Rtek Thumbs up for S5 NA 2.0
Thumbs up for S5 NA 2.0 (Dyno Charts)
91 vert. RB header only mod. Still running stock primary cat. Everything else bone stock. About 95k miles. Power gains were made with fuel tuning only.
Stock ECU Dyno
Mod ECU Dyno
Stock ECU v. Mod ECU
Stock ECU A/F Log
Mod ECU A/F Log
Stock ECU Dyno
Mod ECU Dyno
Stock ECU A/F Log
Mod ECU A/F Log
Trending Topics
You'd be surprised at where the power actually lays on any production car in relation to the tach. Revving to redline for each shift isn't always making things go faster. Very often it's only making more noise. In this particular case freeing up flow on the exhaust side would move the HP up the ladder as well as giving a bump in power across the whole rev range. Regardless, peak power on stock ports is going to be south of the 8000 rpm redline.
Unless the power starts to drop off dramatically or if you've got really close gears then it's best to redline it every time. One excercise you can do is import the dyno numbers into excel then scale them vertically and horisontally for each gear ratio(first is taller and narrower, second shorter and longer, etc). It'll only be better to upshift short of the redline if the scaled power in one gear drops below the scaled power in the next gear. I think you'll find that it's still better to redline it every time, even though the peak power is lower than the redline.
Technically, the best shift point would be where the engine power drops of to the numerical equivalent in the tach after the shift. Unfortunately, I can't think of many cars you can do that on. That's why really peaky cars have such short gear ratios.
Those before and after graphs are AMAZING, I bet the car also runs a little cleaner also. Anyone have any before and after graphs of a Turbo motor with just fuel tuning?
I moved my website and all the links I've ever posted were broken. If anyone wants a file copy just send me a PM.
What does *graphs* mean? I've taken quite a bit of crap from non-believers thinking I manufactured those results. I'd hate to think this was more of the same.
http://www.digitaltuning.com/index.p...age=2&ecu=S5NA
Click "show dyno charts"
We don't have any particular one that we recomend.
From the FAQ...
PDA Compatibility
http://www.pocketlogger.com/index.php?pid=faq_pda_list
Compatible Palm PDAs can be had off ebay for less than $40.
From the FAQ...
PDA Compatibility
