Azenis 615 Vs. Hankook Ventus Rs2 Z212
Which one should I use on my 2280 lbs FC in the 205/50/15 size. Wet traction doesn't matter. Wear almost does. Weight does. Turn in feel does. Overall grip does. Auto X track will be in Nashville TN, probably over 60 seconds and will have speeds around 65 mph. Suggestions?
2280? You are my hero! I'm at 2473lbs, still Street Touring S-2 legal.
Falkens grip better if you've only got a 205 to work with, and the 'kooks need to be shaved.
I am currently running the 225/45-16 Hankook on a 16x7.5" wheel, if that matters. I would really like to switch to the Falkens, if you catch my drift......
-JW
'06 ProSolo- Fontana winner, STS2. '89 RX-7 GTUs
-JW
Well there we have it!
-JW
-JW
James
Grassroots Motorsports did a test a while back:
http://www.grassrootsmotorsports.com...5_tiretest.pdf
The Azenis are faster.
There is one thing to consider though, the RS2's are going to be available in a 225/45/15 in the next few months. If your wheels are wide enough and there's enough room with the offset you've got, and you can wait a bit, then I'd get those. The extra width should make up for the difference in grip and maybe more.
I saw that too and they are tempting
The grip would have to increase over the Azenis enough to counter the slight increase in weight. The weight for the Proxes RA1 is 23 lbs so I can guess I would gain around 2lbs of rotating weight per tire, maybe slightly less.
My only other concern about the Azenis is the problem of hardening over time due to heatcycles. My old 215s made me mad because after the tread was half gone, the tires were hard as rocks.
The wild card in the deck apears to be the Ecsta MX. Not as grippy, but they don't care about heat and they last FOREVER. Plus, I don't run national events. I might not even be a good enough driver to take advantage of the extra grip on a consistant basis that the Azenis would add.
Then there are those hard launches with my puck clutch and street ported 13B all going through my "glass box" N/A transmission. I would *hate* to hook hard and then frag the box 100 miles from home.
245s Hankooks definately fit on a 16x8 rim. You may be able to fit 245s or at least 235s on a 7.5 inch wide rim if you find a good tire place.
I don't think the Azenis came in 245s, that's why i went with Hankooks, plus they were cheaper. The whole width thiong convulutes the comparison huh. =)
Trending Topics
are you comming to Nashville?
are you comming to Nashville autoX in Smyna? I might get off from work early and come to watch. I will be joining the action later next month if all goes well.
615, alternative, autocross, azenis, falken, grassroots, hankook, lotus, motorsports, rs2, rs3, ventus, weight, wider, z212
