Tranny
Old Feb 24, 2007 | 10:05 AM
  #76
IronMdnX's Avatar
Glutton for Punishment
Transmission Size and pics
(A) Length - Bell housing to Output shaft 25.6" (650mm)
(B) Length - Bell housing to End case 24.4" (620mm)
(C) Length - Bell housing to Centre of Shifter 29.7" (755mm)
Width - Bell housing 15.5" (395mm)
Width - Gear Case (maximum) 8.5" (215mm)
(D) Height - Bell housing 14.1" (358mm)
(E) Height - Gear Case (maximum) 10.63" (270mm)
(F) Input Shaft OD 1.33" (34mm)
(A) Drive plate Diameter 252mm
(B) Drive plate surface area 50mm
Dry Weight 51kg
Old Feb 24, 2007 | 10:07 AM
  #77
IronMdnX's Avatar
More pictures and info
http://www.turbosupras.com/pages/en/...nical/V160.htm
Old Feb 24, 2007 | 10:15 AM
  #78
IronMdnX's Avatar
The Bellhousing looks large.
Here are a few more pics I dug up.
Old Feb 24, 2007 | 11:26 AM
  #79
RX-Heven's Avatar
I'll blow it up real good
Speedo options?
Old Feb 24, 2007 | 11:42 AM
  #80
Howard Coleman's Avatar
Racing Rotary Since 1983
comparative speed at 7500 rpm. 25.85 inch tire. no slip. top speeds of course only theoretical
-------FD-----supra------t56 C5------t56 ZO6/GTO-----supra w 3.13 rear gears
1-----40------36-------------52---------47------------------47
2-----69------59-------------78---------67------------------77
3----100------82------------107--------97-----------------107
4----140------107----------140--------140----------------140
5----194------139----------188--------174----------------181
6---------------176----------278--------224----------------230
observations: supra too short w stock rear gears but looks v good w 3.13.
i am going w the C5 T 56 w 07 shifting guts.
howard coleman
Old Feb 24, 2007 | 11:48 AM
  #81
FDNewbie's Avatar
Sponsor
Howard, thanks for that side-by-side comparison
Also keep in mind guys that custom gear ratios ARE available w/ aftermarket gear sets
Old Feb 24, 2007 | 01:55 PM
  #82
RX-Heven's Avatar
The Getrag trans is 4" shorter than the TII trans. That is absoutely perfect for me since I have moved the 20b back ~4". This is not counting the adapter plate thickness though. Couldn't be too hard to relocate the shifter though if needed.
Plus, I just got in on a Cobra 8.8 IRS diff conversion for 2nd gens. Oh yeah baby....
Old Feb 24, 2007 | 02:06 PM
  #83
WsUp_maNig's Avatar
Originally Posted by IronMdnX
Just saw this update.
Very interested, Looking forward for pictures and more info.
'Yo
Ya man this tread is very interesting indeed
WsUp
Old Feb 24, 2007 | 02:10 PM
  #84
WsUp_maNig's Avatar
[QUOTE=RX-Heven]The Getrag trans is 4" shorter than the TII trans. That is absoutely perfect for me since I have moved the 20b back ~4". This is not counting the adapter plate thickness though. Couldn't be too hard to relocate the shifter though if needed.
'Yo Heaven
U do dat ?
Dat's just too kool
Were can I get 1
WsUp
Old Feb 24, 2007 | 05:05 PM
  #85
Doc Holiday's Avatar
Needs more cow bell
howard coleman
I disagree. Id rather have one overdrive gear than 2. Im a drag racer, so my opinion may differ, but I dont see a reason in having my car geared to do 180 in 4th (or 5th, whatever is 1:1). Id rather have shorter closer together gears, and more tire under the car so it stays hooked. Long gears are for getting groceries.
Old Feb 24, 2007 | 05:38 PM
  #86
calculon's Avatar
On flats
except that the supra 6th isn't an overdrive at all. . .you NEED to change the diff gearing to realize any sort of benefit in terms of longer gears. . .
Old Feb 24, 2007 | 06:55 PM
  #87
Needs more cow bell
According to this link it is.
Old Feb 24, 2007 | 08:22 PM
  #88
Doc,
given your objectives i agree 100% w you. i should have posted that the gears are too short for me...
as to 6th being overdrive.... it certainly is. it is .79.... but yes, you do need to run a longer rear gear to stretch out top speed.
hc
Old Feb 24, 2007 | 08:52 PM
  #89
carx7's Avatar
I'm in for a supra setup. I've been looking for a long time at them, and spoken to you (Carlos) about building my 20b. I know you've recomended the trans setup to me before, and I'm still collecting parts for the build.
I'm certainly interested, and willing to put down money if you'll do a group buy for the first few. Seems like you could sell them tomorrow.
-Chris
Old Feb 25, 2007 | 09:09 AM
  #90
Turbo 3's Avatar
Safety Guy
Where did you get the Cobra 8.8 IRS conversion for the 2nd gen?
Old Feb 25, 2007 | 10:59 AM
  #91
RX-Heven's Avatar
http://www.torquecentral.com/showthr...7&page=1&pp=25
Already sourced my Getrag in need of a rebuild. I'm stuffing the dog ring gear set in it.
The going rate seems to be:
Used and neeeds a rebuild ~$1700
Used and in operable cond. ~$2800
Rebuilt ~$3200
New at cost ~$4500
New retail ~$6500
Old Feb 25, 2007 | 05:01 PM
  #92
RX-Heven's Avatar
For those pm'ing me, I sourced the trans from one of the larger Supra forums.
http://www.supraforums.com/forum/index.php?
I don't think there are any others currently available there right now though.
There are several more forums btw and it does seem, at least from the browsing I did, the trannies are snapped up pretty quick when they do become available. I got the only available one I could find ad it happened to be just what I was looking for, i.e. in need of a rebuild. Then again I only looked for a few little bit. e-bay proved worthless fwiw.
Old Feb 27, 2007 | 04:13 PM
  #93
Rhode_Dog's Avatar
\m/
This might have been brought up before but the V160 (93-96) had shorter ratios than the V161 (96-02)
V160
First Gear: 3.830:1
Second Gear: 2.360:1
Third Gear: 1.680:1
Fourth Gear: 1.310:1
Fifth Gear: 1:1
Sixth Gear: 0.790:1
V161
First Gear: 3.724:1
Second Gear: 2.246:1
Third Gear: 1.541:1
Fourth Gear: 1.205:1
Fifth Gear: 1:1
Sixth Gear: 0.818:1
Old Feb 27, 2007 | 07:50 PM
  #94
FDNewbie's Avatar
Sponsor
Is it the same tranny though (exterior-wise)? Cuz I may see if I can source a JDM one then Can someone post up the calculated theoretical top speeds for the JDM version (V161)?
Thanks!
~Ramy
Old Feb 28, 2007 | 07:17 AM
  #95
-------FD-----supra------t56 C5------t56 ZO6/GTO---------supra
---------------------------------------------------------------V160------V161
1-----40------36-------------52---------47--------------------47--------45
2-----69------59-------------78---------67--------------------77--------75
3----100------82------------107--------97-------------------107-------108
4----140------107----------140--------140------------------140-------140
5----194------139----------188--------174------------------181-------167
6--------------176-----------278-------224------------------230-------205
Supra: (V160 3.13 final drive, V161 w 3.36 rear gears to factor 140 in 4th gear)
howard coleman
Old Feb 28, 2007 | 09:39 AM
  #96
Needs more cow bell
Explain to me why you keep trying to gear the car to do 140 in 4th? I realize that 4th with the FD trans is 140 with the numbers you put in, but why do you want the supra trans to run 140 in 4th?
Old Feb 28, 2007 | 10:39 AM
  #97
take your pick there are lots of ways to look at trans ratios.
since my interest is comparing ratios to the box i plan to use, the T56 C5, and it has a 1 to 1 4th i want to see if you put a rear ratio in that delivers a similar speed... what are the top speeds in each gear. further, i picked 140 as that's the number in the stock FD with which i am most familiar.
Doc, should you wish to do it a different way, please feel free.
howard coleman
Old Mar 4, 2007 | 02:56 AM
  #98
crispeed's Avatar
'Tuna'
My opinion of a T-56 tranny is that it's just a waste of time gear ratio wise as a 6-speed. It's basically a 4-speed with two overdrives one of which is useless. Not to mention it was never designed for quick shifts at high rpms. Ask me how I know.
G-force and Liberity transmission do make some upgraded stuff that helps in the shifting department though.
The Getrag supra tranny is probably the best all around except for it's way too low 1st gear ratio for use with the final drive ratio of an rx-7 on a high horsepower application. Even the supra guys complain of this and often use second gear for hard launches especially if they are not using the stock final drive of the turbo 6-speed supra and did the conversion in a a supra that was either a 5-speed, automatic or NA application before. More positive points for the Getrag would be it's strength and high rpm shifting qualities something to which I also have experienced personally.
Richmond also makes a very good 6-speed transmission but the shifter location does require some serious surgery because it sits towards the driver's side of the transmission tunnel. Some very good ratios are available for this tranny though. On the downside this tranny also exibits poor high rpm shifting qualities even worse than the T-56 in stock form but also can be improved upon by the two companies listed above.
I'm going to be experimenting with one of these--->
http://www.g-forcetransmissions.com/tran_gt-5.asp
Old Mar 4, 2007 | 10:42 AM
  #99
FDNewbie's Avatar
Sponsor
Crispeed, thanks for your input I've heard the same thing re: the T-56 and shifting @ high rpms over and over from different sources. I'm thinking a Getrag w/ a 3.9 (auto) rear would help quite a bit re: the Getrag's gearing. Plus it's a real simple job to do; no crazy fabrication of a different diff cradle and installing a new diff etc.
Of course, if one tries the 3.9 and finds it STILL not where one would want to be, THEN we can explore a more complicated setup that would allow us to run whatever rear we'd want (eg. Jimlab's 8.8" Cobra IRS rear).
The one thing I'm curious about is, what's the ratio on the TII or any other earlier RX-7 rear diffs? Any of them lower than 3.9?
~Ramy
Old Mar 4, 2007 | 11:28 AM
  #100
RX-Heven's Avatar
3.9 is as tall as you'll get for RX7's that is out of cars equipped with an auto. Those gears will fit in the fd diff housing but not in the TII diff housing iirc.
I have found three sources that have plenty of rebuilt 6-speeds w/ 12 month warranties (sure ) for ~$3300 and one guy who only has new transimssions for $4400.
Unforrtunately the guy I found with the 6-speed in need of a rebuild decided not to sell it. I'll only put those PPG gears in one that needs a rebuild because of the cost difference. In the meantime, I'll keep looking....
