shifting
Old Sep 11, 2002 | 01:26 PM
lamboz1's Avatar
shifting
general question, i have an 88 with a 5 speed, and the 1-2 shift is not a straight pull back, u have to go back the middle and then diagonally into second gear... is that how it is supposed to be?
dikigoros@yahoo.com
Old Sep 11, 2002 | 01:34 PM
Rxmfn7's Avatar
Do a barrel roll!
No, somethings wrong. It should go straight back. There is usually a little "notchiness" on the 1-2 shift on most older rx-7s, maybe some grinding when shifting fast.
Old Sep 11, 2002 | 01:56 PM
rx7sam's Avatar
Yeah, that happens to me when I race someone. I shift quickly to 2nd, and the stupid shifter gets stuck and makes a grinding noise. Damns
Old Sep 11, 2002 | 02:36 PM
nopistons's Avatar
Try installing new shifter bushings and see if that helps. They're cheap, and easy to install.
Old Sep 11, 2002 | 03:30 PM
AggieDave's Avatar
i second the bushings... i had a small grind until i fixed mine.... but now i have no 1st or 2nd gear.. oops
dave
Old Sep 11, 2002 | 03:51 PM
RangerJoeEOD's Avatar
i am having the same problem only mine dose in in to 2 and 3rd, where can i get bushings? BTW you Name NoPistons is the same as my user name on cardomain.com
Old Sep 11, 2002 | 07:56 PM
Rxmfn7's Avatar
Do a barrel roll!
www.mazdatrix.com sells the shifter bushings.
Old Sep 11, 2002 | 11:03 PM
M.C. Language's Avatar
go to your local mazda dealer for the bushiins, they are like 30 bucks here in Canada...... so whats that over in the states.... like 4 bucks...
Old Sep 11, 2002 | 11:22 PM
dr0x's Avatar
pei > caek
My reverse is to the right of fifth a bit, but I think its susposed to be like that. The rest are straight shifts for me..
Old Sep 11, 2002 | 11:31 PM
NRA T2's Avatar
could be a chiped or bent tooth(s) on the gears
Old Sep 12, 2002 | 01:27 AM
Rotorific's Avatar
I dont know a damn thing
no man its bushings they are about 12 bucks from your local mazda dealer the best thing you can do for your shifting other than a short shifter
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
Rotafuzz
Sep 30, 2015 09:55 AM
