how do i get 850 rpm idle instead of 725?
Old Aug 14, 2002 | 04:35 AM
93TTRX7's Avatar
says that diagnosis idle is from 725-750 rpm-which mine is currently at. I want to know how i can get out of diagnosis and into the normal 850 rpm idle...just for ***** n giggles
Old Aug 14, 2002 | 05:24 AM
user 84205's Avatar
got a PFC?
Set screw...
Old Aug 14, 2002 | 07:30 AM
There is an idle control screw by the UIM/TB .. give it a twist
Old Aug 14, 2002 | 01:10 PM
JONSKI's Avatar
5yr member, joined 2001
It takes a slot-headed screwdriver.
Old Aug 14, 2002 | 01:28 PM
RX7Elmo's Avatar
haha, you can't get any more helpful that the above pic!
Danny
Old Aug 14, 2002 | 01:33 PM
TYSON's Avatar
WTF is wrong with it now?
Electrical load increases your idle slightly, turn your heater to 4. A/C increases idle further. On PFC base map, these numbers are 725, 800 & 900.
I wouldn't **** & giggle while doing this if I were you
Old Aug 14, 2002 | 02:11 PM
TwinTriangles's Avatar
What's an RX-7 ?
I ran a PFC set at 1100 for a while, i noticed when i tuned it down to around 8-900 it would pull boost just a little so I turned it back up to 1100
Old Aug 15, 2002 | 01:32 AM
93TTRX7's Avatar
thanks for the tip
24seven_dada
20
Nov 10, 2018 12:03 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
The1Sun
Sep 7, 2015 10:21 PM
