where are the 13b-rew guys?? people who've done the swap please come here!!!
guys please tell me your experiences!!
YES, I'VE SEARCHED
YES, I KNOW THE ISSUES!
... but please give me some advice on additional issues, besides engine mounts and stuff! do you run your REW with stock twins, who's running single? who did a streetport?
my TII, has gone to nirvana and broke one apex seal in his way...
but this is the time for a new winter project!!
thx for help
YES, I'VE SEARCHED
thx for help
Well in a crossmember behind the stock FC stock engine cradle.
Use the stock FD3S engine mounts.
Call it a day.
Control of the engine is very similar to the FC's 13BT's.
I'd stay away from the stock twins.
They are not very reliable.
-Ted
Call it a day.
-Ted
Call it a day.
-Ted
Call it a day.
-Ted
regs
by the way: i love your page, especially the tech section - nice work man!!
Yeah, it's a question on how you want to mount the engine...
Cause, you're right - the stock 13BT is not mounted in the center of the transmission tunnel!
I can hear the gasps now...
Mazda mounting the engine slightly to the left to allow the exhaust to run down the same tunnel.
The car I worked on pushed the engine directly in the middle - easiest to measure - and we didn't have any problems with it running.
I guess you can mark the spot where your original 13B was sitting and then place it there, but I don't think a few mm ("inches" for us U.S. folks) off is going to make any difference.
Thanx for the kind words on the website!
-Ted
-Ted
i saw one last week where they just drilled the holes in the center housing and put it in with stock fc mounts, it really looked too easy.
ted's method works well too
Trending Topics
-Ted
RETed: Yeah, it's a question on how you want to mount the engine...
-Ted
-Ted
you're right, the hinges of the driveshaft should be able to compensate this little deviation in alignment!
j9fd3s: i saw one last week where they just drilled the holes in the center housing and put it in with stock fc mounts, it really looked too easy.
slo: A guy on the no pistons forum was or is making bolt in mounts for sale.
thanks guys, i appreciate your help!! any other comments??
regs
there are motor mounts already sold to put the 13bre and 13brew into an fc. http://www.banzairacing.net/
please dont post miss information.
Originally Posted by airworks-fc3s
yeah i heard of that method, but i'll have to take the tII oil pan and seal it in the front 'cause it's shorter than the rew's one. and by the way, what's going on with the left mount (driver side), is that one still in place with rew??
regs
regs
ok so there are no aftermarket mounts available... i''l have to try to fabricate them myself... why not
is it possible to bolt the stock fan (stock pulley) to the front plate of the rew?
(please don't start a mech fan/electric fan discussion, just assume i'm veeery happy with the stock fans performance)
any other issuesi might consider??
regs
regs
regs
regs
nzconvertible: Even if the FC pulley could bolt to the FD pump (no idea but I wouldn't count on it), it would place the fan in a different position compared to the FC and so require a custom fan shroud. You'd have to decide whether or not that's easier than using an e-fan.
by the way, nice turbo vert there! in europe the verts came only in turbo version, mine's a '91 s5 turbo vert!
aaroncake: Custom fuel system, custom intercooler, custome intake, custome exhaust, custom cooling system, etc. etc.
but most of that i've already got
aftermarket mounts http://www.motivefab.com/
stock harness and a PFC would be the best way to go IMO
Originally Posted by walken
Apex PowerFC. Tuneable plug and play ECU that functions like the stock ECU.
okay, have some troubles with these abbreviations but i'll get used to it
the power fc would be a nice solution, thought about it... but:
don't flame me, i wanted to max out the stock twins, 'cause i like the low end response of them, don't think the PFC supports them, does it??
Originally Posted by NZConvertible
Thanks! That's the way they all should've come.
yeah, especially considering the increased weight of about 80 kilos compared to the coupé!
with the top down you can hear the enigne at it's best
can't wait until next summer!!
at the moment it's ... say not ready to ride...
