Twin turbo upgrade
Old Dec 2, 2007 | 06:46 PM
R-R-Rx7's Avatar
Rotor or no motor
Twin turbo upgrade
Hey guys
I wanna upgrade my stock 2002 twins for something bigger, i dont wanna go on a single.
I came across the BNR stage 3 and the knightsports setup
Has anyone used them? any comments on them ?
any real difference ?
Or has anyone anything else? that is recommended?
Thanks
Con
Old Dec 2, 2007 | 07:02 PM
David Hayes's Avatar
Go with the BNR stage 3s. Lots of guys run them on this forum with good results. Do a search for BNR and you'll find a lot of info.
Old Dec 2, 2007 | 07:12 PM
RE-Amemiya's Avatar
Not the company
Good advice; i don't have any personal experience but there are lots of threads about them.
Old Dec 2, 2007 | 07:15 PM
R-R-Rx7's Avatar
Rotor or no motor
how about horsepower though ?
Does anyone know how much they are capable of?
Knightsports?
Old Dec 2, 2007 | 07:23 PM
Mahjik's Avatar
Mr. Links
It seems about all of the normal twin turbo upgrades top out a little over 400rwhp. If you want/need more than that, you'll need to go with a single turbo.
Brent Dalton's Avatar
Sua Sponte
GoodfellasFD3S put down 421rwhp on his BNR stage 3's. That is the most I've seen.
Mister Destiny's Avatar
Keep it Easy
I know i've been to South Cypress before. Is it Greece or Turkey?
Old Dec 2, 2007 | 07:33 PM
FDNewbie's Avatar
Sponsor
Hey Con,
The BNR Stage III's def. have a lot of feedback on this forum.
As for JDM options, there are both the Knightsports RF-420s (420PS) and the Border twins which have been around for SEVERAL years now. Haven't heard any negative feedback on 'em to date, although the Knightsports units tend to be more popular due to price (the Border twins are a wee bit expensive)... The KS are re-worked OEM turbos (like the BNRs), while the Border kit is a FULL true bolt-on twin turbo kit, all new from the ground-up (hence the price). It's the only kit that I know that's boasted SERIOUS hp #s... It uses two internally gated Apex (IHI) Ax53b70 P25 Ball bearing turbos, which according to Apex'i USA are good for approximately 350-375hp a piece.
Border kit:
Old Dec 2, 2007 | 09:43 PM
RiPPeN's Avatar
Got a website for that border kit?
Old Dec 2, 2007 | 09:53 PM
Str8Down's Avatar
Avoid Fuego Racing
The border kit doesn't appear sequential, correct?
Old Dec 2, 2007 | 10:05 PM
Click on the dyno link in my sig to see what the BNRs can do
Old Dec 3, 2007 | 12:15 AM
moconnor's Avatar
Got a price for that Border kit?
Old Dec 3, 2007 | 04:03 AM
R-R-Rx7's Avatar
Rotor or no motor
Cyprus is Cyprus ..not greece not turkey but the south cyprus is the greek language spoken side of cyprus
Old Dec 3, 2007 | 04:07 AM
R-R-Rx7's Avatar
Rotor or no motor
Originally Posted by FDNewbie
Hey Con,
Border kit:
Price?
is it a US product or japanese?
Im currently running on a 3 row greddy SMIC
the hks reloaded intake and the twin maxim works downpipe, i will basically have to throw them away and get bigger ones for this application right?
Old Dec 3, 2007 | 11:10 AM
FDNewbie's Avatar
Sponsor
Con,
- It's Japanese (Border Racing is a Japanese tuner company; one of the larger ones actually with VERY high quality products).
- They offer two options:
1) Everything pictured above (manifold, extension pipe, front pipe, air suction intake, and all misc hardware, fittings, etc) WITH the turbos: $8000+
2) Everything pictured above WITHOUT the turbos (ie "bring your own turbos": $5000
These are rough prices, not exact price quotes. And as I mentioned (and seen in the pics) the kit comes w/ an intake, so you wouldn't need the HKS intake you're currently running. And yes, this is a full non-sequential kit.
Thanks,
~Ramy
FDNewbie Imports
Old Dec 3, 2007 | 11:24 AM
Chadwick's Avatar
Mr Sparkles
I recently installed a street ported 13b-rew with BNR stage 3's in a customers car and tuned it. Car put down 445rwhp @ 18 lbs of boost running sequential. I would recommend the BNR stage 3 for the price.
Old Dec 3, 2007 | 11:28 AM
R-R-Rx7's Avatar
Rotor or no motor
Con,
Thanks,
~Ramy
FDNewbie Imports
No doubt that this is amazing setup but also an amazing amount of money.
Thanks though Ramy
Old Dec 3, 2007 | 11:37 AM
Mahjik's Avatar
Mr. Links
Loved to see that dyno sheet. Not necessarily throwing a BS flag, but that's the highest rwhp I've seen with stock configured turbos.
Old Dec 3, 2007 | 11:41 AM
Chadwick's Avatar
Mr Sparkles
Sure thing, I'll run over to my shop at lunch and print one off.
Old Dec 3, 2007 | 02:10 PM
Prometheus's Avatar
Still got it.
What!?!?!
Please post more info.
What has been done to that engine internally?
Dyno Sheet?
Old Dec 3, 2007 | 02:19 PM
Chadwick's Avatar
Mr Sparkles
Here is one I found at 441.6 rwhp, couldn't find the 445 rwhp one in the limited time I had at lunch. Made over 100 runs tuning so a lot to sort though.
Old Dec 3, 2007 | 02:32 PM
TitaniumTT's Avatar
Wow - That's an impressive feat. What are you using to tune that motor? I'm wondering if there is a way to level the torque curve during the transition
Old Dec 3, 2007 | 02:45 PM
Chadwick's Avatar
Mr Sparkles
Originally Posted by sk8erpunk1983
What!?!?!
Dyno Sheet?
It could of made more power, but the injectors were not larger enough and it was pushing the fuel limit to make what it did. We were not going for a max power run, was actually trying to get the boost turned down. Made a 445, 441, 438 before we could get the boost controller to kick in right.
Internally the motor is basically stock with a medium street port. I ported and gasket matched the LIM & UIM. All emission crap removed. Here is a basic list of mods that relates to power:
BNR stage 3 Turbos
3" downpipe, highflow cat and Pettit Muffler
550cc / 1300cc injectors
Nipondenso Fuel Pump
Stock ignition
9L/9T plugs
Pettit Cool charge intake
ASP Large IC
Greddy elbow
Power FC
Greddy Type S boost controller
Pettit underdrive pully set
Old Dec 3, 2007 | 02:48 PM
Chadwick's Avatar
Mr Sparkles
Data Logit with FC-Edit. Yes you can, this was before I made some adjustments to reduce the power loss at transition.
Old Dec 3, 2007 | 02:57 PM
R-R-Rx7's Avatar
Rotor or no motor
What size of injectors and fuel pump are needed for this applications anyway?
