Updated lines, fittings, etc.
Old Aug 2, 2007 | 07:22 PM
Zero R's Avatar
Just in time to die
OK I have updated the lines and fittings in the kits, these fittings of course will all be available seperately for those of you who already have your own turbos
I also will be offering a package to current a-spec kit owners who wish to update what they have to the better fitting, nicer stuff, just shoot me a email for that info.
The oil drain fittings will fit very tight spaces and are made with a smaller footprint than others and angled to acheive this. They can be used on either side of the turbine inlet. They are made with a -10 male end on them. They can be used on the front cover as well. I have these for the larger drain flange(TO4R,42R etc.) as well.
I updated the coolant lines with high temp (1200deg) shielded lines also, this was to address some customers concerns of heat effecting the coolant lines from sitting so close to the turbine and manifolds.
These updates will not increase the cost of the kits, it was done siply to offer a better product by listening to what our customers wanted to see in their kits.
Attached Thumbnails Updated lines, fittings, etc.-odf1.jpg   Updated lines, fittings, etc.-odf3.jpg   Updated lines, fittings, etc.-odf5.jpg   Updated lines, fittings, etc.-odf6.jpg   Updated lines, fittings, etc.-prodrn2.jpg
Old Aug 2, 2007 | 11:09 PM
Good ****
Definitely shoot me a price on the upgraded kit
Old Aug 2, 2007 | 11:19 PM
2FAST7S's Avatar
Originally Posted by GoodfellaFD3S
Good ****
make that 2...
Old Aug 3, 2007 | 05:58 AM
Madee's Avatar
Interested in the oil drain line. I have your GT40R kit. Please post pricing for components.
Old Aug 3, 2007 | 09:47 AM
Zero R's Avatar
Just in time to die
I need you guys to shoot me a email telling me which manifold and turbo you have.
Madee it is very likely if your running the short runner 40R kit that fitment may not work as of yet. I haven't checked to see if the actual drain fitting for that CHRA works with turbine placement on that setup. I haven't sold that setup in quite awhile. Coolant lines wont be a problem.
Old Aug 3, 2007 | 03:12 PM
Zero R's Avatar
Just in time to die
Also the new lines will be warranted the same as the manifolds and DP which is as long as you own them. Just send me the old lines for inspection and new ones will be sent out once there is proof of honest failure. Forgot to add that.
Hopefully more pics showing them mounted on the the engine and turbo assembly soon.
Old Aug 3, 2007 | 03:36 PM
oo7arkman's Avatar
In the Garage
Sean, you guys are great. Thank you so much for putting the time into this. It makes your kits that are already VERY nice kits into something even more impressive. I will shoot you an email about the lines on my 500r kit.
-Noah-
Old Aug 6, 2007 | 03:21 PM
Zero R's Avatar
Just in time to die
Here are some pics of the fitting for the block. I will have pics of the complete drains shortly.
Attached Thumbnails Updated lines, fittings, etc.-odfb.jpg   Updated lines, fittings, etc.-odfb2.jpg
Old Aug 6, 2007 | 09:26 PM
Zero R's Avatar
Just in time to die
Here you go pics of the drain for our short runner customers(first pic) as well as pics for the long runner customers. All kits will come setup like this from now on, along with the upgraded coolant lines. This includes FC kits, RHD kits, 20B kits etc.
-S-
Attached Thumbnails Updated lines, fittings, etc.-odfsr1.jpg   Updated lines, fittings, etc.-odflr.jpg   Updated lines, fittings, etc.-odflr1.jpg
Old Aug 7, 2007 | 07:18 PM
GoRacer's Avatar
Speed Mach Go Go Go
Fracken-ay, dats a sweet upgrade! double props
Old Aug 7, 2007 | 10:00 PM
Smeagol's Avatar
I need this for my GT3574 kit, will send a PM.
Mike
Old Aug 8, 2007 | 01:53 PM
vel525's Avatar
Woo Hoo, It Runs!!
Mike
Mike,
I would email Sean as he gets A LOT of PMs and checks his email more frequently. Much easier to get a hold of him via email than through PM.
Old Aug 8, 2007 | 02:28 PM
GooRoo's Avatar
93-FD
-S-
Very nice! Thanks for listening to your customers and working to improve the kits.
I'll PM you about getting replacement coolant lines.
Old Aug 8, 2007 | 02:30 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
EXCELLENT!!!
You guys did a great job of taking user feedback and improving the product!!!
I will email ya for a new hose kit :-)
Old Aug 8, 2007 | 08:14 PM
Zero R's Avatar
Just in time to die
Mike
Mike I finally have this stuff sorted. Will answer your PM.
No problem sir.
Originally Posted by damian
EXCELLENT!!!
Got ya covered sir. and thanks for the compliments.
Old Aug 9, 2007 | 08:44 AM
sao1's Avatar
Another great product from the A-Spec camp!
Old Aug 9, 2007 | 09:01 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
really nice rotary stuff.
thanks A Spec.
howard coleman
Old Sep 24, 2007 | 12:22 PM
palsor1's Avatar
Is anyone using the new oil drain line with the oil pump installed? I just got the new drain line and tried to install it. The threaded end of the fitting that bolts to the engine ends up touching the wires coming out of the connector for the oil pump. As a result, I can't screw the drain line onto the fitting. The oil pump connector ends up preventing it from going on. Any suggestions from anyone?
It appears the setups in the pictures don't use the oil pump.
- Andy
Old Sep 25, 2007 | 01:03 PM
PandazRx-7's Avatar
Fast + Reliable = $$$$$
- Andy
You are correct, I was stumped for a minute too. I ended up using the extension that is used with the stock turbos to come out a bit and clear the pump... Worked perfect, but I still haven't hooked any lines yet...
Old Sep 25, 2007 | 02:04 PM
palsor1's Avatar
Hmmm... I'll try that, but I'm guessing that the line won't fit if we do that, though who knows.
Old Sep 26, 2007 | 06:55 PM
PandazRx-7's Avatar
I'll be tightening down the fittings and lines this weekend...I'll let you know how it goes.
Old Sep 26, 2007 | 07:20 PM
Smeagol's Avatar
Still waiting for mine. I think I got lost in the shuffle again.
Mike
Old Oct 1, 2007 | 02:21 PM
PandazRx-7's Avatar
- Andy
Scratch what I said earlier...I tightened everything down yesterday and you DON'T need that stock extension. Yes, the new fitting does touch the wires on the OMP connector, but it's not so bad... hand tighten the hose to the new fitting first and then bolt down the new fitting to the block. VERY tight fit, but it works...
Old Oct 1, 2007 | 02:35 PM
palsor1's Avatar
Hmmm... Any thoughts about whether having the wires touch the fitting could cause the wires to burn? I'd be worried about melting the insulation on the wire, and then having them ground themselves on the fitting.
Old Oct 1, 2007 | 03:55 PM
PandazRx-7's Avatar
Hmmm... good point. I can't imagine an oil line getting soooo hot as to burn the wires. But I can imagine the wires getting brittle from long periods of high heat like under the UIM. Well, I guess I'll try sliding something in between to insualte the wire maybe... I'll let you know what I do. Better yet, I'll take pics.
