6 speed tranny?
Old Nov 10, 2004 | 07:44 PM
pezking's Avatar
6 speed tranny?
i checked the old posts but couldnt find much... do they make 6 speed trannys for fd's?
Old Nov 10, 2004 | 07:47 PM
Nick13B's Avatar
why would you want a 6 speed?
Th car already tops out at 183mph with 5 gears, and its geared perfectly for the eninge
Old Nov 10, 2004 | 07:49 PM
dgeesaman's Avatar
https://www.rx7club.com/showthread.php?t=365018
#21 covers it, and JimLab provided most of the answer.
Old Nov 10, 2004 | 07:54 PM
'98 Type RS's Avatar
#71
Why ask why? Maybe he's going to use the car for something different than you. Changing the gearing effects more than top speed. I get sick of reading that stuff.
Old Nov 10, 2004 | 08:17 PM
jimlab's Avatar
Super Snuggles
Fair enough.
Personally, I get sick of reading posts asking about 6-speeds when the asker knows ****-all about gearing or why you'd use 6 gears instead of 5. All they seem to know is "6 is 1 better than 5".
Old Nov 10, 2004 | 08:27 PM
Nick13B's Avatar
Originally Posted by jimlab
Fair enough.
Good point
Old Nov 10, 2004 | 08:44 PM
travisorus rex's Avatar
Avoid the Noid
Vipers have six gears JIM. RX-7's only have five. That must be because they are better then the RX-7. After all, the FD was modeled after the Viper.
Old Nov 10, 2004 | 08:53 PM
jimlab's Avatar
Super Snuggles
True, but for a good reason.
Old Nov 10, 2004 | 08:55 PM
Nick13B's Avatar
The only reason to go 6 spd is if you are doing an LS1/LT1 swap
Old Nov 10, 2004 | 09:30 PM
broken93's Avatar
apex seal BBQ
Fair enough.
That really is damn funny.
Old Nov 10, 2004 | 09:42 PM
jimlab's Avatar
Super Snuggles
In a Viper?
Old Nov 10, 2004 | 09:44 PM
Nick13B's Avatar
In a Viper?
Yes 10 cylinder engines are gas hogs, I want the look of a viper but the fuel economy of a honda civic with vtec lol
Old Nov 10, 2004 | 10:06 PM
darkphantom's Avatar
The king of the highway!
Thumbs down
the rx7 doesnt top at no 183mph, it only does 156. theres no one here that have gone even 170mph stock version
Old Nov 10, 2004 | 10:16 PM
i didnt read this post the hole way through and i used to be like him. Because i had started a post about finding the legendary six speed transmission and i did find it at rotary extreme where they use the stock 5 speed transmission and add an extra gear. But frankly if you got this car to go as fast as you can you have to think about alot of things.
doing 180-200mph on the highway is possible but extremely dangerous
2. unless your racing at a race track dont even think about it.
3. six thousand dollars for another gear sounds tempting (because its a six gear) but is ricidilous
4. a transmission does make your car faster cause of the extra gear but you need good suspension, tires, aerodynamics, downforce, handling, skill, horsepower. By the time youll end up in this project youll be up in the $30,000. For god sake just leave the six speed alone.
Old Nov 10, 2004 | 10:33 PM
jimlab's Avatar
Super Snuggles
Speaking of knowing ****-all about 6-speeds, the GReddy gear set is a close ratio gear set. 6th gear is actually shorter than the original 5th gear, which means a lower top speed than stock.
darkphantom, you shouldn't post any more.
Old Nov 10, 2004 | 10:41 PM
both the 5 and six speed can have the same gear. on the final gear it was the same and we did get more speed out of the car?? thats the truth
Old Nov 10, 2004 | 10:42 PM
jimlab's Avatar
Super Snuggles
What in the hell are you babbling about?
the 5 speed did 160 and the six speed did 171mph. all gears and final gear ratio was the same. just the addition of the six gear
Old Nov 10, 2004 | 10:45 PM
jimlab's Avatar
Super Snuggles
I repeat, what in the hell are you babbling about?
Old Nov 10, 2004 | 10:47 PM
ForceFed's Avatar
a stock RX-7 may be drag limited to 156-159mph, but that doesn't mean thats it's top speed. In this case, the car's theoretical top speed is much higher than 159mph due to gearing. I can't remember what a stock FD gearing is limited to(183mph? Thought it was higher than that).
Like Jimlab said, you shouldn't post anymore Darkphantom.
Old Nov 10, 2004 | 11:18 PM
jimlab's Avatar
Super Snuggles
With enough power, 195-200 mph, especially with a taller tire (P275/40-17).
Old Nov 10, 2004 | 11:19 PM
sub9lulu's Avatar
what u smokin anyways
Old Nov 10, 2004 | 11:29 PM
zmarko's Avatar
shoo shoo retarded flu!
Ha ha. This thread is awesome.
Old Nov 10, 2004 | 11:31 PM
SpeedKing's Avatar
Power Trippin'
Yes you were.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/legendary-6-speed-transmission-352138/
Yet, you're still an idiot and a liability in other ways. And that's why the little red square next to your post count is red.
Old Nov 10, 2004 | 11:32 PM
Black97VR4's Avatar
FEARED
The stock ratios should be good for around 190mph or so on stock rims/tires. I think my car could possibly break the 200mph mark with my 285/40/18's in the back. Not that I'd try.
darkphantom, I won't go as far as to say you shouldn't post anymore ever but you need to research quite a bit more before posting. You're on the right track but you have a little more learning to go.
