Hesitation at 3800 rpm
Old Aug 6, 2002 | 10:04 PM
EZG's Avatar
EZG
Newbie
Angry Hesitation at 3800 rpm
I have a slight hesitation at 3800 rpm while shifting all gears no matter when or where. Once I cross 3850-3900, it takes off as usual and can easily attain 6000 without any further problems. It seems the previous owner had the same problem (from maintenance records) and it looks like nothing has been found.
I have a 1988, F.I. manual, convertible which is probably the same 13B all others have but I haven't heard of other cars with similar problems. Car is in top shape inside and out , 145k miles and a rebuilt engine at 139k. Prior problems were even before engine rebuild so I suspect it's fuel system/computer issue?
Anyone with similar problems? Yuor feedback would be appreciated.
Old Aug 6, 2002 | 10:20 PM
Snrub's Avatar
That's probably one of the most common problems. There are lots of causes. In your case the first thing to do is chech that the throttle position sensor is working correctly. Poor grounds are another common one. 3800rpm is the point where the secondary injectors start to kick in. Get the Haynes manual and check the resistance of all the little electronic sensors, etc. listed as posible causes. Try using the search button to get some other suggestions. I know sometimes its difficult to find what you want with it, but I think you should be okay with this question.
Old Aug 6, 2002 | 10:25 PM
J-Rat's Avatar
Alcohol Fueled!
The 3800 rpm hesitation is quite common for our vehicles. Its commonly caused by bad grounds in either the ECU or other places. Sometimes its just corroded connectors on the secondaries. THere are a million threads on the very same problem Doing a search should get you some ideas.
Rat
Old Aug 6, 2002 | 10:26 PM
NZConvertible's Avatar
I'm a boost creep...
Try this.
Old Dec 1, 2003 | 07:52 AM
The above link is broken. Can you re-post the link to that thread? I'm having the same problem with hesitation @ 3800 RPMS while shifting from 3 to 4th. I have a turbo II rx7
Old Dec 1, 2003 | 03:39 PM
J-Rat's Avatar
Alcohol Fueled!
Good god! This thread is over a year old! NICE!!
Look in the archives, follow the thred "Grounding, thourogh and descriptive"
Rat
Old Dec 1, 2003 | 05:48 PM
rx-7s rock's Avatar
Game of Death
I like my hesitation. It makes me feel like I go faster once it revs past it. lol....just kidding.
Old Dec 1, 2003 | 07:54 PM
<rx-7's rock> good one. I had to say that was funny. I love the part when your head jerks and you get whiplash. Great time.
Old Dec 1, 2003 | 10:50 PM
I've looked but I think it's gone for good. It was a good how-to on regrounding the ECU, but it's not hard to do.
Look at the wiring diagrams for the ECU and you'll see there are four ground wires. Three of these join together a short distance from the plugs, and the joint isn't a very good one. You unsolder this joint and solder it all back together, adding another wire to the joint which you attach the a good ground point on the chassis.
Old Dec 2, 2003 | 09:55 AM
cool - thanks
Sethix
Nov 3, 2017 11:48 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
lnlreaper
Sep 27, 2015 09:59 AM
