Mazdatrix true-dual pics?
Old Oct 31, 2001 | 12:48 PM
Ryde _Or_Die's Avatar
I would really like to see some good pics of the Mazdatrix true-dual setup assembled in case I decide to make my own setup. Thanks.
Old Oct 31, 2001 | 01:39 PM
TPDNRX7's Avatar
Heres one. Although I think you could probably make one for cheaper.
Old Oct 31, 2001 | 01:46 PM
Thanks for the pic, but was looking for a pic like, under the car after its installed. How many people have this system. I am going to try to make my own setup, just need to know exactly how the presilencers fit in. I know they are presilencers for late-model 1st gens but I want to know how they fit in & if any shop can make them fit. Thanks alot.
Old Oct 31, 2001 | 04:07 PM
Old Nov 1, 2001 | 08:25 AM
^^ I know some of you guys have the true-dual exhaust...
Old Nov 1, 2001 | 08:49 AM
relvinnian's Avatar
Don't be I'm sick of hearing you blab about the true dual this true dual that. You need to make yourself a custom true duel b/c that exhaust is too expensive for the performance gains. Racing beat sells uncollected flanges and you can find people mandrel bend you an exhaust.
Old Nov 1, 2001 | 09:38 AM
Lol, man I am in the process of getttin my own custom setup and would prolly already have it except I have to buy the presilencers to be sure that the 5th & 6th ports will open properly. I finally found a place that will do the piping for me but they want a diagram & I can not draw for ****. I am about to order the header, then the presilencers, & then pick some mufflers. Where do you need gaskets? Thanks.
Old Nov 1, 2001 | 09:44 AM
RX-7 GT's Avatar
HyperREV.com
you need gaskets everywhere it has bolts connecting pieces. just like stock's have etc
Old Nov 1, 2001 | 09:57 AM
relvinnian's Avatar
Use the extra money you spent to have your ports electronically activated. Dave has a writeup on www.fc3s.org . So basically you are saying that with no cats and presilencers you will have enough back pressure to activate your 6-ports? Why not AT LEAST use your airpump to do it? Even if presilencers did create enough back pressure wouldn't that negate the need for a true dual setup? You're trying to relieve as much back pressure as possible
Old Nov 1, 2001 | 10:28 AM
Well I am basically trying to produce the Madatrix true-dual setup. Theres gives a 28% in HP, or so they say, & it uses presilencers. I called them & they assured me it is just enough back pressure to open the ports. If I had a very detailed (pics a plus) description of how to open the ports with the air pump I would do that, then worry about the port opening. Or do the exhaust & air pump actuation the same day.
Old Nov 1, 2001 | 11:13 AM
So for approximately $660 you get same setup without the mufflers? The mufflers cost $350 each? Man, I can some HKS one I want for 100 each. Hmm... think I might know what I am doing now. Thanks Mazdatrix.
Old Nov 1, 2001 | 11:16 AM
O ya, without mufflers will the system still open the 6 ports? Thanks.
Old Nov 1, 2001 | 01:19 PM
Flavour's Avatar
what about that greddy cat-back, isnt that better?
Old Nov 1, 2001 | 01:31 PM
GReddy cat-back better than what? That is exactly what it says "cat"-"back." Catbacks give you little performance gain at all.
Mazdatrix...so the ports will open just with the header because of the modicications you guys have done to it, correct? So I don't need the presilencers unless I want it quieter? Thanks alot. Your giving me alot of valuable info.
Old Nov 1, 2001 | 01:38 PM
SpeedRacer's Avatar
Formula Mazda Driver
Just my personaly opinion, but if you have FULL true dual exhaust, why keep your 6-ports. You will lose a minimal amount of low-end with a system like that. Then you could get whatever headers your want, no presilencers, and save yourself a bunch of money.
Old Nov 1, 2001 | 01:50 PM
Well what I am now getting is that Mazdatrix does modifications to the header so its actually the header that actuates the 6 ports. I would like to keep them functional is possible. If it is the header that opens the ports I will order it tomorrow.
Old Nov 1, 2001 | 03:06 PM
kliftin's Avatar
speedracer
Speedracer is right. I have the duall uncollected but not on. It costed me 135. 185 totall. A muffler shop quoted me 150 for streight pipes installed. Mufflers costed 60 bucks each for long 24 inchers. So for 550-600 totall You can have an awsome exhaust. Of course people will tell you to get this and that but my way is cheapest doller per horspower and nowone will tell that its custom or mazdatrix.
Im selling my duall outs for 75. You pay shipping. Im buying my friends full rb duall so I dont need mine.
Old Nov 1, 2001 | 03:28 PM
Kliftin...what year is your FC? If it is 89+ then you don't have to worry about the ports opening like I do. If mine was 89+ i would already have the exhaust done.
Mazdatrix...so is it the header that actuates the 6 ports? Please let me know ASAP so I can order it, thanks.
Old Nov 1, 2001 | 06:13 PM
So with the $200 modified header I won't need the presilencers unless I am concerned with sound, correct? %th & 6th ports will actuate correctly with out the presilencers, just using the header? If that is the case I am ordering it tomorrow, just really want to make sure before I do order it. Oh ya, how long is the wait for that header right now? Thanks alot.
Also, the only gasket I would need when not using the presilencers would be the engine to header gasket, $11 & some change, right?
Old Nov 1, 2001 | 07:08 PM
Node's Avatar
what about a picture for the man like he asked for in the first place if ya have one handy ;-)
Old Nov 1, 2001 | 10:00 PM
lol, node. Well looks like you just sold one modified 86-91 header, lol. Ight tomorrow I will call, any idea on shipping costs to ZIP 33568? Thanks alot.
