FD alt into a S5 turbo 2
Aren't the connectors the same or at least the plug is right??? I really dont want to blow another alternator. I did searching and help from arron and got the diagram but it looks like the way they connect is the same. I do experience the draining and today my internal regulator broke so the alt wash pushing 16.7 volts. I know this is all due to wiring but all my wires lookk correct. heres a pic of the diagram im goin off of and the s5 plug.
You guys are awesome thanks. Yea that alt is big mother... All i did to make it fit was put my duel pully and get a .5" bigger belt and i was set. Oh.. and d =ing my tmic a lil tiny bit for the B cable. Any ways.. I was just curious to what might of cuased my alt to go out if the wiring was fine. I mean i had the car for a year and the s5 alt went out, no biggy, so i go bigger and in ONE month it goes out and takes an optima with it... am i missing something or just a string of bad luck....????
Trending Topics
Originally Posted by samperry007
what about when you wire up an s4? How should it be?
no different plugs and also were the mount on the back of the alt, but you can buy adaptors for them, your you can make your own, but ifyou do that get a wiring diagram and match them up right and you'll be all good!
The Shaolin
Sep 14, 2015 07:50 PM
