Bridge Porting and Street Porting??
Old May 3, 2010 | 03:41 AM
hashman626's Avatar
I am just wondering what is the difference between the two. If anyone could help me out I would appreciate it! I'm trying to decide what to do for my 1991 rx7 n/a coupe.
Old May 3, 2010 | 08:44 AM
mar3's Avatar
Administrator
Street porting is a mild rework of the ports, bridgeporting is a hog-out port job. There is more power to be made with the bridgeport but the idle has to be kept high if you run it on the street...somebody already has the links to some pics, so I'll let them jump in since this is a common question even in this New Member tech board.
Mario III
Old May 3, 2010 | 09:10 AM
Aaron Cake's Avatar
Engine, Not Motor
Your only reasonable option is a street port.
Am street port in the 6 port NA generally just opens the ports a little earlier and closes them a little later. The result is a top end gain (maybe 20%) with some sacrifice down below. You can run the stock intake, stock ECU, and just upgrade the exhaust.
A bridgeport cuts another port between the intake port and the rotor housing:
This is because the intake port has been ported as far as it can go towards the rotor housing, so a small bridge is left for the corner and side seals to run on and the port is then continued on the other side, even into the rotor housing. You will need to ditch the stock intake manifold, run a standalone EMS system and upgrade to a free flowing (loud!) exhaust. Power gains are much more substantial (100+ HP) but low end is severely reduced, exhaust volume is high, and fuel economy goes into the toilet.
Old May 3, 2010 | 09:56 AM
pinkfc3s's Avatar
I will say thank you for this. Explains so much more. Thank you
Old May 11, 2010 | 11:07 AM
94_RX7_FD's Avatar
Newb
Thanks so much for going over this. Fairly new and didn't know what either were.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
