Haltech E8 reviews?
Old Apr 29, 2005 | 08:19 AM
Sesshoumaru's Avatar
Tenseiga
E8 reviews?
Anyone used the E8 yet?
I see it's about 1700 or so.
I wonder if some of the glitches and if the harness is improved over the e6x.
Old Apr 30, 2005 | 07:31 AM
RETed's Avatar
Wow, for a couple hundred dollars more, I'd get the E11...
-Ted
Old Apr 30, 2005 | 01:48 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Ok, first off, the E8 is a downgraded version of the E11, ITS NOT an upgraded E6X. Second, the E8 can be totaly accomodated to any application because you can program your own sensors ranges and do not need to purchase the haltech units. Also, the "no sensors" kit costs US$1350.00 with a flying lead harness. The E11 in contrast costs US$1775.00.
The new E8 is far more capable than the E6X, and on top of that, the E6X has been lowered in price and new patch looms for different applications are going to be released very soon.
So if anybody wants to buy E8's i will sell them for 1350.00 plus shipping to the US, Canada and Puerto Rico.
Contact me if you need one.
Old Apr 30, 2005 | 09:40 PM
Tenseiga
I didnt' say it was a upgraded e6x.
How do you accurately adjust the senor curves? Is there build in settings for "mazda", GM, Ford sensors?
I personally like the idea of getting all new sensors and not haveing to configure the senors or useing old wiring from my previousy harness.
What can you do for a e6X kit and a Full sensor kit for the e8.
Old May 2, 2005 | 04:28 PM
EFI Tech Wannabe
I can get the E6X with the Fully terminated harness, sensors, and 3bar MAP for US$1350.00 shipped to the US, and with a flying lead harness for US$1200.00 also with shipping. I can probably get the flying lead kit for a lower price, give me a couple of hours.
As for the E8 sensor pack:
3 bar MAP US$90.00
Coolant Temp US$20.00
Air Temp US$25.00
TPS (if you have an S5 manifold you can use the full range TPS and save some money) US$50.00
(all sensors with connectors)
Toital: US$210.00 Including Shipping.
Let me know if i can get you anything, i can be payed with paypal.
Old May 3, 2005 | 07:23 AM
Tenseiga
3 bar MAP US$90.00
Air Temp US$25.00
On those water/air you can you get the metric version?
Old May 3, 2005 | 01:56 PM
EFI Tech Wannabe
Actually, right now i can only get the coolant metric sensor, the air temp is still that 3/8 NPT styled. I hope to have the metric one for that soon.
Are you interested?
Old May 3, 2005 | 04:53 PM
Tenseiga
Are you interested?
I need a ECU and it will be a haltech.
Just look'n at which model.
the e6x does what i need but i like the sequential injection on the E8 and the E11.
Could you elaborate oh how to setup the E8 for OEM senors?
I plan on using the stock TPS from the FD. I might use the stock air/water to save some money and buy a 3 bar sensor.
If i can just find some connectors for side feed injectors i'd be set. Any one know of a place that sells the connectors?
I just sold some jimlab bushings to pay for a haltech
Old May 3, 2005 | 11:02 PM
EFI Tech Wannabe
Well, sequential injection in a rotary doesnt realy make that much sense, since you wire up the primaries together and then after a certain load/rpm point you add the secondaries, so in this case the E6X is just perfect.
The way the E11 and E8 use any sensors is by just inputing a voltage range in the configuration part and thats it. For example, at any given temperature, the temp sensors are telling the ECU a specific voltage from 0 to 5 volts.
Halwin Sensor Calibration Window
And the program has the option to input both Ohms or Voltage, and has serveral presets available.
Old May 3, 2005 | 11:35 PM
Tenseiga
What the bottom line price for a E6X with flying lead and senors shipped?
The e8 sensor feature is nice but the price is still more than the e6x with sensors
I'll prolly stick with the e6x as that has what I need.
Old May 4, 2005 | 12:00 AM
EFI Tech Wannabe
US$1200.00 with 3bar map sensor, shipped to the US. I would consider doing a group buy if enough people are interested.
Let me know if you want one.
Old May 4, 2005 | 06:22 PM
Tenseiga
Ok i'll buy one. Does that include TPS/Coolant/Air or just the 3 bar sensor?
Should I wait to see if there is a group buy?
Old May 4, 2005 | 06:53 PM
EFI Tech Wannabe
The 1200.00 is for the flying lead kit with sensors, including 3 bar.
If you wanna organize a GB, i wont mind, but if you want it right away as soon as possible just paypal me and ill order yours up right way. My paypal addy is: info@tuningtechnology.com
It should take a week to get to me and about 2 days more to get to you. I use FedEx for shipments.
Let me know,
Old May 4, 2005 | 10:39 PM
Tenseiga
Let me know,
the deed is done
Old May 4, 2005 | 11:57 PM
EFI Tech Wannabe
Emailed ya...
Tomorrow i put the order in.
Old May 5, 2005 | 06:00 PM
Tenseiga
got it done
Old May 5, 2005 | 09:34 PM
EFI Tech Wannabe
Got it, thanks, you should have your unit at the very most middle of the week after next.
Thanks for your business.
Old May 17, 2005 | 10:47 AM
DCrosby's Avatar
No it's not Turbo'd
So is there a harness for an FD ? I know I'll get flack for asking, since most stock harnesses are fried, but somehow mine is in 7 out of 10 condition, and I'd rather be able to return everything back to stock should I be "forced" to...
I'm also interested in hearing from E8 owners, and tuners on how "satisfied" you are... especially people running high HP (350+ applications).
I need to be able to use FJO wideband 0-5v system. Have 3 Bar Map. Anything else like boost controll via GM sensor, and Ignition Knock retard would also be very desireable...
-DC
Old May 17, 2005 | 06:40 PM
EFI Tech Wannabe
Right now there is only a patch loom for the E6X to map to the FD RX-7, but im not sure yet if the US office has them. There are, i assume, plans for patch looms or the E8/E11 for these cars.
I will try to keep you informed.
As for E8 trials, im waiting on some orders i hope to put in so i can get an E8 for my self and give it a go.
Old May 18, 2005 | 10:18 AM
DCrosby's Avatar
No it's not Turbo'd
From some of the previous posts it seemed like the E8 was a poor-er choice over the E6x due to the absence of features... was this a mistake or still valid ??
Old May 18, 2005 | 11:15 AM
Tenseiga
The E8 has more choices since it's a down graded E11
E11 ---> High lvl
E8 ----> Mid grade
E6X ---> Low lvl
You just need to pick the unit that is best compromise on what you need/want with respect to price.
One reason I didn't want a E8 is becuase I had to use my old wiring harness for the sensors and for about the same price I could get all new ones with my E6X.
Old May 18, 2005 | 12:52 PM
EFI Tech Wannabe
Sess,
The E8 has its own flying lead harness, the fact that you use the factory sensors doesnt mean you will use any kind of factory harness at the most you use the connectors with 3 or 4 inches of wire. In any case, the Stock Water Temp sensor can use a bosch styled injector connector.
I would use the haltech air temp though. And DC, to answer your question, the E8 is FAR BETTER than the X, like Sess mentioned, its an E11 with a few less outputs and inputs.
Old May 18, 2005 | 01:13 PM
Tenseiga
Sess,
I was refering to the 4 inches that you have to keep.
the harness is usually worse right at the connector or the connector itself is broken.
on that note.
anyone know where to buy injector clips for the sidefeed injectors?
Old Jun 21, 2005 | 05:47 AM
EFI Tech Wannabe
Attention Haltech Shoppers!! - E6X, E8 and E11v2 special offer!!
Please go to this post for complete details on my Haltech prices.
https://www.rx7club.com/showthread.php?t=436001
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
series1rx7
Sep 27, 2015 05:46 PM
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
