Yeah! New rtek 1.7 chip now available
Old Oct 6, 2004 | 03:22 PM
hondahater's Avatar
spending too much money..
I'm ordering mine now just thought I would let you guys know that their site is updated now with the new 1.7. The 1.7 has no data logging however the 1.7 has the fuel maps redone for 720 secondaries, unflood, lowers secondary cut on to 3300rpm instead of 3500 on 1.5 chip and price is 95 bucks do it yourself install or 115 to have them do it.
Old Oct 6, 2004 | 03:41 PM
hondahater's Avatar
no one cares??? I bought mine
Old Oct 6, 2004 | 03:44 PM
sub9lulu's Avatar
i wouldnt mind supporting them
but i m going microtech ...
Old Oct 6, 2004 | 03:45 PM
koukifc3s's Avatar
Clogged cat
I want my n/a Rtek!!
Elysian's Avatar
Bimmer *****
if i still had my 88 TII i'd care
Makenzie71's Avatar
...94% correct.
do they have a chip for a car with stock injectors?
Old Oct 6, 2004 | 03:46 PM
Elysian's Avatar
Bimmer *****
the 1.5 chip
Old Oct 6, 2004 | 04:06 PM
Kingofl337's Avatar
Letting the Smoke Out!
They need to make a S5 N/A chip that lets us ditch the OMP!
Old Oct 6, 2004 | 04:22 PM
barcode's Avatar
I want 2.0 with datalogging, I'm holding out for that.
Old Oct 6, 2004 | 04:24 PM
poor_red_neck's Avatar
Wait................What?
Yes sir...
If he can disassemble that **** mazda calls code (j/k ) and get rid of the MOP, and all the features in "2.0" (non-existant as far as we know) then I'll buy.
Old Oct 6, 2004 | 04:48 PM
Markd01's Avatar
What is their Web Address? Thanks
Old Oct 6, 2004 | 04:54 PM
hondahater's Avatar
http://www.pocketlogger.com/?pid=rtek7feat
Old Oct 6, 2004 | 04:55 PM
Digi7ech's Avatar
I break Diff mounts
damn.
Seems pretty sweet.
Now I'm not fully up to par on fuel maps.
Soooo....
Will the ECU compensate for higher boost with this map?
Like if I boost up to 12psi?it will use the injectors right?
If so this thing is a holy grail for my damn car. I can't afford a SAFC yet and want to put some 720's in.
Old Oct 6, 2004 | 05:14 PM
jon88se's Avatar
Eat, sleep, work, mod.
Originally Posted by Digi7ech
damn.
Seems pretty sweet.
Soooo....
The stock ECU will compensate for higher boost as well - even 12 psi BUT the stock car runs out of injector past 10 psi. With Rtek v1.7 you WILL have enough injector past 10 psi and likely to around 14. With the Rtek 1.7, your new limit will be the stock turbo/intercooler. The stock IC is no good past 11 psi (I believe) and the stock turbo is done at 14-15 psi (oil seals will take a dump). The Rtek 1.7 is perfect for car with 720cc injectors, a stock turbo, upgraded fuel pump, full intake/exhaust and FMIC (as I understand it).
Henrik, jump in and correct me if I'm wrong...
Old Oct 6, 2004 | 05:36 PM
fastrotaries's Avatar
W. TX chirpin Monkey
Man it sucks that these guys came out, after I got a haltech. Could have saved me so much wiring.
RotaryWeaponSE7EN's Avatar
Sweet...I want one.
Old Oct 6, 2004 | 05:44 PM
foild's Avatar
what will this do for a NA S4?
any performance increases?
stock s4 that is... 86
Old Oct 6, 2004 | 06:08 PM
sub9lulu's Avatar
... why u want one for NA s4
... u DONT need 720's 2nd injectors
lean out ur car with SAFC will get u more power
Old Oct 6, 2004 | 06:28 PM
FC3S.USD's Avatar
Where is my Life ?
Nice, i was waiting for the V 2.0 But I think this will do.
Its scary when i read '' Needs 720 or bigger or else engine damage will occru but I guess its mapped for that size of injector ''
So I guess i will have to get version.
I hope there will be a trade in value for the when the V 2 comes out
Old Oct 6, 2004 | 07:05 PM
kd86rx7's Avatar
witht his ecu will i still need resistors for my secondaries going from high impedence to low impedence?
eric.
kd86rx7's Avatar
mods: full intake and exhaust, fmic, hybrid turbo 720cc secondaries, hks f-con with gcc and fcd, i dont need the rtek if i have the f-con with gcc right?
eric.
Old Oct 6, 2004 | 07:09 PM
kd86rx7's Avatar
answered my own question: If you have an AFC, it will no longer have to trick the ECU to compensate for the larger injectors. The AFC can be used for fine tuning.
thats cool,im thinking about buying it. for my mods.
eric.
Old Oct 6, 2004 | 07:13 PM
RXSevenSymphonies's Avatar
Turbo Swamp Thing
Sweet 1.7 will hold me over until 2.0 if I get my car on the road soon.
Old Oct 6, 2004 | 07:17 PM
Digi7ech's Avatar
I break Diff mounts
Sweet! just what i wanted to know.
So pretty much since the thing will use 720's they will work at a lower duty cycle so they don't max out for a long time unlike the 550's which end around 10psi.
BTW I have the v1.5 now and they say it's only 20bux to upgrade!! W00t!
Now I gotta get some 720's and boost!
BTW I'm assuming the fuel map is conservatively a bit rich right?
Currently I go SUPER lean right at the injector kick on (3500rpm)
Old Oct 6, 2004 | 07:21 PM
JAPSPECGTUs's Avatar
Turbo GTUs Est. 1999
This is the only time I will ever say I wish I had a S4, just for this purpose. Are they even working on a S5 version?
