Fastest 1/4 mile on stock turbo?
Old Oct 30, 2002 | 08:34 AM
87T2's Avatar
I tried a search but didnt come up with anything. What is the fastest 1/4 mile time achieved on without a turbo upgrade? This assuming that other mods are performed (FMIC, fuel, intake, exhaust, etc...).
Old Oct 30, 2002 | 10:17 AM
fastrotaries's Avatar
W. TX chirpin Monkey
13.93 was the Official with stock turbo, motor, I/C.
I later put on a RB lightweight flywheel and the car was soooo much quicker. I ran some friends that have posted 13.6 and squeezed by them. But Officially my time was 13.93. It was really consistent at 14.0-13.98 Really consistent 207RWHP and 199 lb/ft of TQ
Old Oct 30, 2002 | 10:46 AM
MaTT_FoULk's Avatar
earning these was better
How much boost were you running?
Old Oct 30, 2002 | 12:52 PM
BogusFile's Avatar
I met a guy named ronald who had a 10th ann. that ran 12.7 on the stock turbo. I saw a video of the run to verify it. There was alot of work done to the motor..... though I want to say it was a stock ECU.
Old Oct 30, 2002 | 01:00 PM
TRURX7's Avatar
I ran a 13.9 on my stock turbo, I still had all my sound system in it, running about 9lbs boost
Old Oct 30, 2002 | 02:47 PM
I wish I was driving!
Re: Fastest 1/4 mile on stock turbo?
Does it have to be a 13BT? (3rd gen or 20B's also have stock turbo's). Any additional forms of forced induction count?
Old Oct 30, 2002 | 02:53 PM
Ryde _Or_Die's Avatar
Come on guys I know you can get in the low 13s fairly easy with the stock turbo, right? I hope to come close to 12s running around 12-14psi hopefully.
Old Oct 30, 2002 | 03:15 PM
87T2's Avatar
Re: Re: Fastest 1/4 mile on stock turbo?
yes 13BT.. no nitrous
Old Oct 30, 2002 | 03:53 PM
djaaronp's Avatar
Anyone know the times for the convertible with a stock turbo hehe, anyone done the switch and clocked it? If not, give me several months and ill let you know. Probably a considerable amount slower cuz of the extra weight. What is the stock weight of the convertible, my sticker on the door is scratched off. anyone know?
Aaron
Old Oct 30, 2002 | 04:54 PM
cbrock's Avatar
I've gone 14.2 @99mph @ 7psi. Stock everything...cept a k&N and the boost set to 7 psi (s4). Shooting for high to mid 12's before I switch to a full T04.
Old Oct 30, 2002 | 05:27 PM
jmseven's Avatar
Asset is Wealth
Stock/Stock w/ full RB t-back and computer will rung hi 13's. With a FMIC and FPR, hi 12's are easy.
Old Oct 30, 2002 | 07:31 PM
RETed's Avatar
Jeff (something) ran a 12.6 @ 11x (112-116?) - stock ECU, FCD, stock IC, full exhaust.
I heard he was running 17psi though...
-Ted
Old Oct 30, 2002 | 09:32 PM
i was running 10 psi with a profec-B. But the turbo was worn and would not hold 10psi in 3rd gear past 4K rpms. It was just as efficient as i could possibly make it.
Old Oct 30, 2002 | 09:35 PM
ponykiller's Avatar
guy in my club was at low 13s, with only $700 invested in his car (10 AE)! He had S5 turbo, intake and exhaust. Did I mention that he is a damn good driver?
Old Oct 30, 2002 | 09:36 PM
i averaged about 96-98 MPH.
Old Oct 30, 2002 | 10:56 PM
Wankel Traitor
Low 13's are very doable, with high 12's probably the upper limit.
Jameson
Old Oct 30, 2002 | 10:59 PM
Turblown's Avatar
Turn up the boost
Im gonna try to hit 12's with the stocker....
Rotary Performance Parts
Old Oct 30, 2002 | 11:55 PM
if your stocker isn't working right or up to par it'll never happen. some of these turbo's that have 100k are ok for low boost, but at high boost their age really comes through.
Old Oct 31, 2002 | 07:38 AM
Turblown's Avatar
Turn up the boost
Yeah i figured that, rebuilds don't cost that much anyhow. might as well stick a to4 turbine in there, but then u could say its not really the stock turbo.
Old Oct 31, 2002 | 09:37 AM
rx-7fc's Avatar
what is the hp diffrence if you put a s5 turbo in a s4 car
Old Oct 31, 2002 | 06:43 PM
RETed's Avatar
Nothing really...
-Ted
Old Oct 31, 2002 | 06:51 PM
Johny zoom's Avatar
Hey. fastrotires I have 100 thousand miles on Tiffany boosting about 11 lbs does this = boom.
Old Nov 1, 2002 | 10:55 AM
Turblown's Avatar
Turn up the boost
street tires?
-Ted
Old Nov 1, 2002 | 12:23 PM
should be 12s i would think. runs outta ummph after that
Old Nov 1, 2002 | 03:48 PM
Turblown's Avatar
Turn up the boost
hey Ted, do u know if that was on street tires?
