TB Mod?
Old Oct 12, 2002 | 06:54 AM
RotorDemonGXL's Avatar
TB Mod?
yeah, I tried the search but nothing good came up. Is this something I can do with simple tools and a link would be nice if anyone has one handy. Thanks guys
Old Oct 12, 2002 | 07:37 AM
oppressor666's Avatar
I dunno man. I just did the TB mod and now I have to go buy a new throttle body, because it runs like major ***. It doesn't dle at all. No noticeable inprovment. I would probably only suggest it as a " I have done everything else possible" Probably doesn't hlp that I do not have any more mods beside ported manifolds. But thats my opinion.
MARC
Old Oct 12, 2002 | 08:14 AM
silverrotor's Avatar
Re: TB Mod?
Are you kidding? TB Mod Is to this forum as a red Is to a rash. Search button will yield you more than what you need. But If you are after pics and detailed explaination than go here http://fc3s-pro.com/TECH/HOWTO/TBM/tbm.html
Old Oct 12, 2002 | 08:19 AM
MARC
You did the TB Mod and you have to buy a new one? Strange. Looks like you did something wrong. I doubt you have to buy a new one.
Your Ported Manifolds should compliment the TB Mod you did. Yet you have no Idle?
Old Oct 12, 2002 | 03:13 PM
Rs4Racer's Avatar
i think you have to adjust some stuff...
Old Oct 12, 2002 | 03:35 PM
Ni5mo180SX's Avatar
White Comet
Did the mod on mine, I havent had any problems and the motor seemed more responsive afterwards. Only downside is that I need to give it gas when warming from a cold start for about 15 seconds.
Old Oct 12, 2002 | 03:59 PM
rotarygod's Avatar
Rotors still spinning
I noticed that my idle went up to about 1000 rpm after the mod but that was easy to fix. No adverse side affects.
Old Oct 12, 2002 | 05:00 PM
I removed the Secondary Plates (left the Cold Start alone). I didn't even have to adjust the Idle.
Old Oct 12, 2002 | 05:15 PM
FC Drifter's Avatar
Damaged Little F*cker
what exactly is the point of the TB mod? i know basicly how its done and what it envolves, but i dont really know why people do it. sorry if thats a dumb question.
Old Oct 13, 2002 | 12:04 AM
boostmotorsport's Avatar
I did it and dont really know if I gained any HP, but throttle response was amazingly improved. Now if I am cruising at 3K in 2nd gear and blip the throttle the motor follows suit just as I touch the pedal with no gap between my actions and the cars response. Do it correctly by following the instructions closely, and you will love it.
Old Oct 13, 2002 | 07:14 AM
No I got the TPS adjusted. The goddamn idle adjustment screw on top of the throttle body does not do **** any more. I dunno I Pretty much did what everyone else does. I think my car just hates me and tries to **** with me all the time. Maybe I need to drive it off a cliff, that will teach it.
Old Oct 13, 2002 | 07:24 AM
viperkiller7's Avatar
1.3 liters of whoop ass
Did you plug the holes after you took out the throttle plate rail. you can use JB weld
Old Oct 13, 2002 | 08:30 AM
i knew i forgot to do something. YES i did plug the holes. I used some 7/16 set screws. I dunno, my car just sucks sometimes. I blew my headlights last night because my altenator is over charging.
Old Oct 13, 2002 | 08:41 AM
Rotorific's Avatar
I dont know a damn thing
TB mod the best thing to do to your throttle body since sliced bread
Old Oct 13, 2002 | 09:16 AM
presetlimits's Avatar
when i had the tb mod on my car i felt a very noticeable differnce but i hated when you started it you had to keep it up and running for a little bit til it was warm enough to drive
Old Oct 13, 2002 | 08:09 PM
For a little bit, Yeah till it is all the way warm. I am thinking of just bolting the temp thingy back up. For a whle I had just taken out the butterfly plates, and it would still high idle. Now like I said it will not idle until it is all the way warm.
Marc
Old Oct 14, 2002 | 08:24 AM
You can still reap all the benifits of the TB Mod, w/o messing with your Cold Start Apparatus, simply by removing the plates. How wants to hold on to the Throttle, without fear of car bogging out, for a minute or so?
Old Oct 15, 2002 | 03:03 PM
RETed's Avatar
Geez, you guys can't read?&nbsp It's all in the write-up.
And for the record, I do NOT recommend this for NA's - the write-up is for turbos only, and I cannot guarantee positive results for NA owners.
-Ted
Old Oct 15, 2002 | 04:03 PM
jon88se's Avatar
Eat, sleep, work, mod.
why not for NA's Ted??
Old Oct 15, 2002 | 04:19 PM
RETed's Avatar
The downsides outweigh the benefits for an NA.
The flow potential in a turbo engine is a lot greater than an NA engine.
The low-RPM "hiccup" can become a major pain-in-the-*** on a street driven FC.
-Ted
Old Oct 15, 2002 | 05:16 PM
I've loved It ever since.
Old Oct 15, 2002 | 09:41 PM
jon88se's Avatar
how come only an NA will hiccup and is this just the 'give it gas for a few seconds while it's cold" thing. Could I just adjust the idle to about 1000 and play w the mixture screw to get it to idle??
Old Oct 15, 2002 | 10:16 PM
jon88se's Avatar
I only ask since I have a modded TB ready to go in that I got for nothing, plates removed and plugged w JB weld (nicely smoothed over the JB weld on the inside so the holes look hidden). If I swap everything from my old TB over to this one (including TPS w/o messing w it since it runs great now) will I run into these reliabilty problems? I'm curious since I'm running outta stuff to do to the car
Old Oct 15, 2002 | 10:31 PM
rotarygod's Avatar
I had the ported tb on my n/a. No hiccup and improved throttle response. I still had the thermo wax pellet too. Easy to keep if you know how. No negatives. A benefit is a benefit whether it is on a turbo car or not. Air still flows in the same direction and therfore acts the same whether it is under a vacuum or pressure. I believe someone here (not me) would consider this mod undoing years of research and millions of dollars that Mazda engineers spent in designing it this way! Not naming anyone of course.
Old Oct 15, 2002 | 11:03 PM
I wish I was driving!
Adjust idle via the cam stop screws, not by the screw on top.
