Spark Plug Restoration
Old Nov 20, 2004 | 05:43 PM
apneablue's Avatar
Hey guys,
I bought this nifty little air tool...Its for cleaning sparplugs...Most of you probably know about this but the difference when you clean them is amazing... Well, you might say..."why the **** don't I just buy new plugs? Well, I am running a couple of those Greddy race plugs at about $35 a piece...so I just wanted to get as much out of them as possible.
Here is a photo of the tool and before and after photos on the plugs I cleand.
THE TOOL (Hehe, I said TOOL )
PLUGS BEFORE CLEANING
PLUGS AFTER CLEANING
Attached Thumbnails Spark Plug Restoration-pict0010.jpg   Spark Plug Restoration-pict0008-3-.jpg   Spark Plug Restoration-pict0009.jpg
Old Nov 20, 2004 | 05:56 PM
the_glass_man's Avatar
Will u do me a kindness?
where?
Old Nov 20, 2004 | 05:58 PM
Snook's Avatar
Tony Stewart Killer.
sexual
Old Nov 20, 2004 | 05:59 PM
P'cola FD's Avatar
Hamado things my way!
I've had one of these spark plug cleaners for the longest time. For $30, it's one of the best investments I've made for my car. When I first got my AEM, I was fouling plugs like crazy, but with the cleaner, the last a long long time. BTW I got mine off the Matco truck.
Old Nov 20, 2004 | 06:02 PM
akiratdk's Avatar
The Laser Man
Can you buy them like any auto store??? or is this like a specialty tool kinda deal...
apneablue's Avatar
Originally Posted by the_glass_man
where?
Ah ****...Sorry...Got it at the local Harbour Freight...It was $16.??...worth it in my book...You can buy it online also but I got it local.
BUY IT HERE.
Tell them David sent you....
Old Nov 20, 2004 | 06:12 PM
BlueRex's Avatar
Looks like a worthwhile investment even if you're using the stock plugs.
Old Nov 20, 2004 | 07:06 PM
afterburn27's Avatar
Lets Go Hokies!
We've got one at the garage and it works great
Old Nov 20, 2004 | 07:28 PM
eyecandy's Avatar
I have one of them, really help exspecially on breaking in a new engine, since plugs get foul very quickly.
You also might want to try a very thin piece of metal (like a tooth pic) to make sure there is no sand left in the bottom of the plug and to clean little noks and crannys.
Old Nov 20, 2004 | 09:27 PM
apneablue's Avatar
I just blasted it with air...worked great.
Old Nov 20, 2004 | 09:59 PM
eyecandy's Avatar
The only problem with that is sometimes to blast it further into the plug, I use to do that until I started to notice on a few that sand was getting trap, just an extra precaution.
Old Nov 20, 2004 | 10:24 PM
wReX's Avatar
Does not drive a WRX!!!
Yeah that cleaner works great. I'll agree it's a lifesaver with those of us who have race plugs.
Just remember, s spark plug should only be cleaned 3 or 4 times MAX though, then you should really be replacing it with a new one.
Old Nov 20, 2004 | 10:36 PM
Yup, every FD owner should have one .
Coupla good points made......make sure you clean the plugs afterward with comp air/carb cleaner to get all the sand out before screwing them back in. Also, be aware that sandblasting them does slowly wear them down.
Davey, you have suck sexy flippers, er, hands
Old Nov 20, 2004 | 10:51 PM
apneablue's Avatar
BTW...What do you guys think about the two leanish looking plugs...Those are my trailing and the two race plugs are my leading.
I'm not so concerned with the race ones as I am with the other two that look kinda burnt...from a plug diagnosis stand point would you say that's normal or looks a little lean?
Well, I am headed to the dyno tomorrow so I can check the AFR and see for sure.
Old Nov 21, 2004 | 02:57 AM
WaLieN's Avatar
Call me gramps!
For plugs that are platinum coated, doesn't this blast away that coating?
Old Dec 22, 2004 | 12:07 AM
93FD3S's Avatar
Big Snail
Walien....good question. Does the platinum coat get blasted off if cleaned?
Old Dec 22, 2004 | 12:13 AM
rotorbrain's Avatar
fart on a friends head!!!
why would you buy platinum plugs anyways??? they burn out in the same time the regular ones do. i NEVER buy platinum plugs for my rx-7.
i thought about getting one of those things. . . but figured the sandblaster in the corner would work just fine. hahahaha.
paul
Frox
Feb 27, 2016 11:11 AM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
