Dual Oil Cooler Pics
Old 06-14-03, 03:02 PM
  #31
Fatty_FC3S's Avatar
one FD cooler really isnt enough. They should have had something like the crooked willow kit from the factory. And you wonder why FD's have heat problems.....
Old 08-21-03, 10:27 AM
  #32
HAILERS
HAILERS's Avatar
I took them down. Email me and I'll send you the files.
cludwig2@insightbb.com
Old 08-21-03, 11:55 AM
  #33
liquidferrum's Avatar
Old 08-21-03, 02:47 PM
  #34
HAILERS
HAILERS's Avatar
It's called a mistake.........../\ ?
Old 09-16-06, 09:43 AM
  #35
www.lms-efi.com
C. Ludwig's Avatar
So you all can quit emailing me 3 years after the fact here are all the pics I have.
Old 09-16-06, 10:42 AM
  #36
R.I.P Mark( Icemark )
fc3s91's Avatar
Why would you put one in front of the other. I used the stock oil cooler then ran the second fd oil cooler in where my brake duct were. I went from 210 normal cruising to 150 deg.. Your heat transfer is wrong. Meaning the heat that comes from one tansfers to the other. You might want to put the second oil cooler on top.
Old 09-16-06, 12:13 PM
  #37
www.lms-efi.com
C. Ludwig's Avatar
They're not one in front of the other. They're staggered vertically.
Old 09-16-06, 12:30 PM
  #38
RETed's Avatar
Problem is that it looks like the round cross-bar is directly behind one of them?
That would impede airflow?
-Ted
Old 09-16-06, 03:42 PM
  #39
Dak
Information Regurgitator
Dak's Avatar
I would guess that since these are on a road race car he needs the air coming in through the brake ducts to cool the brakes. As for cooler placement I imagine it's a balancing act to distibute the available air coming in to everything that needs it(oil coolers,radiator) to try to keep temps down.
Old 09-16-06, 04:13 PM
  #40
www.lms-efi.com
C. Ludwig's Avatar
The car was built within a set of rules that don't allow modifications to the bumper cover that would make it feasible to move the coolers to the corners like is mentioned. Good idea, but that's out.
The coolers are stacked as well as possible within the space there is to work with. Go any higher with either and we limited airflow to the rad and raised water temps. It was tried. There is no where to go lower as the lower cooler sits well below where the stock undertray is on the bottom of the splitter. There are alternatives, this is how I did it, it works well, temps are fine, pressure is fine, etc, etc, etc. Like Dak points out there are concessions to total cooling. Seriously, got a better idea? Do it. Build it, test it, and go win some races.
With this setup we went from 250*+ on the stock single cooler to around 190-200* depending on ambient temps, traffic, etc. That's on a road race car that's at WOT much of the time. Simple, effective.
Old 09-16-06, 11:22 PM
  #41
fc3s91's Avatar
What class are you running and sanction?
Thanks Robert
Old 09-17-06, 11:11 PM
  #42
www.lms-efi.com
C. Ludwig's Avatar
SCCA ITS
2005 Cen-Div East Champs. Sold the car this spring.
FD7KiD
15
02-26-21 10:12 PM
Quick Reply: Dual Oil Cooler Pics
