for the choke release is located in the thermostat housing.
Old Apr 14, 2003 | 03:55 PM
slag's Avatar
Revhead, or anyone else.
My 79 is missing many wires to certain things. I have no connectors to the sensors on the radiator, both the top sensor and the sensor on the driver side near the top. Are these needed for anything motor related, or are they just idiot lights for something?
Old Apr 14, 2003 | 04:23 PM
Cody's Avatar
SKELETOR!
I took mine off and ate it. It tasted like burning.
Old Apr 14, 2003 | 10:03 PM
ZigZag's Avatar
Definitely the Hot Start Assist. On American Rx7's, anyway.
cristoDathird
28
May 30, 2019 08:47 PM
rx7jocke
Aug 15, 2015 03:36 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
